Speed Passion Thread >
Like Tree4Likes
Old 11-29-2012 | 08:34 AM
  #2356
AlanHall's Avatar
Im confused about the stock vs mod software. They dont see much different. Is it just different boost/timing setup? Trying to understand why they run stock1 in 4wd SC
AlanHall is offline
Old 11-29-2012 | 09:05 AM
  #2357
Originally Posted by dMITIj
So if i look at your setup section: http://www.speedpassion.net/en/escsetup.asp?t=6
i can't see Jorn's setup for 4wd? only the old once.
i have asked for 4wd Reventon Pro setup before and nothing happend? maby i look the wrong place?
Best Regards.
Check now...under 4WD off road...it is very similar to 2WD just with minor motor setup.
Solara is offline
Old 11-29-2012 | 09:09 AM
  #2358
Because these SCT are heavy as brick.....LOL
Yes, all SCT 4x4 I see....all run boost = STOCK1.
Mod software is more for 2WD and 4WD buggy as adding BOOST on them will not make it better to drive....not unless you have a track that is like a size of a NFL football field. Mod software only gives you static timing...a static curve increase of timing...STOCK1 will give you the shifting, dynamic and custom setting of the timing increase plus the BOOST (Turbo when it is WOT).
You will not see much of a different IF your track is small....but once it is bigger, the different is more obvious.
Solara is offline
Old 11-29-2012 | 09:24 AM
  #2359
AlanHall's Avatar
Oh ok. So your saying stock settings are more tunable and the mod settings are more just blasts of power? Im i understanding correct?
AlanHall is offline
Old 11-29-2012 | 09:26 AM
  #2360
Cain's Avatar
Tech Legend
Solara: So what is the issue I would run into trying to use the Reventon Pro with a 4 Pole motor? Does it run inconsistently, not at all, etc?
I am curious to see how much more punch the blaze 2 Pole has than what we are seeing for 4 pole motors. How large is the rotor on it?
Cain is offline
Old 11-29-2012 | 10:29 AM
  #2361
Originally Posted by Solara
Silver Arrow is for 3-4 cells use....for 1/8th E buggy, no reason to use that ESC on 2S powered SCT 4x4.
I got the SAII for the Durango 1/8th buggy, the DEX408.
Snafujg is offline
Old 11-29-2012 | 10:40 AM
  #2362
Cain's Avatar
Tech Legend
what happens if you do try to use it on 2S? Does it not power on or act erractically?
Cain is offline
Old 11-29-2012 | 10:54 AM
  #2363
I haven't even tried that as I knew when I bought it that it was for 3-4S.
Snafujg is offline
Old 11-29-2012 | 11:16 AM
  #2364
atatro's Avatar
I have a gt2.0 pro that needs the switch fixed. Will speed passion fix this for me?
atatro is offline
Old 11-29-2012 | 11:35 AM
  #2365
tom2tone's Avatar
R/C Tech Elite Member
Originally Posted by tom2tone
Hey guys.. I was digging through my stuff and found this... SP V1 Silverarrow combo with lcd card. Still sealed and never used. Would this be worth anything?
Well I just tried to call support and I got their answering machine. I was able to find my receipt and I purchased my combo back in march of '09. Is it worth trying to see if I could get an updated combo or just pitch it?
tom2tone is offline
Old 11-29-2012 | 12:18 PM
  #2366
AlanHall's Avatar
Why would you pitch it
AlanHall is offline
Old 11-29-2012 | 01:22 PM
  #2367
RCmayor's Avatar
The motor and programming box are probably worth something either way. Probably could get 70 to 80 out of those two items at least. Better than pitching. Surely someone with an over priced Orion speedo would want the programmer for 20 bucks vs paying 80 for the Orion box. lol same thing.
RCmayor is offline
Old 11-29-2012 | 02:58 PM
  #2368
Make sure you have ALBERT to ship you a new caps...may be one or 2...you tell him HOWARD tell you to call him...thanks for sticking with SPEED PASSION
Howard
How do we know if we got the old or new style caps with the Reventon Pro?
AlderBoy is offline
Old 11-29-2012 | 04:50 PM
  #2369
tom2tone's Avatar
I would rather not just throw it away but I have no idea what it's worth. I have no use for it and would rather get a few bucks for it. I'm going to try to call SP tomorrow and see where I get. Thanks guys..
tom2tone is offline
Old 11-29-2012 | 08:03 PM
  #2370
I'm new to the Speed Passion ESC and I have a LPF 2.0 GT in my losi 22 with an orion vst 17.5t motor. Tonight was the first night I've run it so I was rather impressed the first few laps then all of a sudden it started running at about 1/2 power. Took it off the track and checked things and pulled the throttle and it seemed to run fine. Did a couple more laps and it went into limp mode again.
Battery pack was charged but I tried a different one to make sure and it did the same thing with that pack. The batteries are GenAce 30C 4000 mah 7.4V.
I have a programming card on the way and was wondering if there is a setting that needs to be adjusted. I got the speed control used and all I could do is program it to my throttle.
Please help?
bobsavenger is offline
