Speed Passion Thread >
Like Tree4Likes
Old 12-13-2012 | 01:46 PM
  #2551
subaru_tech's Avatar
since the blaze 550 is out as of yet.
does sp have any other 550 can motors for 4wd sct
subaru_tech is offline
Old 12-13-2012 | 01:58 PM
  #2552
Cain's Avatar
Tech Legend
Originally Posted by bobsavenger
Lipo cutoff was set at 2.6v and I did try the DRRS at 6 and 9. I did not turn off the lipo or the thermal.
I do know when I used the same sensor wire and changed from the Speed Passion ESC to my old Novak Havoc that I did not have this problem. Bad thing is the Novak doesn't have the punch that this one does.
The motor is an Orion 17.5t VST.
Have you tried a different battery? See if you can power someone's higher end pack.
Cain is offline
Old 12-13-2012 | 02:54 PM
  #2553
marcel p's Avatar
Hey.
Is the gt2.0 case (housing) posible to order as replacment part.
Mine is broken .
I bougt 2 new reventon pro speedos. But my gt2.0 works still great and i would like
To make it clean an sharp again
Anyone a order number?
Maybe solara?
marcel p is offline
Old 12-13-2012 | 03:06 PM
  #2554
Default Revention Pro
Does the revention pro use the external capacitors like the GT 2.0 pro?
knowitall156 is offline
Old 12-13-2012 | 03:15 PM
  #2555
Originally Posted by marcel p
Hey.
Mine is broken .
Maybe solara?
Give our office a call and talk to Albert
Solara is offline
  #2556
No...Reventon PRO use a single cylinder type.
Solara is offline
Old 12-13-2012 | 03:16 PM
  #2557
I hope the BLAZE will be out early next year...
Solara is offline
Old 12-13-2012 | 03:17 PM
  #2558
Does it use the same programming box? I'm guessing no?
Old 12-13-2012 | 03:19 PM
  #2559
No...
But....Reventon PRO came with one free, so no need to buy one, cause it came with one (LCD one) from the ESC.
Solara is offline
Old 12-13-2012 | 04:20 PM
  #2560
marcel p's Avatar
Sorry. Forgot to mention im from europe. Normaly deal with tonisport.
marcel p is offline
Old 12-13-2012 | 05:03 PM
  #2561
Oldschoolrcer's Avatar
Originally Posted by OferS
They did indeed warranty the capacitor. Sent me a new pair within days!! ESC was not damaged. Look for the black line on the side. It should be closer to the black wire than the red.
The stripe is right about in the center of the red and black wire.
maybe you can tell from the pic. It would make perfect sense why it burned where it did if the poles were reversed. It didnt seem to fry the inside of the case since I dont see any smoke or discoloration through the clear bottom case.
It also melted the solder joints right off the battery +/- terminals.
Here are some pics
Attached Thumbnails Speed Passion Thread-photo-4-1-.jpg   Speed Passion Thread-photo-5-1-.jpg   Speed Passion Thread-photo-1-2-.jpg
Oldschoolrcer is offline
Old 12-13-2012 | 07:29 PM
  #2562
will any 550 motor work with the reventon pro.
and can you add timing with them,without damage.
Old 12-14-2012 | 03:47 AM
  #2563
Default Capacitor looks polarity correct
Here are some pics
Your capacitor has the black wire on the side of the circuit board that also has the black "negative" stripe... So it is polarity correct. My first one had the stripe on the side of the little circuit board that had the red wire soldered to it. That was wrong. Both the replacements look like yours. Maybe a bad capacitor in general?
OferS is offline
Old 12-14-2012 | 07:42 AM
  #2564
Then talk to Toni....he is cool.
Solara is offline
Old 12-14-2012 | 07:44 AM
  #2565
Here are some pics
Please contact our office and request warranty service, we will take care of that for you.
Solara is offline
