Speed Passion Thread
#1096
#1097
Ok, something new happened at the track. I have a GT 2.0 LPF which has worked flawless until today. The last couple of race days it at times will not go to neutral but it wasn't enough to even move the car and I gave it very little thought. I have moved the EPA around on brake and throttle but nothing major. Today it was moving the car pretty good and would take a couple stabs of the throttle to get it to go to neutral. Also at times it would go "dead" for the first hit of throttle after it finally went to neutral. I re-did the radio/esc and while it got better it still will not go to neutral. Any ideas?
It is not going into thermal protection as it does this at all times. When I plug it in and turn it on and after it has been run.
I would try the following and bench test after each change:
Check the sensor wire connections
Swap with a known good sensor wire
Check all of your solder joints - ESC, motor, and battery
Swap in a known good motor
Check your receiver wire connections
Swap with a known good receiver wire
Open receiver and clean out any accumulated dirt
Try an alternate Rx if possible
Try an alternate ESC if possible
If it is still acting up you're pretty safe to assume it is the lpf. Give SP a shout to send it in for service.
#1099
Dual rates are not anything I've ever messed with. They are all set at zero. The negative wire leading to the capacitor while it was not off was nearly so. I will take everything out of the car and give it a cleaning. Hopefully this will be all that is needed.
Thank you.
Thank you.
#1100
quick report on yesterday's races using GT2.0 For SCT 2wd, 2wd ST, and SCT 4x4.
using the LPF in the SCT 2wd, the Pro's in ST, and SCT 4x4.
both 2wd using Novak 10.5s and the SCT 4x4 using a 550 Tekin SCX 5.5.
I started with the setup I saw for the SCT-E 4x4 using the novak 550 ballistic 5.5 I believe as I figured it would be a bit more conservative. I also combined this with the recommended settings in the 323 stock software guide for I believe an 11.5 for offroad turned down slightly since the novaks start with there 30 degree timing thing.
On the tight track here, I found that I needed basically to turn all the boost off for the 4x4 to get the temps down into a reasonable range. As the track had a lot of 180s, I found that I had too much power and was jamming the brakes too much heating stuff up. The actual speed of the vehicle was sufficient so I wasn't at the high end of the throttle range all the time or too low.
The SP GT2.0 Pro performed flawlessly in my SC10 4x4. Very impressed.
It also did the same on the T4.1 , wheels on command, almost too much power.
the SC10 felt a bit down on power with the LPF, and I needed to adjust the gearing more, probably part of the issue.
All in all, the Speed passion stuff was excellent. May just pickup a pro version for the SC10 too.
#1102
#1105
Just started having a problem with my lpf in my b4.1. Running a 7.5 geared at 22/81. No timing at all, tried running 528 mod software and the newer version (still no boost at all). The speed control is coming off the track at 200+ degrees? Motor temps at 125-130 after a 5 minute heat. Car has good power and runs with the other guys with similar motor and gearing. Drag brake is set to 12% and I hardly ever use the trigger brake.
Suggestions?
Suggestions?
#1106
are you running a fan or capacitor?
Suggestions?
Suggestions?
#1110
Suggestions?
Suggestions?
SP Team Setups
4Likes
