Speed Passion Thread >
Like Tree4Likes
Old 03-11-2013 | 04:00 PM
  #3391
07Forester's Avatar
Originally Posted by noahf
I tried searching but couldnt find an answer.
I just installed a Reventon R into a 22t. I broke in the diff and the slipper clutch just fine. Turned it off. Then i put it on the track, ran 1 lap, and the throttle died (still had steering.) Took it off, powered it off, and then checked all wires/plugs and it looked ok. Then I put it back on the track, lined up for racing, and got down the straight away before the same thing happened again.
It appears that after about 1 minute of running with the occasional full throttle, it shuts off.
When I arrived home I did some testing and reset my neutral/throttle/brake and checked settings on the ESC and all appeared acceptable. Then was testing the throttle, giving it some juice, and after about 1 minute it just cuts off.
Any idea? The temps on both ESC and Motor are ambient. I used 3 different lipos (all have less then 4 cycles on them) Any idea? Bad ESC? (brand new reedy sonic 17.5 motor as well.)
When the throttle dies, what do the lights on the unit do?
07Forester is offline
Old 03-11-2013 | 04:07 PM
  #3392
they stay solid
noahf is offline
Old 03-11-2013 | 04:44 PM
  #3393
they stay solid
Try throttle protection off, lipo cutoff protection off....and give that a try.
Solara is offline
Old 03-11-2013 | 06:22 PM
  #3394
have something that needs to be returned RMA website will not recognize any of my login information (where my recipt is) so i cant reset my password. I was getting help threw PM's on this site then nothing. Kinda mad i have a 50$ paper weigh for the 350$ worth of esc's i have.
micrors4guy is offline
Old 03-12-2013 | 04:15 AM
  #3395
Default R
Originally Posted by jhhack
Can someone from Speed Passion know an update of when the orange Rs will be available for sale in the US?
I may have one I don't know if it is orange the box is still sealed. I will check to see if the box has the color on it. let me know.
maizer is offline
Old 03-12-2013 | 04:28 AM
  #3396
Pittster's Avatar
Originally Posted by Pittster
Hello Solara,
First of all thanks for posting lots and lots of very useful information in both speed passion threads.
A few quick question I have a Reventon Pro and a Comp MMM 10.5 in a HPI Blitz 2wd SCT.
I have been playing with the DRRS 3.0 settings to get the best mix of traction and power. Is this setting limiting the maximum current to be pulled from the battery/current sent to the motor at x throttle position? or is it changing the throttle curves to be softer or more aggressive.
Secondly is the overheat protection of 95Deg for the motor or ESC ?
Thirdly I am running the Mod2 firmware as recommended by you.
How much do the power/brake curve/power application vary to the Stock0 Firmware? (I ask this due to our class requiring blinky mode but I prefer Mod2 with no timing)
Is there any tables or data that show how the firmwares vary behind the scenes.
Thanks.
Just bumping this one as I think it got missed would appreciate any input.
Pittster is offline
Old 03-12-2013 | 10:54 AM
  #3397
I use savox servos in all of my cars. One car in particular has a 1258, with a reventon r and it's just fine. Spend the few extra bucks and buy the R.
Thanks for the info Forester.
I looked at the -R but the Pro combo was less than USD 20,- more so I took the combo. But I'll keep it in mind as the -R and -S share the same BEC, I might get either one for a future project.
Simulacra53 is offline
Old 03-12-2013 | 03:13 PM
  #3398
lipo cutoff is off, but i do not see where to turn throttle protection off at.
noahf is offline
Old 03-12-2013 | 03:42 PM
  #3399
blade329's Avatar
R/C Tech Elite Member
Did you forget that you have a login name that can be different from the display name?
blade329 is offline
Old 03-12-2013 | 04:32 PM
  #3400
There is a total of 4 names i would have used. Then my email i tried for 45 mins to pull it. Nothing worked. Cant even reset my password.
Old 03-12-2013 | 04:51 PM
  #3401
-WHEELMAN-'s Avatar
He meant thermal protection.
-WHEELMAN- is offline
Old 03-12-2013 | 04:56 PM
  #3402
-WHEELMAN-'s Avatar
Think you need to send it in. Get an RMA number. Same thing that happened to my first one.
Old 03-12-2013 | 05:12 PM
  #3403
thats off as well.
any other ideas?
noahf is offline
Old 03-12-2013 | 05:17 PM
  #3404
07Forester's Avatar
Did you call like I told you to? All they have to do is look up your name in the computer and your problem will be solved.....
  #3405
07Forester's Avatar
thats off as well.
any other ideas?
Send it in...
