Speed Passion Thread >
Like Tree4Likes
Old 02-25-2012 | 02:27 PM
  #1081
trytowin's Avatar
Good thing I got my order in !
trytowin is offline
Old 02-27-2012 | 10:51 AM
  #1082
zeakemedia's Avatar
Ok I may have a small complaint. I could be in a position to get the Silver Arrow and 2200kv motor combo but spending close to $160 on shipping does seem a bit excessive to me. Should I just buy the two separately from the USA warehouse? And if I do that I can't get the 2200kv which is the one I would prefer.
zeakemedia is offline
Old 02-27-2012 | 10:54 AM
  #1083
zeakemedia's Avatar
And trying to buy them separately isn't going well either. It will not put both of them in the shopping cart at the same time? I would like to know what I am looking at as far as shipping costs.
Blake
Old 02-27-2012 | 11:07 AM
  #1084
the overseas shipping costs have always been super high.. best bet will be to wait till speedpassion usa gets them back in stock.
cm.stites is offline
Old 02-27-2012 | 11:17 AM
  #1085
zeakemedia's Avatar
I was just bringing up that I would really like the combo. Will shipping costs ordering the Silver Arrow and 2500kv separately be close to the same as being able to order them together? They are coming to Ohio, 43333. And the "problem" with waiting for them to get back in stock together is people are snatching up everything Speed Passion that I may miss when they do become available.
Old 02-27-2012 | 01:24 PM
  #1086
try emailing usa customer support and let them know your situation....they might be able to help
clintscreations is offline
Old 02-27-2012 | 02:26 PM
  #1087
i know when i ordered my stuff the only difference in shipping costs was like 10-15 cents. but i also live in illinois 2 hours from speed passion usa. they do have both the esc and the citrix slotless 2500 kv in stock at the usa site for a subtotal of 160.92 plus shipping to which at most is 12-15 dollars depending on the method of choice.
Old 02-28-2012 | 09:17 PM
  #1088
Cain's Avatar
Tech Legend
Anyone got a suggestion on starting values to use for a 10.5 motor in a 2wd SCT and Stadium truck?
Also, starting value and software for a 5.5 in a 4x4 SCT?
Cain is offline
Old 03-03-2012 | 01:15 PM
  #1089
silverhkswrx's Avatar
I have a few "noob" questions...
1) I just got my hands on a 2.1 GT EX... I plan on running it in 1/10 TC carpet with the 1 cell 7.5R v3 motor. (I will be running 2 cell though) this would do fine right? I mean I have never owned an ESC that doesnt have a fan... I am a very aggressive driver and how does the esc handle the heat?
2) will the bluetooth/wifi tools for the Reventon work with the GT 2.1 EX?
3) is there a mounting reccomendation? (Heat sink direction)
silverhkswrx is offline
Old 03-03-2012 | 01:37 PM
  #1090
trickedout's Avatar
Any update on the reventon availability??
trickedout is offline
Old 03-03-2012 | 02:07 PM
  #1091
For the 10.5 I'd go with the regular 205 firmware. Crank the ESC timing up and adjust punch (ATMS?) as desired. Watch temps of course. Generally don't want boost and all that in mod as it makes it less predictable and the extra speed isn't normally needed with more motor. Others may disagree, that's fine.
Don't have any experience with the 4x4 SCT motors (550 can?).
1) Not sure if the EX model is going to work for you, it's intended for 1 cell, not recommended for 2 cell touring car. Looking at the ratings, maybe with the 508zero no timing firmware???
2) Don't believe so, as I understand it the Revention is all new.
3) Not sure, perhaps ask in the on road forum SP thread. Or others may come along here with more and perhaps better info.
Last edited by Dave H; 03-03-2012 at 02:53 PM. Reason: still working on that English as a first language thingy
Dave H is offline
Old 03-04-2012 | 09:54 AM
  #1092
The fastest speed controller on the market is only getting better, and smaller...
Speed Passion is proud to present the brand new GT2.1 EX series ideally designed for 1/12th scale applications and 1/10th WGT racing. It feature the all new "Auto-detect" power input (auto select how many number of cells) without choosing the power input manually. And there are no need of using any voltage booster or external receiver battery pack even using the single cell lipo battery. It has the ultra low profile heat sink design that flushed with the case and it will fit all the 12th scale bodies and 10th scale WGT bodies without any rubbing problem.
GT2.1 EX also features the most winning "Supercharger" software from Speed Passion for Stock and the 2010 World Champion Modified class racing software with supercharger already installed. It still feature the same USB update capability so you can always renew the latest software along with the Speed Passion development without any new hardware. It still feature the Speed Passion owns DRRS and AMTS function along with the ROAR sportsman "No-Timing" option for the Sportsman spec racing.
As always, the GT2.1 EX are build in new Green Power Feature which gives you the full time consistency power and longer run time!
A small footprint of L44.15 W31.75 x H18.30mm, it supports up to 1 to 2 cells of LiPo with 3.5T motor. Speed Passion also sells this new ESC in carbon black, silver and blue colors.
GT2.1-EX features:
Digital Racing Response System - DRRS
9 Selection Digital Racing Modes (From Level 1 to Level 9)
Advanced Multi Timing System - AMTS
Special 8 mode brushless motor timing adjustment system
Design suitable for different brand of brushless motor which give you the best performance for both ESC and Motor
9 stages of Supercharger BOOST level
9 stages of motor RPM engagement adjustment
9 stages of Supercharger full throttle time adjustment
7 stages of Supercharger PUNCH level
Standard Smart ESC Program Unit
came with the ESC LED Programmer Card with 14 adjustable functions, no need to use a computer or counting flashing lights.
Leading Brushless ESC Specification
Support both sensored and sensorless brushless motors
Support up to 3.5T brushless motor on 1 cell lipo or 4.8V battery
Support up to 5.5T brushless motor on 2 cells lipo or 7.2V battery
If using software 323STOCK with any of the GT series speed controller, the included LED programmer box will not be compatible with the software/speed controller. Please purchase our LCD professional program cardPart No.# SPLCD01 in order to work with the software and the speed controller.
Old 03-04-2012 | 01:17 PM
  #1093
Keep going.....
Type Scale Software Motor Battery
On Road 1/12 528Stock 10.5T to 21.5T 1 cell Lipo or 4.8V Battery
On Road 1/12 528MOD 3.5T-9.5T 1 cell Lipo or 4.8V Battery
On Road 1/10 528Stock 10.5T to 21.5T 1 cell Lipo or 4.8V Battery
(528stock software cannot be used with 3.5 to 9.5T motor)
On Road 1/10 528MOD 3.5T-9.5T 1 cell Lipo or 4.8V Battery
On Road 1/12 205MOD 3.5T-9.5T 1 cell Lipo or 4.8V Battery
On Road 1/10 508zero 3.5T to 21.5T 2 cell Lipo or 7.2V Battery
On Road 1/12 508zero 3.5T to 21.5T 1 cell Lipo or 4.8V Battery
On Road 1/12 508zero 10.5T to 21.5T 2 cell Lipo or 7.2V Battery
Note: GT2.1 EX "exit factory with preload 205MOD software"
We are not recommended to use this GT2.1 EX ESC with 100528stock or any
Supercharged software on 2S/7.2V powered Touring Cars.
Please consider using the GT2 series or GT2.1 ProStock series for all
Touring Cars application.
The bold text, and previous comments by SP reps in the on road forum, were the basis for my post. And your comment about being an aggressive driver. But again, not completely sure, just a note of caution.
Dave H is offline
Old 03-04-2012 | 01:38 PM
  #1094
slaughter.j's Avatar
Default SAII esc
if somebody figured out how to get the SAII esc to work on 2s for 4x4 sc i would like to know how.
slaughter.j is offline
Old 03-04-2012 | 03:26 PM
  #1095
zeakemedia's Avatar
Ok, something new happened at the track. I have a GT 2.0 LPF which has worked flawless until today. The last couple of race days it at times will not go to neutral but it wasn't enough to even move the car and I gave it very little thought. I have moved the EPA around on brake and throttle but nothing major. Today it was moving the car pretty good and would take a couple stabs of the throttle to get it to go to neutral. Also at times it would go "dead" for the first hit of throttle after it finally went to neutral. I re-did the radio/esc and while it got better it still will not go to neutral. Any ideas?
It is not going into thermal protection as it does this at all times. When I plug it in and turn it on and after it has been run.
