Speed Passion Thread >
Like Tree4Likes
Old 03-18-2017 | 01:28 PM
  #5716
Thanks Optima, just what I needed, save me from having to buy a new blinky ESC!
Little_ceaz is offline
Old 03-18-2017 | 01:38 PM
  #5717
Why have the Reventon R 70a speedo's price's exploded?
Norse is offline
Old 03-19-2017 | 11:47 AM
  #5718
racer1812's Avatar
Super Moderator
FYI for those who may not know. Speedpassion is no longer in business.
racer1812 is offline
Old 03-19-2017 | 12:00 PM
  #5719
Figured something had to be up, however I don't think many would pay over $300 for a Reventon R.
racer1812 likes this.
Norse is offline
Old 04-03-2017 | 12:59 PM
  #5720
I had a problem with my Reventon R today and I'm wondering if anyone can help.
I have been running it with an 8.5 v3 for a while with no problems, with (I think) the mod software, and the latest versions. It was a bit slow so I figured it would be safe to run with a 7.5 today, changed out over the weekend.
The car tested fine and ran ok for a couple of minutes, but got stuck in the long grass. I tried forwards and reverse a couple of times and then went to inspect it. My brother noticed some smoke and there was no drive (though the BEC was still working as the steering was fine). I quickly took the shell off, unplugged it, smoke seemed to have come from the speed controller though there were no real signs of singing etc on it.
I gave it a few minutes and tried it again, shell off, it gave drive for about 10 seconds then drive shut off. I'm pretty sure I've killed my Reventon R at this point but I'm quite surprised - it's not boosted or turbo much I think (while since I looked at the settings) and it's specced to 5.5t? (though higher for hybrid boost, I realise, which I may have been running but don't think so).
Is there any way I can bring this speedo back from the dead or should I bin it? I have the programming card so I could try and default it and reload the firmware that way, but I suspect the smoke indicates this won't help much.
I'm quite disappointed, I only went down one turn, and it still wasn't going much quicker. Compared to the 7.5 I was running (for a min or two), the Novak GTB and 6.5 combo in my other B4 is much faster, even with a smaller pinion. Talking pinions, I didn't change that, might have pushed it a bit with 24 @ 81 spur and 2.6 gearbox ratio. It was within a tooth or two of what others were running though (mainly 23/78 from what I can gather) so it should have been fine.
Anyone revived a Reventon R in this condition? I noticed when the drive went, pushing the throttle caused the ESC cooling fan to slow down, something it didn't do when it worked. Not sure what that means.
Thanks all
Zoea
Zoea is offline
Old 05-16-2017 | 07:52 AM
  #5721
Stock Club Race ESC. Hi all, I'm running a Stock Club Race ESC in 21.5 and just wondering what people's experiences have been like. I find up high it's good but down low it feels really flat and down on power. I have the DRRS set all the way and it didn't make too much of a difference.
PaulC83 is offline
Old 08-25-2017 | 03:59 PM
  #5722
Im looking for anyones input on a few Speed Passion ESC i may be buying used.
First is a Speed Passion Grandturismo 2.0 and the other is a Reventon Pro 1.1.
Thanks!
Oaken81 is offline
Old 09-09-2017 | 06:21 PM
  #5723
theclutch's Avatar
Is this actually true? It wouldn't seem so since the Speed Passion website is still up with what appears to be many new products. Also, the speedpowerrc website is still up. However, I've been trying to get service for my ESC (see pic) and haven't gotten a follow-up reply after they initially replied within 1 day! I love the ESC but if they're out of business, I'll get a different ESC.
theclutch is offline
Old 09-09-2017 | 08:02 PM
  #5724
theclutch's Avatar
Guys! Heads up! They are having a 25% off sale for a specific color of the Reventon Pro 1.1 for $90!!!
Old 09-10-2017 | 08:14 AM
  #5725
I think they're still in business but seems they've been having a lot of trouble... they do seem to have a new website up now (speedpassion.org rather than the old .net domain), though their last FB post is from June. So it's hard to say what's going on with them exactly.
That aside, I've been getting gray hairs with my Reventon 1.1 for a while now. First it seemed to have some sort of short circuit (maybe from moisture?), causing the external capacitor to become extremely hot, causing even the shrink wrap to undo itself and there was some traces of smoke. The main unit did get hot too. I'm not sure if the capacitors themselves burned, though I've now swapped in a single higher-capacity 10V capacitor (as I don't use higher than 2S batteries) just in case. Opening the main unit's case, at least the underside of the chip board showed no signs of burning. And it does still work, I've driven through at least 10 packs since.
But other than that, for a while there I was worried it was falling apart again because of very erratic behavior such as spastic reversing.. well, turns out it was just the sensor wire. Seriously, can't anyone make a durable sensor wire? Second broken one in a short while. I'm surprised/relieved I didn't burn out the ESC or the motor while I was diagnosing the problems, due to odd behavior suddenly causing the motor to run at high speeds while not installed in a car (thus free-revving, a few times even with no sensor wire installed, which was odd because it was calibrated after removing the wire).
At least one slight problem still remains. I've had this ESC for nearly three years but haven't noticed this before until recently so I'm not sure what is causing it now - it seems the ESC is causing motors to run faster backwards than forwards. Even when I had set the reverse to 70%, reverse revved up very high, at least as high as full forward throttle. I now have it at 10%.
From googling up others with similar issues the suggestions usually involve reversing a channel on the transmitter or whatever, but that doesn't work, and besides the motor's rotation is correct. There's the transmitter EPA settings which can be used to tone down reverse further, but I'm not sure about boosting the forward throttle to match. Would simply pushing the forward EPA past 100% cause more actual maximum forward throttle? It doesn't seem logical that it would but I guess there's some reason to be able to push it past 100%. As said right now it's not installed in any car and I'm not comfortable free-revving full throttle even with the sensor cable installed to try it out.
tvih is offline
Old 10-06-2017 | 02:15 PM
  #5726
Finally got around to taking apart my 3.0 7.5t motor, as it was looking quite dirty and whatnot. Seems like I'll need to get some spare bearings before the next outdoor season. The front bearing still seems pretty decent, but the rear one sounds very gritty and doesn't free-spin all that well, not likely to go away with just further cleaning. I'm actually not sure why the rear bearing is "exposed" like that, it just gathers unnecessary dirt that way. Once I change the bearing I reckon I'm gonna fashion something to plug the rear "bearing well" from the outside.
I also recently noticed while removing the pinion from it that while I can't see anything "wrong" with my plain eyes on the rotor shaft near the end where the pinion was, there's definitely some irregularities (grooves or something) that have formed because it's very hard to get the pinion off and back on. And now I couldn't get the front of the motor free of the shaft because the bearing gets stuck near the end of the shaft, and I didn't want to risk breaking the bearing just yet. I even tried sanding the shaft lightly, with no effect yet.
tvih is offline
Old 10-15-2017 | 03:20 AM
  #5727
Hi guys! Im looking for ESC/motor combo for Xray xB2D, want to race carpet in winter but mainly on dirt for summer season. On RCMART, i just found the Reventon Pro 1.1 and Competetion V3 motor combo ridiculously cheap. Are these good for this category? (1/10 2WD buggy)
I race 1/8 buggy (xb8e) and 1/14 minis (lc racing), never ran an 1/10 vehicle, so apologies for my ignorance. Originally I wanted to buy the blinky hobbywing combo, but then I found out my local 1/10 indoor/outdoor track does NOT have any novice/stock classes, the only restriction they have is 2S lipo and 540 motor, so I should buy something really fast and try keep up with those freaks. 8.5R maybe?
And one more maybe stupid question, why do some speed passion motors have holes in covering and others dont? At least on motor images.
tekayi is offline
Old 10-15-2017 | 05:20 AM
  #5728
Despite my minor woes above it's a good combo for 1/10 2WD buggy, yeah. Power-wise the ESC is even way overkill, but of course better overkill than underpowered! I have 7.5 and 9.5 SP motors, with the latter being in my B5M buggy currently. It's definitely not too fast with it, so 8.5 should be fine. Actually I originally got a 8.5, but due to uh, various circumstances ended up with the 7.5 which was too much for the tiny indoor track I was driving at the time. Didn't drive there much longer though and now at the outdoor track I use the 9.5, which is mostly fine but if you have longer straights then the extra speed from the 8.5 would come in handy for sure.
Personally I like the 3.5mm plug system in the SP motors compared to the soldering tabs found in most motors, but your mileage may vary. And as for the holes in covering, I'm not really sure. I guess it's some change made in design during the lifetime of the product. My 7.5 bought in late 2014 doesn't have the ventilation holes, but the 9.5 I bought this summer does despite both being of the same 3.0 line of motors.
tvih is offline
Old 01-29-2018 | 09:55 AM
  #5729
Whoever need to download the latest firmware here is the link from dropbox
https://www.dropbox.com/s/rbw4vq35l1..._0_25.zip?dl=0
Solara is offline
Old 01-29-2018 | 09:14 PM
  #5730
SlowGuySam's Avatar
Well went to both the old and new websites and it doesn’t look good. Both are dead sites. Facebook page is outdated as well. Anyone have word if there is life in them or down for the count.
SlowGuySam is offline
