Speed Passion Thread >
Like Tree4Likes
Old 04-30-2013 | 08:49 AM
  #3556
Originally Posted by Gwoodrc
Thought I would bump this thread back up and see if anyone was willing to comment on my issue.
Running full timing 28.25* on Mod2 software is normal, alot of driver use it and it depends on the size of your track...of course, it the track is shorter and smaller, you should turn it down to 18*...it is nothing abnormal to use full timing on AMTS....check out our factory drivers setup on SP website...most are using full timing...
About the motor timing...yes too, you can use the full timing = 10*...it really depends on the gearing and driving habit. But you should still be able to use the middle setting like 5* and still have good power...
Last....have you calibrate your radio with ESC after loading the MOD2 software...? I calibrate between my radio and esc everytime JUST to make sure there are no mistake at all....make sure your EPA on throttle are 100%....don't do that 120% setup and back down to 90% crap like other brand ESC does...not going to work on SP ESC.
Solara is offline
Old 04-30-2013 | 09:02 AM
  #3557
Cain's Avatar
Tech Legend
Solara: Any news on when the Blaze SCT motor will be available in the USA? I hear of people testing it, but nothing else.
Also, what all happened to the Cirtix R8 1/8 speed control?
Any news on if we will get some 1/8 scale sensored motors in the same Kv ranges as the sensorless stuff?
Lastly, have the Reventon Pro been certified for 540 4 Pole usage, albeit, with limitations on the software you use (like the Speed Passion GT2.0 Pro).
Cain is offline
Old 04-30-2013 | 09:13 AM
  #3558
Autocratic's Avatar
What's the word on that new Reventon Pro that Viktor Wilck used at the last ETS race? Is it replacing the current Pro or is there something different besides the case?
Autocratic is offline
Old 04-30-2013 | 09:21 AM
  #3559
Cain's Avatar
Tech Legend
Cain is offline
Old 04-30-2013 | 09:31 AM
  #3560
Looks like a bigger fan too..
Raul Garcia is offline
Old 05-01-2013 | 06:52 AM
  #3561
Default Gt2.0 problem
Alright I'm having a couple problems and I'm baffled. I run GT2.0 pro's in my 4 Durango's. in my DESC410, the esc jumps into unsensored mode after 4-5 laps. You can feel it lose the punch and when I pull it off the track the green light is blinking.
Now, I figured okay the esc and motor are a bit tired so I re-did my electronics with some extra parts I have. I installed a Brand new GT2.0 pro, Tekin 4000 Pro4, new sensor wire. Same exact symptom. Tried 2 other sensor cables, same thing.
I'm stumped. Any suggestions?
knowitall156 is offline
Old 05-01-2013 | 07:07 AM
  #3562
Cain's Avatar
Tech Legend
what software you using on the ESC?
Is the Tekin motor new too? Have you tried a different motor?
Cain is offline
Old 05-01-2013 | 10:38 AM
  #3563
528 stock and the motor has less than an hour on it. No. I was going to try a 4.5 and see if it goes away.
Old 05-01-2013 | 11:38 AM
  #3564
Cain's Avatar
Tech Legend
strange stuff. Have you tried any different software modes like 205MOD or even blinky?
Cain is offline
Old 05-01-2013 | 11:44 AM
  #3565
That would be the next step. It's weird because I've been running this set up for the past year and love it. It just started giving me problems.
What would blinky be considered as I run no timing now?
Maybe Solara can chime in his thoughts?
Old 05-01-2013 | 11:56 AM
  #3566
Cain's Avatar
Tech Legend
If you have been running the same setup no issues before makes me wonder about the motor personally.
I am thinking there may be more to the software in blinky than just timing alone as I also run similar software to you or have and haven't had an issue. I did notice that blinky felt a bit lower in overall grunt compared to stock, but I could be wrong.
Cain is offline
Old 05-01-2013 | 01:56 PM
  #3567
Do you run a Tekin 4 pole or a 550 motor?
Old 05-01-2013 | 02:40 PM
  #3568
Cain's Avatar
Tech Legend
Tekin Pro4 4000Kv and 4600Kv (now). Before that, ran a Tekin SCX 5.5
Cain is offline
Old 05-01-2013 | 05:37 PM
  #3569
Definitely the sensor board on the motor, if you have changed the esc and the sensor cable.
Old 05-01-2013 | 06:32 PM
  #3570
silvalis's Avatar
Whatever happened to the cirtix slotless 540 motors?
silvalis is offline
