Speed Passion Thread
#2673
I just received a Reventon Pro for Xmas from my son. Tried it at practice tonight, and it was awesome. The power application is very smooth, making the car much easier to drive and jump. A couple of questions about the bluetooth module. Is it supposed to be mounted in the car? If so, do you connect it with a Y-cable? If you have to plug it in every time you want to make an adjustment, I don't see the advantage of using it with your cell phone, versus using it with the LCD programming card.
#2674
#2675
ok, got a problem with the Reventon Pro. This is a buddys. It wont work now after a failed update. It just turns on then shuts off right away with just a yellow light. Any fixes?
The esc was new out of the box and I installed it like I have my other two reventon pros. Everything worked fine. Calibrated it and test run. Updated his firmware to 2.6 on the box and as I went to update the esc to mod2 software it failed shortly after the update and now the esc wont work.
BTW: this was using V1.1.0.21
#2676
Don,
Sent you a PM. i have all the software for my GT 2.0 and LPF on the digital box, so let me know. I can meet you at the track sometime if you want it.
The newer MOD1 software should be plenty for you. Esp. for a 13.5 it should be fine. We may have to up the timing and boost, but its easy enough to change.
MOmo
#2677
Take it a little easy on me for this question. Running on a somewhat small track and have both a LPF and Pro 2.0 and it will be in either a T4 or B4. 17.5 running full timing on the ESC and everything else turned up because I am not running blinky. Gearing?
#2680
17.5 around 75/30 would be a safe start and mind your temps.
MOmo
#2681
#2684
4Likes
