Speed Passion Thread >
Like Tree4Likes
Old 01-03-2014 | 07:54 AM
  #4261
chillindrdude's Avatar
do you know if i can use the GT Pro 2.0 esc with a brushed 35T motor in my crawler?
chillindrdude is offline
Old 01-03-2014 | 08:47 AM
  #4262
Wink
Originally Posted by Chriscamp
I am having problems with my replacement revention pro 1.1. The first one had problems from the start and speed passion replaced it and the motor. Just installed the new one and I am having the same issues. The orange light is on but the red is blinking. This is a fresh pack and just testing it on the stand. Solder connections look good. Unit wires and motor are getting warm after 20 seconds running on the stand.
Any suggestions. I will call speed passion again in the am. I also disabled low voltage and thermal
I called speed passion and they are sending out a new esc today. I am impressed with the response speed!
Chriscamp is offline
Old 01-03-2014 | 09:34 AM
  #4263
The GT Pro 2.0 only supports "brushless" motors.
Nexus is offline
Old 01-04-2014 | 09:14 AM
  #4264
askbob's Avatar
Double post.
askbob is offline
  #4265
askbob's Avatar
Searched a bit without finding an answer.
What is the hottest firmware to use on the Reventon S?
Same question for the Reventon Pro using a 10.5 in 2wd buggy? Tried one of the Mod versions, but it seems it may be better using the on of the Stock versions to use the boost functions.
askbob is offline
Old 01-04-2014 | 09:22 AM
  #4266
thisismyusrname's Avatar
Hey guys, I'm desperately looking for the programmer card for the cirtix series esc, i have the stock club race esc so I can't use the USB programmer. If anyone has one they're willing to part with, please send me a PM
Cant find one in stock anywhere!
thisismyusrname is offline
Old 01-04-2014 | 12:24 PM
  #4267
MOmo's Avatar
You should be able to use the programer, you just cant update software or tune off blinky afaik.
I want to say I was able to change my drag brake and punch from the box.
Momo
MOmo is offline
Old 01-04-2014 | 03:30 PM
  #4268
FMLinero's Avatar
Default Reventon PRO 1.1 with 8.5R motor
Hello,
I bought this combo new and I put it together today. However, the motor does not spin. The steering servo works fine. I calibrated the radio/ESC many times but the motor does not spin. I tried a different sensor cable and rx cable. Any ideas. Thank you
I have a radiopost TX and RX.
FMLinero is offline
Old 01-04-2014 | 06:59 PM
  #4269
Autocratic's Avatar
Originally Posted by FMLinero
Hello,
Double check your motor wires and make sure you're calibrating in the right order. If you can, see if the motor will run on someone else's ESC to make sure the motor is fine.
Autocratic is offline
Old 01-04-2014 | 07:04 PM
  #4270
Autocratic's Avatar
Hello,
Old 01-04-2014 | 07:48 PM
  #4271
Kremzeek's Avatar
Ugh.. I forgot how short the sensor cable is that comes with the Reventon R. Gonna have to brave the cold weather and see if my LHS has a longer one.
I'd order one from Speed Power but they don't have them in stock.
Kremzeek is offline
Old 01-04-2014 | 10:52 PM
  #4272
the incubus's Avatar
I just got 2 Pro 1.1's last weekend and installed them both. one was perfect and the other did this very same thing. So I dropped my car on my table and it lurched forward so I grabbed it and tried the throttle and it did nothing so I held down the throttle and smacked the car on my knee and it kicked on.
Seems something was loose inside from factory. My buddy is their local rep so he simply swapped me out for another one which was perfect and sent the bad one back for evaluation/replacement.
I've had nothing but excellent experiences with Speed Passion products outside the single ESC and their Motors are also top notch. Just wish they'd place the plugs all on the same side so the wires all reside together for a slightly cleaner look. All in all, still the nicest and cleanest motor installs I've seen.
the incubus is offline
  #4273
Old 01-05-2014 | 12:10 AM
  #4274
Guest
3 inch sensor wire kinda sucks but it does work in like b44.2 or maybe my new tekno buggy when I get it!!!!.if not Smc racing makes or has different size wires.
kyoshoracer77 is offline
Old 01-05-2014 | 12:15 AM
  #4275
Guest
Same here, I have had good luck out of the 2 revention pros and the revention r for my son. I can't wait to see if my revention pro handles the 4600kv 550 can corr motor in my buggy that will truly impress me!!!
