Speed Passion Thread
#2686
So what happens now? It doesn't turn on or does it with any LED indicators? If so which ones, steady or blinking?
Not electronics, but Speed Passion none the less. I'm liking my Speed Passion Ananta short course body. I've been running the pre-painted and now sprayed up a non-prepainted version. These bodies are solid and hold up very well in SC door banging :P
http://www.speedpassion.net/shop/ind...ODYSHELL&sc=49
#2688
#2690
On the vidio on the speed passion site it shows a driver pull his car into pit lane, pull out his iPhone and change his esc setting all without ever turning the car off or leaving the drivers stand, is this really possible and what is needed to be able to do that?
#2693
http://www.speedpassion.net/en/produ...SP000008&c=OPT
Or this for you Iphone folks.
http://www.speedpassion.net/en/produ...SP000009&c=OPT
I have the bluetooth module It always trips people out at the track when you pull out your phone an adjust your esc.
#2697
As stated above by others, try and connect the ESC to your computer via the programming card. Then update the firmware again. This will usually solve the problems you describe. You can choose any firmware and not necessarily the one you are trying to run. Sometimes choosing a different firmware first helps. Then once your ESC accepts that you can go ahead and update the firmware you are specifically trying to use.
Not having to bring a laptop is one of the key benefits that the WIFI and Bluetooth module give the user. It is easier to use your smartphone trackside instead of a netbook/laptop.
#2699
4Likes
