Speed Passion Thread >
Like Tree4Likes
Old 03-05-2012 | 06:35 PM
  #1111
Originally Posted by Cain
quick report on yesterday's races using GT2.0 For SCT 2wd, 2wd ST, and SCT 4x4.
using the LPF in the SCT 2wd, the Pro's in ST, and SCT 4x4.
both 2wd using Novak 10.5s and the SCT 4x4 using a 550 Tekin SCX 5.5.
I started with the setup I saw for the SCT-E 4x4 using the novak 550 ballistic 5.5 I believe as I figured it would be a bit more conservative. I also combined this with the recommended settings in the 323 stock software guide for I believe an 11.5 for offroad turned down slightly since the novaks start with there 30 degree timing thing.
On the tight track here, I found that I needed basically to turn all the boost off for the 4x4 to get the temps down into a reasonable range. As the track had a lot of 180s, I found that I had too much power and was jamming the brakes too much heating stuff up. The actual speed of the vehicle was sufficient so I wasn't at the high end of the throttle range all the time or too low.
The SP GT2.0 Pro performed flawlessly in my SC10 4x4. Very impressed.
It also did the same on the T4.1 , wheels on command, almost too much power.
the SC10 felt a bit down on power with the LPF, and I needed to adjust the gearing more, probably part of the issue.
All in all, the Speed passion stuff was excellent. May just pickup a pro version for the SC10 too.
Good to hear your're getting where you need to be with the 10.5s. As you've noted boost doesn't work so well on the bigger motors, and generally not really needed.
Dave H is offline
Old 03-06-2012 | 06:43 AM
  #1112
Cain's Avatar
Tech Legend
Yeah, for the track I am running on it since its very small definitely not needed. I also will be adjusting my gearing as I think I am off on that too.
I actually decided to go with all Speed Passion stuff at least for my 2wd stuff. Picked up 2 9.5R V3 competition motors to try out. Last time I had 1/10 speed passion stuff I really liked it, so will give it a go again.
Cain is offline
Old 03-07-2012 | 06:29 AM
  #1113
Originally Posted by heattracer
Tubular Heater: It is an electric heater in wide range of ratings and sheath materials. The tubular heater forms in various shapes with advantage of improved heat distribution with simple installation and application.
Construction: Tubular Heater is made up of for metal to suit applications, surrounds a nickel chrome resistance wire centered and packed by an electrical insulator. This gives a resistance spiral with varied heat concentrations protected by atmospheric corrosion. These tubular heaters can be fitted with mounting bushes, flanges, header bosses etc., to suit the installation.
Reported. Bye bye!
Dave H is offline
Old 03-07-2012 | 06:39 AM
  #1114
Suspended
Reported. Bye bye!
+1
I just reported the post too.....
MattP is offline
Old 03-07-2012 | 06:45 AM
  #1115
jkach's Avatar
Matt, I assume u really like the silver arrow v2 in your ve8. Anything I need to know, looking to get into 1/8 ebuggy and really like the ve8 (alittle nerves about the chassis). Just making sure the silver arrow is a good fit. It must be pretty good it's back order all over the place.
jkach is offline
Old 03-08-2012 | 06:15 AM
  #1116
jkach's Avatar
Any word on when the silver arrow combo, seems everyone has them back ordered. Soon I hope
jkach is offline
Old 03-08-2012 | 11:57 AM
  #1117
Cain's Avatar
Tech Legend
Does anyone have any experience using the Silver Arrow V2 motor in a 4x4 SCT? Is it basically a 550 motor like stuff from Tekin, etc?
Thinking of using this in an SC104x4 as I like the vented design.
What is the kv rating on the 5.5R Silver Arrow V2?
Cain is offline
Old 03-08-2012 | 10:47 PM
  #1118
russp's Avatar
any word on the REVENTON release yet? cant wait to strap one in to my truck!
russp is offline
Old 03-09-2012 | 08:20 AM
  #1119
S and R pushed back to early April.....Reventon PRO, still testing and revising.
Solara is offline
Old 03-09-2012 | 02:12 PM
  #1120
umm winning's Avatar
tututuuuday speeed passion!!!!
umm winning is offline
Old 03-09-2012 | 03:31 PM
  #1121
hairymuffin's Avatar
which rotor to install for a 17.5 v3 for offroad...want more top speed
hairymuffin is offline
Old 03-09-2012 | 04:35 PM
  #1122
Better off getting the +20 or +30 timing boards. I don't think a rotor swap will get you the top speed either of these can.
kwiksi is offline
Old 03-09-2012 | 07:18 PM
  #1123
most places I race at are no timing? will that board matter?
Old 03-10-2012 | 01:13 AM
  #1124
russp's Avatar
Most of our local tracks non timing classes means in the esc. We can add all the timing we want in the motor tho.
I pretty sure you and I race at the same local tracks.
russp is offline
Old 03-11-2012 | 01:38 PM
  #1125
Anyone have some base settings for 109 mod? running a 4.5
cm.stites is offline
