Speed Passion Thread >
Like Tree4Likes
Old 07-10-2014 | 03:51 AM
  #5011
Originally Posted by 3edc
i have a speed passion that i just got but when i did the calibration in the beginning you push the trigger the full brake but when i use the car it has no brakes to stop the car so can you guys help me to figure out what i did wrong or something tanks for reading
What model Speed Passion, and what are the current settings? New or used?
Dave H is offline
Old 07-10-2014 | 04:06 AM
  #5012
rraden's Avatar
What's the difference between the Reventon Pro 1.1 EX and the Hirosaka version? Name only? Or something else?
rraden is offline
Old 07-18-2014 | 08:03 PM
  #5013
JDM_DOHC_SiR's Avatar
Exclamation BLINKY MOD without Brakes... Ain't gotz no time for dat'
Man what is up with the Stock0 Profile and having jack squat for brakes!!... I feels as if the car hardly wants to stop... but then I load Stock1 and it's very different and your able to stop the car much better...
Is there going to be an update to the Firmware that fixes the BS issue
Speed Passion.. PLEASE FIX THIS!! for us Blinky users of the Revention series ESC's
JDM_DOHC_SiR is offline
Old 07-18-2014 | 08:53 PM
  #5014
SlowGuySam's Avatar
JDM good luck. I bought 3 different versions of the reventon line (stock, R, and pro) and never found brakes. And from what I was told awhile back they wont be updating stock0 for a while. For me it was the same, great brakes in other profiles but cant stop in stock. ended switching to another esc which sucks b/c I like the SP stuff and now have 3 sitting around.
SlowGuySam is offline
Old 07-18-2014 | 09:51 PM
  #5015
Sucks...
Oh well I guess this will be using the ESC for 13.5 boosted then
Old 07-19-2014 | 04:00 AM
  #5016
For guys having trouble with the brakes in Stock0. Has anyone tried running the Muchmore software and try their blinky profile? I have not, but it might be worth a try since the hardware is the same.
http://www.petitrc.com/reglages/spee...eSoftware/eng/
kwiksi is offline
Old 07-19-2014 | 04:22 AM
  #5017
rraden's Avatar
Anyone know the answer to my question? Thanks
rraden is offline
Old 07-19-2014 | 08:10 AM
  #5018
Hmmmm.. might give it a try
Old 07-26-2014 | 10:30 AM
  #5019
Default Speed Passion Reventon Tips?
Hey guys, I've got a Speed Passion Reventon 10.5 that i'm running in my 1/10th scale buggy. As of now it's set to stock out of the box. I'm wanting to know what should I change in the program card to make it better. I'd like to have more motor out of the hole. & any other ideas that will help it out. Any help is very much appreciated! TP
Tyler Price is offline
Old 07-26-2014 | 05:03 PM
  #5020
Download the latest software and upgrade the LCD (link below). Then I would recommend MOD2 software. Which is made for offroad. They come preloaded with MOD1 which is a bit more aggressive for Onroad. I don't recommend boost or turbo as it will be hard to drive in the dirt. What you want is smooth throttle profile (MOD2). If you can put the power down you can go up in timing on motor and or speedo settings as well as play with gearing while watching temps.
http://www.speedpassion.net/us/produ...SP000739&c=ESC
kwiksi is offline
Old 07-28-2014 | 09:33 AM
  #5021
Thank you!
Old 07-28-2014 | 11:37 AM
  #5022
I have my B5R on Stock0 for blinky, and with the LCD box had good brakes, turned them up, seamed to high, settign is at 3 on my car, and can still lock up to turn a corner if need be. Running a rev r and a lrp 17.5. bought new in February.
ALIEN3T is offline
Old 07-28-2014 | 05:23 PM
  #5023
What setting is at 3? Can you post your speedo set up sheet or settings?
Def don't want lock up. Don't forget you have the epa on your trans as well as speedo to play with. Mine are set on 60% on either more or less. Using the epa for on track on the fly adjustments.
kwiksi is offline
Old 07-28-2014 | 07:18 PM
  #5024
Thumbs up
You must be the only guy with brakes on a Stock0 program... I can hardly get the buggy to stop with that setting....
So you have loaded it up via the CPU and then your using the LCD programmer to dial in the brakes?? please let us know if you can
THIS...
Old 07-28-2014 | 09:54 PM
  #5025
DJ_KILROY's Avatar
Default New esc case
Hi All,
Can anyone point me in the right direction to purchase new cases for my speedpassion speed controls
I need a lower case for a Reventon Pro (First version) and 2 complete cases for the GT2 pro.
David
DJ_KILROY is offline
