Speed Passion Thread >
Like Tree4Likes
Old 12-07-2012 | 04:08 PM
  #2491
3srcracing's Avatar
Originally Posted by schumacheracing
ok new video with the fan unplugged and trying to calibrate again with a cap on the reciever so there is no brown out issues
http://www.youtube.com/watch?v=WemMZ...ature=youtu.be
Same thing is happening to me, anyone have the solution to this?
Except mine wont eve going into programming mode.
Mine is also the Speed Passion SP Cirtix Short Course.
3srcracing is offline
Old 12-07-2012 | 08:48 PM
  #2492
dvsstrike's Avatar
Originally Posted by 1mrdad
I adjusted my neutral point from 6% to 9% at practice yesterday and recalibrated the radio to the esc. I had no problems all night with reverse or brakes.
That is good to hear.
dvsstrike is offline
Old 12-08-2012 | 12:45 AM
  #2493
66Racer's Avatar
Hey guys,
Curious how well the wireless android ESC programing works on the reventon pro, also how do you guys like the throttle responce/smoothness? I'm gonna use it in 17.5 buggy and loved the gt2.1 in my 1/12 pan car. I'm just looking for smoother throttle. After racing 1/12 scale my 1/10 lrp feels more on/off like.
66Racer is offline
Old 12-08-2012 | 07:16 AM
  #2494
See
Originally Posted by 66Racer
Hey guys,
The bluetooth module with the android app works awesome. I run 17.5buggy with a reventon pro and the throttle response and smoothness are great night and day difference over the tekin Rs I was running.
See is offline
Old 12-08-2012 | 08:05 AM
  #2495
dvsstrike's Avatar
No comparison the Rev pro is ten times smoother than the lrp and the bluetooth works flawless.
Old 12-08-2012 | 08:16 AM
  #2496
66Racer's Avatar
Thanks guys this changes things up a bit as I almost overlooked this ESC before buying a new one!
66Racer is offline
Old 12-08-2012 | 11:35 AM
  #2497
See
Its nice to be able to just pull out your phone and change your settings.
See is offline
Old 12-08-2012 | 05:19 PM
  #2498
I busted the case on a Silver Arrow can I get a new case? Where?
texaspaul is offline
Old 12-08-2012 | 05:38 PM
  #2499
heavy's Avatar
R/C Tech Elite Member
I have a Reventon Pro that will not program from the card - when you have the program open on the PC and then the card plugged in to the USB and it says connect the ESC - then nothing happens - the PC program doesn't open up with the settings options.
It's not a PC or usb driver isssue because I have another Pro that programs perfectly - anyone had this problem - any help ??
heavy is offline
Old 12-08-2012 | 05:54 PM
  #2500
See
Originally Posted by Solara
Yes...RICH told me your case, and I find it very interesting...low C rating lipo will cause this problem.
However, another thing is...does TEKIN Gen 2 motor has temp sensor inside..? If it does....you have to do the same thing like LRP and Viper motor does...disable the 2nd wire from the left on the sensor cable and that should take care the shut down issue.
Give that a try.....
Solara,
Did some testing today and I believe pulling that wire has taken care of the problem.
See is offline
Old 12-08-2012 | 06:10 PM
  #2501
DaveG28's Avatar
Hi Solara,
Are you expecting any more stock of the Silver Arrow 2 esc to come in at some point?
Or is it now finished until a new esc appears (if one is!)!?
Also, I hav a Reventon pro...is there a more powerful option capacitor than the one included?
DaveG28 is offline
Old 12-08-2012 | 06:44 PM
  #2502
Autocratic's Avatar
Is there ever going to be an update that allows the newer Reventon LCD box to work with other Speed Passion ESCs? Because honestly, the $35 LCD programmer plain sucks. Cheap plastic, buttons are terrible. The Reventon box atleast feels like it has some worth to it.
Autocratic is offline
Old 12-08-2012 | 08:05 PM
  #2503
I'm looking for some suggestions on where I need to start with the setting on my LPF gt 2.0 ESC. I'm running a losi 22 with a 17.5T Orion VST. I do have the professional programming box that I can hook to my laptop.
Any good starting points would be appreciated since I have never messed with a Speed Passion esc.
Let me know.
Bob
bobsavenger is offline
Old 12-08-2012 | 08:31 PM
  #2504
Oldschoolrcer's Avatar
I had the same issue just two days ago( first time I used it) the driver was not installed properly. I removed all the software and reinstalled it EXACTLY like the YouTube video by speed passion and it works fine now. Try removing and starting over. I spent hours trying to figure it out because everything " looked" right on the pc but for some reason it wasn't working .
Only problem I have now is the first time I went to use the Reventon Pro , I plugged the battery in about ten minutes before the race, and it fried just sitting there on the bench.??? It actually burned the positive terminal right off the circuit board for no apparent reason. I guess i will find out how thier warranty service is now. It went through the Calibration process and bench testing just fine so I don't know what happened. Anyone else have this problem.
Oldschoolrcer is offline
Old 12-08-2012 | 10:21 PM
  #2505
quickershifter's Avatar
I cant setup my Reventon Pro esc using LCD program box I have upgrade the LCD software to v2.6. It just show 'Speed Passion Reventon' on the LCD screen. Any thought on this?.
quickershifter is offline
