Speed Passion Thread >
Like Tree4Likes
Old 12-13-2013 | 09:09 AM
  #4156
1967Typhoon's Avatar
Originally Posted by derekbsmith
new to SP. looking at a SP reventon pro, assume this will work in my sct 4x4 since its 140a? im using a HW sct pro now and its 120a continuous. also, my motor is a revtech 4800kv.
OK to use? I emailed support 3xs with no response. : (
thx!!!
I personally wouldn't use the reventon with anything but 540 can, 2-pole motors. It isn't really meant for 4x4sct.
1967Typhoon is offline
Old 12-13-2013 | 09:13 AM
  #4157
derekbsmith's Avatar
Originally Posted by cripplethreat
This is the best place to ask because the website support is absolutely worthless.. I've emailed many times also and to no avail
ok, so know of any issues with trinity revtech 4800kv with a SP reventon pro?
# site says:
# Reventon PRO: 4.5R to 21.5R Motorturn.
what about the reventon pro itself, flaky firmware, etc?
derekbsmith is offline
Old 12-13-2013 | 09:22 AM
  #4158
the trinity revtech 4800kv is a 540 4 pole can and right now I am using a 120a HW. 540 Quad magnet is used.
the pro 1.1 is 140a, so to me logically it will be fine, unless some one had tried this already?
I emailed support just now....4 xs now.
Old 12-13-2013 | 09:26 AM
  #4159
I can't answer that question. I don't run anything but 2wd and 4wd buggies.. But I have Speed Passions in both and have yet to have a problem. I'd recommend them
cripplethreat is offline
Old 12-13-2013 | 10:11 AM
  #4160
Cain's Avatar
Tech Legend
thx!!!
This is not supported usage. Now, I don't know if this has changed recently, but when this was discussed a few times it was never confirmed by Speed Passion that the ESC can be used in this manner. Part of it may have been they were trying to boost the motors which when running 4 pole is a big no no with at least the Tekin motors for sure.
the Speed Passion GT2.0 Pro however does work for 4 pole 540 and 550, I know, I used it in such matter with the Tekin Pro4 4000kv, 4600kv, and 4300Kv HD motors and the Hobbywing 4000Kv motor with the siliver rings around the middle.
I hope though that in the future, Speed Passion releases a full 1/8 ESC similar to what Tekin and Viper offer that covers the 1/8 classes and 1/10 4x4 SCT class.
Cain is offline
Old 12-13-2013 | 10:37 AM
  #4161
USA support just responded, quickly I'll add. They said no and yes, yes with no timing and no boost. I'd like to use the wifi module in both my cars for programming, hence reventon. Any other SP Escs support the wifi or bt modules?
Old 12-13-2013 | 10:39 AM
  #4162
You don't need any timing or boost on those motors anyway. They have all the power you would ever need.
Old 12-13-2013 | 10:50 AM
  #4163
Only the newer Reventons work with the wireless modules. Older GTs will not.
The new 1/0 4x4 motors will be landing soon...
Nexus is offline
Old 12-13-2013 | 10:54 AM
  #4164
Yeah but can I be certain the rev pro 1.1 will not glitch out with the revtech? Opinions? Thx!!!
Old 12-13-2013 | 10:57 AM
  #4165
Cain's Avatar
Tech Legend
not unless you try it or someone else does. I am glad we got a definitive answer on if the ESCs can do 4 poles, assuming when you called you asked about the 540s and 550s?
Cain is offline
Old 12-13-2013 | 11:00 AM
  #4166
I only asked about the 540 4 pole. Here is the email resp;
No and Yes, only with no timing and no boost.
BR
Speed Passion
Old 12-13-2013 | 11:02 AM
  #4167
Speed is Key's Avatar
From: Born in Simi Valley CA ... Raised In Temecula CA ... Live in Louisville KY ... BUT I WILL BE BACK IN CALI SOON (:
Default Im looking for a speedpassion 17.5 system
Its going in my Dex210 I am just not too well known on SP I was looking at the Novak Pulse/ Vulcan Combo but it is pretty Expensive and I know SP has good quality equipment
Thanks Guys!
Speed is Key is offline
Old 12-13-2013 | 11:03 AM
  #4168
How much of a risk reventon pro 1.1 with the revtech u think?
The revtech would be bought for ~120, warranty replacement.
Anyone have a gtpro 2 for sale?
Old 12-13-2013 | 11:32 AM
  #4169
BR
Speed Passion
Reventon ESC will not work with 4 poles motor if you are using TURBO (STOCK1) software on the 4 poles....it will work with 4 poles motor with MOD2 software with mild timing setting.
Of course it will work with 4 poles motor if running blinky....Stock0.
Solara is offline
Old 12-13-2013 | 11:36 AM
  #4170
Cain's Avatar
Tech Legend
and to confirm, that includes 550 4 poles right?
Cain is offline
