Speed Passion Thread >
Like Tree4Likes
Old 12-10-2012 | 12:48 PM
  #2521
See
Originally Posted by Carranza76
Is the Rev R not for sale anymore? It does not show up on the SP American website only the Pro, S and Stock
The Reventon R is on the US site just shows out of stock.
See is offline
Old 12-10-2012 | 01:15 PM
  #2522
Originally Posted by texaspaul
Just left message at 888 number.
thanks
Cool....I will have the office to follow up.
Out of stock...and I do not know when it will be instock. Keep checking the website. Or check your local hobby shop (or other online store).
Originally Posted by Autocratic
Solara, can you comment on this?
It will not going to happen...to different software and hardware. The problem is...the GT2 series software was developed by different company and we are not going to blend them into our REVENTON series.
I think if you really want to, you can buy the other brand version programmer card and install our software, I was told it will work.
Originally Posted by See
The 2nd generation motor does have a temp sensor that was confirmed by Randy Pike from tekin. I will go ahead and run it with the wire pulled until that update comes out.
Thanks for understanding...I am very much sure the auto shut off was caused by this temperature sensor.
Solara is offline
Old 12-10-2012 | 02:42 PM
  #2523
Originally Posted by Oldschoolrcer
I had the same issue just two days ago( first time I used it) the driver was not installed properly. I removed all the software and reinstalled it EXACTLY like the YouTube video by speed passion and it works fine now. Try removing and starting over. I spent hours trying to figure it out because everything " looked" right on the pc but for some reason it wasn't working .
Only problem I have now is the first time I went to use the Reventon Pro , I plugged the battery in about ten minutes before the race, and it fried just sitting there on the bench.??? It actually burned the positive terminal right off the circuit board for no apparent reason. I guess i will find out how thier warranty service is now. It went through the Calibration process and bench testing just fine so I don't know what happened. Anyone else have this problem.
Had this happen. Capacitor was reversed at the factory.
OferS is offline
Old 12-11-2012 | 05:49 AM
  #2524
shanelang's Avatar
Originally Posted by Solara
Again...DO NOT connect the LCD card, with computer and ESC with LIPO batteries, unless you want to have a new ESC and new computer. It stated on the manual.
Now...the latest V21 software (on the website) should able to UNBRICK all the bricked ESC. Please uninstall the old version, and do a clean install...restart Window and give that a try.
thaks solara just wondering battery and usb problem was early on, and for month and a half after that i could use on pc and wifi, but the problem updating firmware was just recent, it said update failed, would the two be connected even though several sucessfull updates were made.new to the hobby learning the hard way maybe otherwise very impressed with reventon.
shanelang is offline
Old 12-11-2012 | 06:01 AM
  #2525
Mundy1's Avatar
Is there ever going to be an update that allows the newer Reventon LCD box to work with other Speed Passion ESCs? Because honestly, the $35 LCD programmer plain sucks. Cheap plastic, buttons are terrible. The Reventon box atleast feels like it has some worth to it.
Are you talking about the LED or LCD programmer?
I agree the LED that comes with a ESC feels like junk. It also does not work with current software once you update the ESC.
But the optional LCD programmer is nice. It feels like a fine instrument and works very well with all the software available for this line of ESC.
It also looks and feels just like the "Other Brand" programmer minus the carbon fiber sticker.
Mundy1 is offline
Old 12-11-2012 | 07:16 PM
  #2526
Dob's Avatar
Dob
I was looking into a Speed Passion system to replace my MMP, as it won't fit in my next kit (Schumacer SVR). I'm not quite sure on a few aspects of the controllers. Would I need either the Reventon Pro or Gt 2.0 pro, or would I be ok with the "reventon r" or "gt2.0 lpf" as it will only be used in a 2wd buggy with an 8.5.
I also did not see a footprint listed on the site for the reventon. I remember reading the reventon was smaller than the GT esc's, but just wanted to make sure that was true. Thanks in advance!
Dob is offline
Old 12-11-2012 | 07:27 PM
  #2527
The r or 2.0 will be just fine in your 2wd....I've got a 2.0 in my buggy and have ran a 6.5 with no probs
clintscreations is offline
Old 12-11-2012 | 07:33 PM
  #2528
Oldschoolrcer's Avatar
Great! Did they cover it under warranty? I'll have to look at the cap and see if it is marked +/-.
Oldschoolrcer is offline
Old 12-11-2012 | 08:24 PM
  #2529
After soem help, would this be a good motor to run in 4wd offroad mod?
http://www.speedpassion.net/ausshop/...=13865V3&c=MTR
If it is, what is the best choice of ESC to couple with it form this page here?
http://www.speedpassion.net/ausshop/index.asp?c=ESC
If there is a better option for my Schumacher Cat K1, could someone point me in the right direction from the speedpassion range? I want to run 6.5t, but am completely new to electric so not really sure where to start motor spec, and ESC wise.
thorns is offline
Old 12-12-2012 | 05:00 AM
  #2530
Originally Posted by mjk1210
it would be odd, but my first thought is a motor wire. The SP esc will still run on 2 wires and maybe you have a weak solder connection to a terminal on a motor wire? ??? or a bad piece of wire? or??? I've had a wire pop off completely and the car slowed like that before. but my problem was obvious so an easy fix. you're seems intermittent which always is hard to figure out. Once it's working right you will surely love the smooth power of it though.
I've re-soldered the wires, I've also got a programming card and changed the setting to see what happens. Well, I still have the same result. Sooo. I guess I'll have to send it in to be looked at. The reason I think it's the ESC is because I have put my novak Havoc Pro SC in and it works but doesn't have the punch.
So, any other recommendation would be apprciated before I send this in.
bobsavenger is offline
Old 12-12-2012 | 09:41 AM
  #2531
Hi all. I am quite new to all the brushless esc and motors. I am using the SP gt2.0 pro in both 2wd & 4wd with 6.5 & 5.5 motors in my buggies. I have updated the software on both speedo's to 428 Mod, but I can't find anywhere that explains what each of the new functions does if I adjust them up or down eg 'turbo slope' 'turbo timing' etc. can someone tell me if there is an explanation on these new setting that I can down load from somewhere.
Thanks.
mark-rc is offline
Old 12-12-2012 | 09:52 AM
  #2532
a 6.5 in a kitty will be plenty
save yourself some headaches and go with the reventon pro or the LPF 2.0 pro....and use the fan
they are smooooth az butta
Old 12-12-2012 | 09:56 AM
  #2533
The Rev's Avatar
Great speedo. just replaced my sxxv2 with the revention and i definately think it helped with my lap times in 2wd buggy due to the super smooth throttle feel. The motor felt better then it ever has with other speedos.
nice job sp
The Rev is offline
Old 12-12-2012 | 11:17 AM
  #2534
My honest opinion is..REVENTON PRO is still the best all around ESC if you are running from stock 17.5 no timing to full mod BOOST with 4.5....for just a little bit more you will have the top of the line ESC with tons of software update/upgrade in the future, and it will work on any turn motors and covered every classes...
Solara is offline
Old 12-12-2012 | 11:33 AM
  #2535
Cain's Avatar
Tech Legend
Has the issue with running 4 Pole motors like the Tekin Pro4 and similar types been fixed? I would look into upgrading if that was the case, but for now, the GT2.0 Pro is the only one from SP that will do those motors on 2S.
Cain is offline
