Speed Passion Thread >
Like Tree4Likes
Old 03-12-2013 | 05:40 PM
  #3406
Originally Posted by 07Forester
Did you call like I told you to? All they have to do is look up your name in the computer and your problem will be solved.....
I have to wait till friday to call them I work from 7:30-5. No time untill friday when I will get off at 2:30
micrors4guy is offline
Old 03-14-2013 | 05:16 AM
  #3407
Waflet's Avatar
Hideeho
For those that are using viper, tekin gen2, or LRP motors, how does the motor perform with the 2nd wire from the left cut? I seem to have a lot of cogging, like it's running completely sensor less, especially from a stop. Have I done it wrong? Could there be other issues with my motor? Is this what I should expect with the wire removed?
Waflet is offline
Old 03-14-2013 | 06:20 AM
  #3408
flat6's Avatar
Just picked up a Speed Passion Silver Arrow V2 esc to run in my Mugen Mbx6 Eco. Now I just need the lcd programmer and im all set. Looking forward to it!!
flat6 is offline
Old 03-14-2013 | 06:55 AM
  #3409
See
Originally Posted by Waflet
Hideeho
I am running a Gen 2 with the wire removed and mine does this only when you barely give it throttle.Any other time it is fine and not noticeable.
See is offline
Old 03-14-2013 | 07:08 AM
  #3410
Hideeho
I have a Tekin-1 motor. I cut the 2nd from left wire also. my motor was cogging a bit also. you can fix that by turning down the timing on the motor a bit.
gdcopbdcop is offline
Old 03-14-2013 | 07:41 AM
  #3411
Waflet's Avatar
Hideeho
That will be perfect. I currently have max timing on the can & nothing on the ESC. I was planning on reducing the can timing & adding in ESC boost any way so that should work out perfectly.
Waflet is offline
Old 03-14-2013 | 11:34 AM
  #3412
Hideeho
Why do you cut the 2nd wire wire from the left?
Welshmerlin is offline
Old 03-14-2013 | 12:47 PM
  #3413
Waflet's Avatar
Hideeho
Those motors have a temp sensor that doesn't play well with the reventon ESC's. After 15-20 laps the ESC will go thermal & shut down. The ESC registers 55-60*c & the motor 110*f. With the 2nd wire from the left removed I can run to lipo cut off with ESC @ 60-70*c & the motor @ 150*f, but it cogs at low speeds. I will try reducing the timing on the can & adding boost from the ESC, hopefully that will fix everything. If not, I'll be trading my LRP motor for a different brand.
Waflet is offline
Old 03-14-2013 | 12:55 PM
  #3414
Hideeho
Ive been running an LRP x12L 5.5 in my 4wd SC with the Reventon Pro ESC and it's been flawless and I didn't have to cut anything. You must have some set-up incorrectly or something.
kerby is offline
Old 03-14-2013 | 04:48 PM
  #3415
I've got a quick question - I've just set up my Reventon Pro ESC. It's awesome but one thing does seem to be a bit irregular. Is it normal for me not to be able to turn off the ESC unless the TX is on and sync'd with the RX? I noticed it by chance but wanted to know if this was normal. Thanks!!
capricorn415 is offline
Old 03-15-2013 | 12:18 AM
  #3416
If the radio transmitter is on and the throttle is not at normal point, ESC will not able to turn off. Re-calibration would be solve the problem.
WMGary is offline
Old 03-15-2013 | 01:34 AM
  #3417
Hideeho
We have run a LRP X12 7.5 with zero timing on can and 22.5 on ESC for months without any problems. Changed to a X20 7.5 with same settings and ESC was going thermal at around 5 mins. Motor was too hot at between 90 to 100c. Reduced timing on ESC to 11.25 and all was OK except son wanted more power! Now runing a X20 6.5 at 11.25 timing with the LRP cooling fan. Son is happy with power and motor is running around 65c. Hope that helps.
Old 03-15-2013 | 01:50 AM
  #3418
Suspended
You will love it. Remember the hobbywing software also will work on this esc along with the brushlesshobbies.com software as well. You just need a usb to receiver lead adapter.
I've bought over 20 SA V2 escs and not a single issue from the first one. I prefer it over my old Tekin RX8's I used to run.
MattP is offline
Old 03-15-2013 | 10:10 AM
  #3419
Waflet's Avatar
Hideeho
Is this with the 2nd sensor wire disconnected?
Waflet is offline
Old 03-15-2013 | 10:23 AM
  #3420
Speed Passion chicks are fast...
http://www.liverc.com/news/race_resu...Town_Shootout/
http://teamspeedpassion.com/
Nexus is offline
