Speed Passion Thread >
Like Tree4Likes
Old 12-05-2012 | 08:08 AM
  #2461
New update for REVENTON ESC....there are no new firmware within but all the frimware were added the "upload protection" feature that it will provide a perfect upload without demaging the ESC internal software. That means it should not have anymore 99% upload and crashed....for those ESC that has software problem, this software should take care of it....give it a shot.
http://www.speedpassion.net/files/SP..._v1_1_0_21.zip
(1) Uninstall the REVENTON software via window's uninstall program
(2) Go to 'C:\Program Files\Speed Passion" and make sure to delete the folder SPEED PASSION.....(if the folder still exist there)
(3) Install the new program...
(4) Update the LCD card...without connecting the ESC. I see alot of people having trouble connecting the LCD firmware because they are connecting the ESC with the LCD while doing the card update, that will not work and will screw up the software.
(5) When updating the card (the new V2.6 version) then restart the computer and program and connect your REVENTON PRO with the LCD card (no fan connection and no LIPO please) and you should be able to do the firmware update...
Solara is offline
Old 12-05-2012 | 08:38 AM
  #2462
Originally Posted by Tia813
Hello all. 2 months ago I picked up a Rev Pro along with a Revtech 8.5T for my 2wd buggy. I noticed at full throttle no lights illuminate on the esc. I calibrated twice to make sure. Normal right? 2 weeks ago I started using Mod2 and last night I threw on a slightly used Thunder P Z3R 9.5t. Guess what... At full throttle I get the solid red light. I did recalibrate when I uploaded Mod2. I did not notice the solid red when I had the 8.5t with the Mod2.
Originally Posted by Solara
Are you saying that...when you use a 9.5, you have red light when WOT? then you switch to the 8.5 and when you are WOT there are no red light? I want to understand it correctly and find out the solution.
That you "E"? If so check you FB messages
Nexus is offline
Old 12-05-2012 | 09:44 AM
  #2463
Solara---- I stayed up late last night doing some diag cuz I actually had 2 issues. IF the solid red at WOT is normal then that means that up until I updated the firm ware to mod2, it was not calibrate correctly because now I get a solid red on both 8.5 and 9.5.
The other issue is only with the 9.5 and my 25c pack. I get the low voltage blink as soon as I hit the throttle. It drives normal just blinks. This is on both 25c. I tossed my 65c in there and no issues.
Sent you a PM
Tia813 is offline
Old 12-05-2012 | 09:47 AM
  #2464
Yup it's me!
Tia813 is offline
Old 12-05-2012 | 10:13 AM
  #2465
Yup it's me!
stop practicing...race..fuggit LOL
Hopefully we'll get it figured out. But for sure I would do what I described in the FB message.
Nexus is offline
Old 12-05-2012 | 10:29 AM
  #2466
Lol!!! I'm stuck in touring mode! I can take the turns but add a jump and forget about it.
Yes I will try what you suggested.
Tia813 is offline
Old 12-05-2012 | 10:33 AM
  #2467
PM me and Howard when you are going to the track next. If the problem still exists or you just need help with the ESC maybe we'll can head out there.
Racing, practice...baah same same LOL
Nexus is offline
Old 12-05-2012 | 11:14 AM
  #2468
Originally Posted by Jeff Werner
Just got a Rev R and want to ask what motors have people used with no issues? I am in the market for a new motor and want to get what works the best with the esc. Read through the thread and want to avoid any issues.
Thanks and excited about running some SP ESC!
We have been using a LRP X12 7.5T for the last 2 months in a 2WD without any problems. Temps are good on the motor and the Rev R.
Would like better brakes for high grip astro - hoping a version of MOD2 is released for the R
Welshmerlin is offline
Old 12-06-2012 | 04:54 AM
  #2469
dam
Silver Arrow V2 Question:
I put in a recently serviced motor and was having problems with it. I thought I would recalibrate the radio but I can't seem to get it in the right mode. I hold the set button, turn on the esc and release the set button. The esc flashes red, and the motor kind of twitches, it never gets into the calibration mode.
I ended up putting my good motor back in and the esc works fine and is smooth as ever, so I assume it is still calibrated fine. I can make all adjustments with the card and computer, but it puzzles me that I can't recalibrate it to the radio.
Also, do I need to download the Drivers Software Patch from their website dated 7/21/10?
Thanks!
dam is offline
Old 12-06-2012 | 04:59 AM
  #2470
AlanHall's Avatar
Do you have the newest mod2? I updated my pro and it definitely has more brakes.
AlanHall is offline
Old 12-06-2012 | 07:10 AM
  #2471
Cain's Avatar
Tech Legend
Isn't it supposed to flash? Then you press the button for each setting, total of 3 times?
Cain is offline
Old 12-06-2012 | 08:41 AM
  #2472
R/C Tech Elite Member
Server Error
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
flame56mx is offline
Old 12-06-2012 | 08:44 AM
  #2473
Originally Posted by flame56mx
Server Error
Are you clicking Solara's link or directly from SP website?
I just tried by going directly to SP's website and it worked fine.
Nexus is offline
Old 12-06-2012 | 09:13 AM
  #2474
I clicked his link, I just tried the SP site, and it did work fine..thanks
Old 12-06-2012 | 09:15 AM
  #2475
Only the Pro can use MOD2
Hoping for a better brake version for the R
