Speed Passion Thread >
Like Tree4Likes
Old 11-27-2012 | 04:40 PM
  #2326
Originally Posted by flame56mx
No fan is plugged in, it works with both the LED, and LCD directly using battery, fan spins lights and all that, it just will not connect to the PC interface..
Gotcha.
Disconnect the fan then connect everything back up.
When you connect your PC + LCD + ESC there should be not battery or fans connected. (Reventon ESCs)
Nexus is offline
Old 11-27-2012 | 05:08 PM
  #2327
R/C Tech Elite Member
Originally Posted by Nexus
Gotcha.
Right, I read that is a bad thing, Pc's are not lipo compatible..lol. I'll try disconnecting the fan, and give it another try..
flame56mx is offline
Old 11-27-2012 | 05:12 PM
  #2328
Boom, you nailed it Nexus, it works with the LED, and LCD Pc interface..Thanks man....
Old 11-27-2012 | 05:19 PM
  #2329
No problem.
There is supposed to be an updated instruction manual or an addendum coming out that notes that the fan and the battery should not be plugged in when connecting Reventon ESCs to your PC.
Enjoy
I've run the R in buggy and SC and it runs awesome.
Nexus is offline
Old 11-27-2012 | 05:32 PM
  #2330
The Pro's manual tells you to unplug the fan and only plug the lipo in when using the box only.
SRW141 is offline
Old 11-27-2012 | 06:01 PM
  #2331
What's a manual? j/k. I admit, I am "that guy" that didnt read the manual.. I have been running another brand esc for years, but I decided to try something different, and didnt really give myself enough time to learn the ropes..Thanks for the help, lesson learned..
Old 11-28-2012 | 02:32 AM
  #2332
Hyper Sean's Avatar
Hi. Just bought the 5.5t and the reinvention pro combo for my dex410v3 after having no luck with my new hobbywing v3. I run on a high grip carpet track. Was running 6.5 tekin redline with not to many issues. But now were coming in to summer and I'm finding the hw v3 is getting hot. Well this combo be ok our should I keep using the 6.5. Any help would be greatly appreciated. Cheers
Hyper Sean is offline
Old 11-28-2012 | 04:55 AM
  #2333
Stanfsu's Avatar
What program box will work on the Silver Arrow ESC (1/8)? Will the Professional LCD Program Box (SPLCD01) work? Is it worth to get one?
Stanfsu is offline
Old 11-28-2012 | 08:31 AM
  #2334
tazfam2's Avatar
Originally Posted by manuelargentina
So Reventon Pro will not work on 4 pole motors? What esc should I use on 550, 4 pole motor??
Have my short course almost ready to run but I'll keep waiting for some response here...
Regards
Don't use a 4 pole will run for a while the boom done will burn up the speedo
tazfam2 is offline
Old 11-28-2012 | 08:35 AM
  #2335
tazfam2's Avatar
[QUOTE=Stanfsu;11491073]What program box will work on the Silver Arrow ESC (1/8)? Will the Professional LCD Program Box (SPLCD01) work? Is it worth to get one?[gt/QUOTE]
the old one from the gt 2.0
tazfam2 is offline
Old 11-28-2012 | 08:50 AM
  #2336
Jorn Neumann used the REVENTON PRO with 5.5 motor at the 1st round of the ETS carpet track...you can see the setup on our website. Using the new MOD2 software....and yes, he ran the same car as yours.
Solara is offline
Old 11-28-2012 | 09:03 AM
  #2337
Cain's Avatar
Tech Legend
Solara: can you confirm if the Reventon Pro can handle 540 and 550 Pro4 motors?
Cain is offline
Old 11-28-2012 | 09:24 AM
  #2338
540 550 are the motor size...(diameter and length)....has nothing to do with the pole...
PRO4...is the name right..? It is from TEKIN, right..?
And Pro 4...is a 4 pole motor, right...?
If that is the case....NO, right now, Reventon Software will not work with any 4 poles motors. But we are testing the new BLAZE motor, which is 2 poles but in 550 size and 5mm shaft....so far, it is the best motor that I can see for 4x4 SCT.
And still....I want to know....WHY 4 poles motor..? does 4 poles motor is any faster? More torque..? Lighter...? Why 4 poles?
Solara is offline
Old 11-28-2012 | 10:21 AM
  #2339
Cain's Avatar
Tech Legend
From what I have experienced going from tekin's 550 2 Pole motor to there 540 4 Pole motor, similar Kv's, the 4 Pole felt like it had a lot more torque than the 550 2 Pole. it ran slightly cooler as well from what I can tell.
From what I have been reading from people who have the 550 4 Pole motors from other brands, they run cool and with even more power than the 550 2 Pole and 540 4 poles.
The SP GT2.0 Pro does excellent with the Tekin Pro4 motors. What about the reventon pro makes it so it doesn't work with them?
Are there plans for a Speed Passion ESC that can handle these motors and maybe double as an upgrade to the Silver Arrow V2, similar to how the Tekin RX8 can handle both areas with a somewhat reasonable size?
Cain is offline
Old 11-28-2012 | 10:47 AM
  #2340
dMITIj's Avatar
So if i look at your setup section: http://www.speedpassion.net/en/escsetup.asp?t=6
i can't see Jorn's setup for 4wd? only the old once.
i have asked for 4wd Reventon Pro setup before and nothing happend? maby i look the wrong place?
Best Regards.
dMITIj is offline
