Speed Passion Thread
#5687
A lot of guys around here are using V4 4.5s and 5.5s for onroad too
#5689
Along those lines, I use a Futaba 4PKS -
the EPA goes to 120, so for calibration, do you push the setting to the Max and then back it down from there? since "Technically" 100 isn't Max, 120 is?
The Stock Spec Firmware is made so it can't be modified, so the Club Spec ESC like others, come "Hardwired" with a set firmware. Otherwise it defeats the purpose of a Spec status. All the other versions, S, R Pro Etc can be modified with a FIRMWARE change.
MOmo
#5691
My Esc fan on the reventon pro 1.1 has finally died after six months of light use
Is it okay not running one in 4wd mod buggy
Just mounted a spare 30mm yeah racing fan.. Should do the job.
#5693
#5694
#5695
I race dirt oval in a class that specifies we run the speed passion club race esc and the recent ion 17.5 motor with a 10 degree fixed end bell. Well everywhere I look it's back ordered. So I may pick up a regular esc/motor kit and put the end bell on separate. I see now they have a new mmm revention motor but it's an 11-20 degree motor. Could I take this version and put a 10 end bell on and be better off than the regular ole 3.0 with having to buy an end bell? Says the new mmm is better and lighter but not sure if I can get/find the end bell for it to make it 10 degree. Thank
Doug
Doug
#5697
#5700
The New Speed Passion Competition V3.0 MMM motor series has the following features:
A. Totally redesigned motor front plate and rear motor end bell.
Totally new design and stronger material motor front plate and rear end bell ready for the most extreme condition.
B. The new and reinforced timing sensor unit
4Likes
