Speed Passion Thread
#4366
Is there a chart for what each rotor is and what it provides? Just curious if changing rotors would do anything for my 17.5 3.0 and if it would, what rotor would be better.
Also, what is a good replacement for the power switch on the stock club race esc? I found mine to be causing my problem of the cutout.
#4367
That's a good question, i did some research on that as well... and coming across some older posts, it does not seem to me like people noticed any differences at all to swapping out to different rotors. In fact i think some people said it actually hurt them in some instances. Anyone?
#4368
I noticed a lot more torque going from 12.3 to the 12.5mm rotor in 17.5 MMM I have. It was exactly what I needed to take the A main win against a field of modified running vehicles in the 2wd open class. some guys were even running 4 pole motors and they were comparable drivers.
I sourced a super 7 rotor at the time. These seem hard to get.
#4369
Not sure this has been answered here, but I just bought the cheepo set up: Revention S with Competition Motor V3.0S 3500KV combo.
I'm not a racer, so I guess I am a basher: RC10T4.2
Does anyone know how this engine performs? Tunig recommendations? I am just about to do setup and I am hoping it will be fast and strong enough for the goofin' around that I do.
Any feedback?
Any feedback?
#4374
I see that the GranTrusimo LPF v2.0 are on sale at Speedpower. Is there are reason they are so heavily discounted? I own a Reventon R right now. Would buying one of the sale GT's be a downgrade or just old model? I race modified SCT and 2wd buggy.
#4375
#4377
i noticed the temps slightly higher also, for the V3 i was at mid 90s and the MMM is low 100s. ESC is at 88-95* either motor without fan. Ambient temps are in the low 60s. A local sponsored Kyosho driver took my car for a spin and was off 0.4sec a lap to the RB6 with D3.5 he just drove. Said he could tell the power was lower so I'm looking to try more timing. And I'm working on getting more corner speed, but that's for another thread.
#4379
2 Pole or 4 pole. Last word I saw here was if you don't use timing (no timing blinky software at least works well for the GT2.0 Pro), etc the 4 pole 540s will work. Not sure if they have commented on a 550 4 pole but if the ESC is at all robust as the GT2.0 Pros I would think you use proper current limiting (DRRS Value) that could work.
For the GT2.0 Pro in comparison with a 550 4 pole motor I used DRRS value of 3. 540 4 pole I was at about DRRS 7.
probably cause its old stock.
In modified, if you don't need boost, etc. then I feel the GT2.0 and GT2.1 s are great escs for the money. Very versatile, especially the GT2.0 Pro.
#4380
4Likes
