Speed Passion Thread
#1156
will the silver arrow v2.0 work with a 2s battery? i have on for my d8 and i plan on running 2 2s lipos but i havent received my series connector yet. so i tried it with just 1 2s battery and it turns on fine but when i hold set then turn it on to set the throttle/brake stuff.....it just keeps blinking red and beeps?
#1157
#1158
#1162
The GT2.0 Pro works great for 550 motors, I am going to try it with the Tekin pro4 today.
#1163
Hey guys, I have been having a look through but its not easy to find one particular setup, wondering if anyone can offer some advice,i finaly recieved my program card (lcd) i am running the following
Hpi pro 4
Speed passion GT 2.0 Pro
Speed passion MMM 10.5
6500 Lipo 90c 7.4 2s lipo
It will be used on a medium track quite a nice straight
Item 9 Boost timing
The defualt for the boost timing is showing *37 and to the right 36 hmm
The manual suggests value 5 which is 15 big differance
Item 10 Turbo slope
I dont evan have this one in my book
Its set at default *4 and to the right the number 18
Item 12 Turbo timing
set default *25 to the right the number 24 (i am sure i read somewhere were all meant to be using this 24 timing at our track)
Item 13 start RPM
Set as default *4 number to the right is 4000 (rpm)
Item 15 timing acc
Set as default *7 number to the right is 350
any adice on the above items appriciated thanks
Hpi pro 4
Item 9 Boost timing
Item 10 Turbo slope
Item 13 start RPM
Item 15 timing acc
#1164
Hpi pro 4
Hpi pro 4
You should probably scan thru this thread, since this is the thread dedicated to people using the Offroad setups.
ONROAD can be found here. http://www.rctech.net/forum/electric...on-thread.html
MOmo
#1165
can you use a speed passion program box on a xeron 120a? 1s black edition?
reason I ask is because hobbypartz is out of stock on those programming boxes for the xeruns and a friend of mine has a speed passion box...I have access to until they're in stock
#1166
I finally got the 8.5 V3 motor in my B4 and the temps went down to 145* on the ESC so I would say Luke and Dustin were correct that something was wrong with the 7.5. My lap times remained the same with the 8.5 over a 7.5 but with a 78 tooth spur I couldn't get the temps on the motor over 85*. I started with a 22 tooth pinion, moved to a 24, then ended with a 26, the highest I have, and with that temps were at 80*. The car still has a good amount of rip and pulls some 7.5 cars on the straight but I think there is more. Going to try a 75 tooth spur this Sunday and then an 81 tooth and see what happens. I kept the exact same settings on the ESC that I had with the 7.5.
Blake
Blake
#1167
I HAVE NEVER TRIED NOR WOULD I CONDONE THIS AT THE RISK OF VOIDING ANY WARRANTY OR DAMAGE TO PRODUCT. ( MOMO's disclaimer)
#1168
I've asked this question before and gotten mixed answers, but I think the software inside is different. Logic would think That if You could format the device and download and install the proper SP software, it could work.
#1169
anyone know the Kv rating for the Crawler Master-L?
http://www.speedpassion.net/us/produ...SPCML205&c=MTR
#1170
Hi!
I'm new to Citrix ESC. A local competition has specified this ESC to use with 13.5T motors and I was on a race on Monday and on the last final heat, the ESC stopped working after 1 minute of racing. I was using it with LRP ERASER stock spect 13.5T motor.
When I turn on the ESC, the light goes on, but BEC (power to reciever) is not working. The fan is not turning. The ESC did not overheat (after 1 minute of racing, the outside temp was 13deg C).
Any ideas what went wrong and what to do? I suppose this should be fixed under warranty?
Thanks,
Miha.
Thanks,
Miha.
4Likes
