Speed Passion Thread >
Like Tree4Likes
Old 12-07-2011 | 12:19 PM
  #826
Originally Posted by Mxer59
Bumping my question
We will have the new 1/8th "BLAZE" motor series coming out later this month early next year for all the 1/8th scale application. 2450 and 2750kv. Currently tested on Losi 8ight II and ran like 18 minutes and temp was only 120*.
Solara is offline
Old 12-07-2011 | 12:46 PM
  #827
Mxer59's Avatar
That would be nice planning on getting another buggy after x mas
Mxer59 is offline
Old 12-09-2011 | 07:40 AM
  #828
Well, lets see if anybody can help me out here, I might just be an electric noob..
I just picked up a speed passion ESC/motor (stock club race and 17.5R) and I'm having a few issues. It works and will drive forward, but only forward. I have no brake and no reverse. Every time I try configuring the throttle it just stops working entirely for a few minutes or until whenever it decides to work.
Also, it does not seem to work if I have the sensor wire connected, no matter what.
Any tips?
coxmaster is offline
Old 12-09-2011 | 09:23 PM
  #829
mrbirchum's Avatar
Does Speed Passion have any ESC that will handle a 4 turn, 4 pole motor such as the Tekin Pro4 4600? I'm trying to decide what ESC to get after frying my previous ESC the first time out with the Pro4.
mrbirchum is offline
Old 12-10-2011 | 09:30 AM
  #830
the gt 2.0 and lpf gt 2.0 both will run that motor. id go with the gt 2.0
cm.stites is offline
Old 12-10-2011 | 10:44 AM
  #831
sc10rr's Avatar
i hope the new 1/8th motors are alot better then the current line up. i have two of them and both had issue right out of the box, such as the can screws always come un done. and they run hot because they are not true 1/8 motors.
sc10rr is offline
Old 12-12-2011 | 08:51 AM
  #832
murky123's Avatar
I understood you also were testing 550 sized for short course ? right?
fit for 2s lipo ?
kv around the 3500 / 4500 ?
murky123 is offline
Old 12-12-2011 | 09:00 AM
  #833
GT2 PRO version is your only option.
Solara is offline
Old 12-12-2011 | 09:04 AM
  #834
fit for 2s lipo ?
Yes....550 SCT 4x4 version, 4600kv......Jorn Neuman testing it, he used the new BLAZE motor and TQ/WON the JConcept Clash Event on 1/8th and 4WD. He cannot use it on 4x4 because it is a prototype motor so he didn't race that event.
Solara is offline
Old 12-12-2011 | 09:35 AM
  #835
murky123's Avatar
only a 4600kv in development? or maybe other kv's ?
any info about the size ? what is the maximum length ? will it fit the AE sc10 4x4 ?
murky123 is offline
Old 12-13-2011 | 08:36 AM
  #836
Testing a faster one now in Germany...we have about 5 different speed but will only make 2 of the best.
It was also testing on Losi SCTE...so it will fit your AE easy.
Size is very much like a longer version of the MMM motor. 550 size or 540L size or whatever that thing called.
Solara is offline
Old 12-16-2011 | 10:47 AM
  #837
pghgamer's Avatar
Default Need some insight on SP!!
I just got a used XXX-T CR roller and need a decent motor / ESC combo that won't break the bank. I'm going to be running Stock and the track parameter is 13.5T brushless and above. What can you recommend? Would the "Stock Club Race" work well?
Also, what pinion / gear would you run as well?
Any insight is welcome,
Thanks!
~John
pghgamer is offline
Old 12-16-2011 | 11:46 AM
  #838
my sons xxxt cr has a stock club spec with 17.5 and it geared 25 86, its pretty quick....temps are pretty low down in the 100 range...i could go up at least 2 more teeth to get some more power in it
for a 13.5 id go around 23-24 .......i try to keep my sons truck pretty mild
clintscreations is offline
Old 12-16-2011 | 12:01 PM
  #839
pghgamer's Avatar
Do you think I should run a 17.5 instead? Or would the 13.5T fit my needs just as well? What tooth spur is he running? I'll be ok with the spur in it?
I'm pretty new to this whole thing so I'm kinda learning as I go..
pghgamer is offline
Old 12-16-2011 | 01:40 PM
  #840
to start i would go 17.5 that gives you a chance to learn car control and learn setup changes
i run 86 tooth spur in all my trucks and short course...i could go to a smaller spur but feels it kills the bettom end feel of the motor
