Speed Passion Thread
#947
#948
When you stab the trigger to full multiple times, check the green light on the speedo, see if it flashes. If its flashing, yoy have either a bad sensor wire, sensor on the motor, or the circuit on the speedo is damaged. I would try another known good sensor lead first.
I will check the "LED" to see what happens....then it could either be the sensor on the motor or the sensor inside the ESC, correct? I am going to try my Novak to see if it does the same thing. And if it does it has to be the ESC I guess.
You don't think I am asking the ESC to do too much with the 4.5 550 motor connected to it, do you??
#949
Thanks Raul, I have tried 2 different sensor wires. One new and one for a car that is running fine.
#952
Marc Rheinard still a believer of non boost and he is still very fast with a 3 years old 205g program.
#954
HI,
I'm trying to find the Stock 17.5 ESC motor combo and no one has one. Have been looking for about 3-4 months. Have tried all the big named places on line. Any suggestions on where we can find them in stock?
Thank you for any of your help with this matter.
Michele
Michele
#955
http://www.speedpassion.net/us/produ...12280175&c=CMB in stock on speed passions site if this is the combo your talking about.
#956
Man do you gotta gear these funky? Thing was fast.. but I wanted a little more hit.. so I dropped a tooth on the pinion and it felt even flatter? Weird .. also could someone explain the punch setting in blinky?
#958
Not had a chance to play with blinky but if you can take the drrs up 9
Gearing will be tall.....for more punch go to a larger spur and gear up pinion wise acoording
My sons xxxt with 205 no speedo timing I geared it 26 88 and it was plenty fast.....could have geared up more
I check temps every minute....but also try to listen to hear if it runs out of gear
#959
4Likes
