Speed Passion Thread >
Like Tree4Likes
Old 12-17-2012 | 10:20 PM
  #2611
Originally Posted by dvsstrike
you can't go wrong with with this set up. no need to upgrade at all. all top notch stuff.
+1..... you wont find a smoother speed controller out there,,,if you find that your on a large track that can take the extra power, purchase a yellow timing board, (but if you do, be very conserative with the timing, and watch your temps)
gdcopbdcop is offline
Old 12-18-2012 | 08:18 AM
  #2612
DHooter's Avatar
quick question
im running the 2.0 lpf. is turbo the added power at WOT and boost just the all around added power?
DHooter is offline
Old 12-18-2012 | 11:06 AM
  #2613
Cant wait to get my stuff.
GT2.0 pro brushless on its way, (usa website has sales right now most shops cant touch in price). and ordered a v2.0 6.5, why a v2, on sale for 27 bucks. Not racing just practice time at track, these will go in my b44.1, shoudl be enough. even the v3 motors soem are on sale for 35 bucks.
next get revention r for stock class.
ALIEN3T is offline
Old 12-18-2012 | 11:11 AM
  #2614
Cain's Avatar
Tech Legend
GT2.0 Pros are awesome. I still get a kick out of how well it runs my SC10 4x4.
Cain is offline
Old 12-18-2012 | 11:15 AM
  #2615
Originally Posted by DHooter
quick question
Turbo is added at WOT after the selected delay (if set). Boost is started at the selected RPM and added on the RPM increase that is set.
KSimmonds is offline
Old 12-18-2012 | 11:41 AM
  #2616
Cain's Avatar
Tech Legend
Cool info. for 4x4 SCT I have been using boost with the RPM based settings, 5 degrees max with a 4 pole motor and get great power. may switch or couple this with Turbo to get even more top speed.
Cain is offline
Old 12-18-2012 | 01:38 PM
  #2617
mjk1210's Avatar
Additional tip: The turbo slope is how aggressively the turbo comes in. And the lower settings it is smoother and at the higher settings and "fastest" it kicks in alot quicker and in buggy can result in some mid-straightaway wheelies.
mjk1210 is offline
Old 12-18-2012 | 01:47 PM
  #2618
BBJ's Avatar
BBJ
Thanks for the recommendations on the Revention pro.
Had a look at the manual and it states that it is suitable for down to 4 Nimh cells (4.8v) but it also says that if it is used with voltages below 6v, damage may occur. Im planning to use this ESC (if I decide to get it) with some older 6 cell packs i have (to begin with). I dont want to kill the speedy simply because i used an old pack.
BBJ is offline
Old 12-18-2012 | 07:17 PM
  #2619
sugs's Avatar
Which 4 pole are you running Cain?
sugs is offline
Old 12-18-2012 | 07:24 PM
  #2620
Cain's Avatar
Tech Legend
Tekin Pro4 4000Kv in the SC10 4x4.
Cain is offline
Old 12-19-2012 | 09:57 AM
  #2621
Originally Posted by subaru_tech
just installed a new rev pro for first time.
all is wired correctly,no fan,no battery connection.
went to connect too pc.it showed it connected,stated it had mode1.then went to connect esc home screen.
now the esc wont power up,when i try to connect lcd to esc and battery.i get the lcd to show speed passion for a second them powers off.motor kicks on at the same time.
i have 3 other rev pro's.tried all the other cards,cables with no luck.
motor is wired correctly.
any clues?
Can you PM me Mike...
Solara is offline
Old 12-20-2012 | 12:12 AM
  #2622
We have had our Reventon R for about 2 months and are very pleased with it. Early this week we updated the speedo firmware and LED Box software without any problems to version 21. But now we can't calibrate the throttle and brake. Holding the button down and turning on results in rapid beeping sounds. Car still runs fine but would like to be able to calibrate if needed. Tried re-installing the software - any ideas?
Welshmerlin is offline
Old 12-20-2012 | 01:10 AM
  #2623
MOmo's Avatar
Cain,
Have you tried 2 pole motors? If I update o the Rev Pro in my 4wd and Rev R in my 2wd, I might swap the GT2.0 to my borrowed SC10 4x4 with a 5.5 2 pole.
MOmo
MOmo is offline
Old 12-20-2012 | 06:19 AM
  #2624
-WHEELMAN-'s Avatar
My Reventon Pro has been at Speed Passions repair facility for three monhs anyone have any info on when replacements will be in?
-WHEELMAN- is offline
Old 12-20-2012 | 07:31 AM
  #2625
Please do PM me your info, RMA numbers and others....that is unacceptable.
Solara is offline
