Speed Passion Thread >
Like Tree4Likes
Old 01-01-2014 | 09:39 PM
  #4246
Guest
Had another good night at the track with revention pro power sc10.2 ft . But tonight I tryed the stock with hypbred boost and took it out in the 2nd heat, back to mod 2
I guess our carpet track is not big enough for the power!!!!!
kyoshoracer77 is offline
Old 01-02-2014 | 06:31 AM
  #4247
mjk1210's Avatar
lol. the hybrid boost can definitely make it rip. but you can also set it up so it is much less aggressive. use the lowest setting (40%), one of the lower settings for the max RPM 125k?, use 3 or maybe 6 for the slope (this makes the boost come in much softer)
mjk1210 is offline
Old 01-02-2014 | 08:55 AM
  #4248
Originally Posted by Scargoes
heat and voltage protection is enabled. I have been running a 4300mah 60c 2s and get an easy 30 minutes of run time. This is not lvc coming on. Ambient temps have been around 60f and measured temps of the motor have been mid 90s and the ESC is high 80s without the fan.
This might sound basic, but double check your connection on the motor. Maybe one of the female bullets coming from the ESC is loose on the motor.
There were a few posts with that issues awhile back.
Nexus is offline
Old 01-02-2014 | 10:33 AM
  #4249
I have been checking the connectors and even looking at the external solder joints on the ESC board. I'm down to it being either a bad switch or the ESC is faulting out internally (bad solder joint on the board?). I'm going to make a jumper plug to eliminate the switch. Unless you know of some reason the factory switch needs to be there??? The ESC should power up without a signal/button wire correct?
Scargoes is offline
Old 01-02-2014 | 01:05 PM
  #4250
Autocratic's Avatar
Who's running the Blaze motor in a heavy short course? Is it working well?
Autocratic is offline
Old 01-02-2014 | 07:00 PM
  #4251
Dependability............that's what I am looking for. Give me some feedback on the speed passion product. I am looking at a Reventon pro 1.1 combo probably a 7.5 or 8.5 for my 44.2............
Ssilverfz1 is offline
Old 01-02-2014 | 07:10 PM
  #4252
Cain's Avatar
Tech Legend
me personally, there GT2.0 Pro was the most dependable esc I have had. If you want something dependable on the cheap, I would give that one a vote.
Cain is offline
Old 01-02-2014 | 07:22 PM
  #4253
Does someone know if you can add a sensor endplate on the 1/8 Blaze sensorless motors? Some esc's only run sensored motors.
Raul Garcia is online now
Old 01-02-2014 | 08:55 PM
  #4254
I am having problems with my replacement revention pro 1.1. The first one had problems from the start and speed passion replaced it and the motor. Just installed the new one and I am having the same issues. The orange light is on but the red is blinking. This is a fresh pack and just testing it on the stand. Solder connections look good. Unit wires and motor are getting warm after 20 seconds running on the stand.
Any suggestions. I will call speed passion again in the am. I also disabled low voltage and thermal
Chriscamp is offline
  #4255
Any suggestions. I will call speed passion again in the am. I also disabled low voltage and thermal.
Old 01-02-2014 | 09:49 PM
  #4256
Guest
i will have the blaze 4700kv in a tekno eb48 at the end of the month on 2s, we r running on a indoor carpet track.
Old 01-02-2014 | 09:53 PM
  #4257
Guest
I ran a revention pro combo/ 7.5 with no problems
19-20 pinion 78 spur on a small tight track.
mod 2
Old 01-03-2014 | 02:02 AM
  #4258
Guest
Default program boxes????
OK guys I got 3 speed passion controls, 2 revention pro and my sons new revention r can I use 1 program to program the revention pro and 1 for the revention r, or do I got to use all three program boxes?
Old 01-03-2014 | 03:56 AM
  #4259
You can use one LCD card that came with the Pro for all 3.
kwiksi is offline
Old 01-03-2014 | 06:33 AM
  #4260
Cain's Avatar
Tech Legend
hopefully speed passion in the future makes the Kvs available in sensorless config in sensored mode as well. the Kvs for those 1/8 motors are more practical.
Cain is offline
