Speed Passion Thread
#2657
I just got a reventon R to try. Would love to do a review or write up if you guys want to contact us at [email protected]
Heard about you from a friend, and just love finding new treasures to pass on
#2658
I just received a Reventon Pro for Xmas from my son. Tried it at practice tonight, and it was awesome. The power application is very smooth, making the car much easier to drive and jump. A couple of questions about the bluetooth module. Is it supposed to be mounted in the car? If so, do you connect it with a Y-cable? If you have to plug it in every time you want to make an adjustment, I don't see the advantage of using it with your cell phone, versus using it with the LCD programming card.
#2659
ok, got a problem with the Reventon Pro. This is a buddys. It wont work now after a failed update. It just turns on then shuts off right away with just a yellow light. Any fixes?
The esc was new out of the box and I installed it like I have my other two reventon pros. Everything worked fine. Calibrated it and test run. Updated his firmware to 2.6 on the box and as I went to update the esc to mod2 software it failed shortly after the update and now the esc wont work.
BTW: this was using V1.1.0.21
#2661
What software do you recommend with a 13.5 motor on a fairly tight indoor clay track for a mod truck class?
Is there a list of what the different software versions are designed/best for? (vehicle, track conditions, motor, etc.)
#2662
http://www.speedpassion.net/reventon/home.asp?t=5
#2664
Here is a link to the different software profiles. I would think the Mod 2 or Stock 1 software then adjust settings to your liking.
#2668
#2669
4Likes
