Speed Passion Thread >
Like Tree4Likes
Old 01-30-2012 | 04:51 PM
  #976
you should be able to get it into blinky mode without the lcd programmer. im sure solara will chime in when he see's this. i have never personally ran in blinky mode.
cm.stites is offline
Old 01-30-2012 | 05:10 PM
  #977
Lenman73's Avatar
Yeah I searched this thread and it was posted awhile back that you need the LCD box and pc to get the different software to get the lite to blink. If there is a way to do it without I am all ears. lol I am open to suggestions.
Lenman73 is offline
Old 01-30-2012 | 05:37 PM
  #978
Originally Posted by Lenman73
I may have figured this out. i have to get the other card and use the pc from what I gathered. But for right now with all the timing off is it the same as it would be if the lite was blinking?
Not exactly because the last setting is essentially a timing setting. U need the other "pro" box and the pc to change firmware to "no timing".
jb7778 is offline
Old 01-30-2012 | 06:04 PM
  #979
Racecrafter's Avatar
+1
If you are running "Mod" firmware you have to reprogram the esc with a PC through the "pro" program box to change it to a "stock/blinky" firmware.
Racecrafter is offline
Old 01-31-2012 | 11:52 AM
  #980
trytowin's Avatar
Any idea when stuff will make it through customs ? been waiting awhile....
trytowin is offline
Old 02-01-2012 | 01:23 PM
  #981
No....not the same.
Solara is offline
Old 02-01-2012 | 01:39 PM
  #982
AlanHall's Avatar
you have to use the PC..plug in the box.. change to stock no timing.. then load that to the esc.. i just had to do it for my prostock 2.1 mine dont blink. but i have to plug the lcd box in at the track in tech so it flashes "stock/no timing"
AlanHall is offline
Old 02-01-2012 | 04:01 PM
  #983
Cain's Avatar
Tech Legend
I got some Speed passion GT2.0 pros and an LPF coming in.
i am looking for some starting settings to go with for the following vehicles on a 40 x 40 carpet track over jumps:
- SC10 2wd SCT with Novak Ballistic 10.5 motor
- T4.1 2wd Stadium truck with Novak Ballistic 10.5 motor
- SC104x4 with Tekin SCX 5.5 motor
I will be using the LPF on the SC10 2wd, and the Pros on the stadium and 4x4 SCT.
i don't need specific novak motor info, if you have say another brand that doesn't use the funky high timing like the novak, i can just subtract the timing amounts.
Also, if you have a gearing suggestion please let me know that too. From what I am understanding, people use a smaller pinion / bigger spur setup to keep torque, and the timing boost to get that high RPM, at least that is what the current brand of ESC I use has been suggested.
Cain is offline
Old 02-01-2012 | 05:03 PM
  #984
Forget about any timing. With those motors and the size of the track with a straight barely 40 ft. You won't need any. Your gonna have a lot of forward grip. Gear for torque and accel while keeping temps low. I would run mod 205 and just play with the physical timing on the motor and DRRS. Concentrate on NOT traction rolling.
kwiksi is offline
Old 02-01-2012 | 05:09 PM
  #985
Cain's Avatar
Tech Legend
I am actually thinking of trying the 323 or whatever its call stock software as there are sections where the punch would come in quite handy, at least that is what I am seeing with my current ESCs.
Cain is offline
Old 02-01-2012 | 05:27 PM
  #986
You can turn the DRRS to max then. That is your punch. If you use 323 on SC/ST in 40x40 high grip carpet track. I see high temps in the future. There isn't give on carpet like there is on dirt when it coms to traction with those heavy trucks. You will put ALOT of strain on motor. You already have ALOT of motor for the size of the track.
kwiksi is offline
Old 02-01-2012 | 05:36 PM
  #987
Cain's Avatar
Tech Legend
thanks, I'll give the 205 a go first.
i am actually using a motor that is less than what others run here lol. Though, that 17.5 I had previously did have a lot of punch.
Cain is offline
Old 02-02-2012 | 03:01 AM
  #988
just noticed that rc model http://shopping.rcmodel.hk/index.php...&filter_id=164 is showing the reverton esc's with pricing if thats the pricing we will get over in the states then these esc's are going to be killer deals cuz even with the shipping they are still good deals from hk.!!
Old 02-02-2012 | 07:00 AM
  #989
Those prices will be pretty close.
Old 02-02-2012 | 07:04 AM
  #990
Cain's Avatar
Tech Legend
So how does the reventions that come out first rate against say the GT2.0 Pro power wise?
Can these first ones handle a SCT 4x4?
Cain is offline
