Speed Passion Thread >
Like Tree4Likes
Old 07-06-2014 | 11:58 AM
  #4996
Originally Posted by idrummerboy13
the timing which im not sure how to change is set to 10 degrees on the motor. Maybe ill plug what is in the esc into the program card, if I flip it the controller doesnt turn on. Its a brand new unit btw
OK cool.
Originally Posted by 13Maschine
@nexus: Frustrating response to be honest. Unfortunately pretty much what I expected. Almost all of the emails I've written to Speed Passion have been replied to with little to no actual answers. I have had to write several times to get the same questions answered. Would you at least tell us what your official speed passion position is? I'd like to know before I spend the time chasing you down over the phone only to find out you can't help because you aren't the correct person to speak with in this regard.
13. Its a public forum and I'm on here just like you...a fan and customer of RC racing. Officially yes I do work with Speed Passion and carry different responsibilities. My job title isn't necessarily tech support, but myself, Howard and a few others come on here to try and answer what we can.
If you have called Speed Passion you can ( or anyone) hit ext 107. That would go directly to me. I'll work with you on resolving any issues.
Nexus is offline
Old 07-06-2014 | 01:00 PM
  #4997
both websites are up as of this morning when I checked
-rcsteve715
rcsteve715 is offline
Old 07-06-2014 | 02:02 PM
  #4998
13Maschine's Avatar
Is this the correct phone number to call? I've copied this from the website:
NORTH AMERICAN SALES AND SUPPORT
Email [email protected]
Phone 1-888-928-1328
13Maschine is offline
Old 07-06-2014 | 07:10 PM
  #4999
idrummerboy13's Avatar
Originally Posted by Nexus
OK cool.
no luck. I think my unit is defective. flipping the wires did nothing. All the connections are tight. Radio is calibrated...idk
idrummerboy13 is offline
Old 07-06-2014 | 11:17 PM
  #5000
Default GT2.0 LPF ESC for SC10 4x4
I was told that I could use the GT2.0 LPF with my SC10 4x4 is this correct? I currently own two GT2.1 Pro Stock ESCs, B4.1/T4.2, that I love. I have a GT2.0LPF that I would like to pair with the Blaze 4600kv or 5700kv motor to run open 4wd SC at our local track. Any input or help would be much appreciated.
Jade67 is offline
Old 07-07-2014 | 01:19 AM
  #5001
MOmo's Avatar
I think the gt2.0 is favored over the lpf.
on a side note, I managed to resolve my issue and will try and write a detailed explanation to try and help others that might have the same struggles.
Momo
MOmo is offline
Old 07-07-2014 | 02:50 AM
  #5002
mjk1210's Avatar
Momo
I believe you meant to say the GT2.0 PRO is favored over the LPF. both are GT2.0 series speed controls.
mjk1210 is offline
Old 07-07-2014 | 11:47 AM
  #5003
MOmo's Avatar
Correct. GT2.0 Pro model.
Since ive updated to the reventon in my buggies, I m7ght try this in my converted Rc8 sc.
looking at 550 motor options.
Momo
MOmo is offline
Old 07-07-2014 | 01:09 PM
  #5004
Momo
Momo I would suggest not doing it. The Sc8 is extremely heavy even with the 550 motor. You'll smoke a esc for sure.
Raul Garcia is offline
Old 07-09-2014 | 02:37 PM
  #5005
MOmo's Avatar
A couple folks have said they were using the GT2.0 ESC in their 4x4 SC, and it seemed as though they said it was Losi or maybe Tekno. None the less, it seemed like it was more 8th scale based, partly why I was considering it. I had planned to pair it with a 550 sized motors. Perhaps I will hold off.
As I posted earlier I was having trouble getting the software to work.
I realized that its important to read the steps carefully and make sure you follow them exactly and in my case, I overlooked a crucial step that may have been the culprit.
1) Download the latest software version from SpeedPassion.net (Obviously)
http://www.speedpassion.net/us/download.asp
*You will need to "extract" or "Unzip" the compressed file,
so its best to have a utility that can do so. (I Used WinRar).
(It should generate or create a SPEEDPASSION folder, or you can create a specific folder in which you extract, the software however WILL generate a SP Program folder for the actual Program itself. I like making a separate folder to keep track of the specific updates.)
2) Once the file "Unzips" it creates Separate files. (Prog, PDF, and importantly the USB Driver update- More about this later)
3) Select the SETUP software and install the REVENTON Program.
4) Once complete, Install the SP-USB Driver program.
*Note that while all this is going on, the LED/LCD Box remains Disconnected*
5) **You will then need to RE-BOOT the computer.**
6) This is where you pay attention....
-Now connect the USB Cable to the LCD/LED Box
BUT NOT THE COMPUTER!!
-Hold the RESET Button- 2nd button from right
-Connect the Other end of the USB cable Into the Computer
-Once the cable is connected, then release the RESET button
-Now- Select the REVENTON Software and open it.
(This is where I think I was messing up in that it was open initially and I didn't Re-boot after the USBdriver installed.)
*Your computer may also run a 2nd USB driver install, for "Found New Hardware" *
-On the left side, you should see the "tab" or option for the FIRMWARE update
-Select the desired Firmware option *This can take a few Minutes*
*MAKE SURE THE ESC IS NOT CONNECTED!!!*
7) It should prompt after its complete
8) *I would re-boot again, JUST to be safe*
9) After the reboot, Open the Reventon software- connect the USB cord and the LCD device. Then connect the ESC to the device, remembering to disconnect the Fan. It should open the software allowing you to modify and recognize the ESC. Then you can select and update the ESC with the various Profiles- Mod1, 2, drift, stock, etc.
I hope this helps some folk. It DOES explain this in the manual, but for me, I wasn't re-booting and I ended up getting 2 different USB Driver install Prompts, one from the software, an another from the computer. *You may have to run both.*
I managed to get mine to work and get the software to work with the ESCs.
MOmo
MOmo is offline
Old 07-09-2014 | 11:42 PM
  #5006
Exclamation brake problems
i have a speed passion that i just got but when i did the calibration in the beginning you push the trigger the full brake but when i use the car it has no brakes to stop the car so can you guys help me to figure out what i did wrong or something tanks for reading
3edc is offline
Old 07-10-2014 | 12:01 AM
  #5007
R/C Tech Elite Member
Actually you have to calibrate for full throttle, full brake, and neutral point.
Did you calibrate all 3 points?
Fixmy59bug is offline
Old 07-10-2014 | 12:16 AM
  #5008
tom76's Avatar
What turn motor are you using?
tom76 is offline
Old 07-10-2014 | 12:42 AM
  #5009
yes i did
3edc is offline
Old 07-10-2014 | 12:56 AM
  #5010
What is your endpoint set at right for brake.
Pat863 is offline
