Speed Passion Thread
#3422
#3423
Stock Reventon Pro Setup request:
Looking for a good blinky setup for a Reventon Pro in a B4.2. Revtech 17.5/standard rotor, geared 72/34.
Will any firmware blink if all esc timing is off? Coming from an RS Pro...it has a weird low-mid hit that I couldn't tune out with gearing or can timing.
#3424
Strange.
Totally random, what is your radio setting? I noticed that if I had anything other than a linear curve, it would also do strange things when i ran the GT 2.0 or LPF ESC. Waiting for a car to show up on Mon before I test the new REV S. in it.
MOmo
#3426
#3427
question...on average how long does it take for a SP rep to get back to you by email when you send in an item for repair?
I have send a few emails to them with my RMA# and still have not heard back from anyone..
I know my item is there as I tracked it online..
#3428
They modified the layout of my track today, so I stopped off to run a pack & try it out. I also reconnected the sensor wire & took most of the timing out of my lrp (1 dot). It did exactly the same. Ran great, lacking power but smooth, for about 5 minutes & thermaled
. Motor was @ 108* & the ESC was @ 97* (per temp gun, not the card). I pulled the sensor wire & ran sensor less for the rest of the pack. The motor got to 130* & the ESC to 120* (again by temp gun, not card). It was actually smoother sensor less than w/ the 2nd wire only out, but it still clogged @ low speed & from a stop. I'm going to see if I can borrow a motor that is not an lrp, tekin, or viper & give that a try tomorrow. It's not looking good for me continuing to run an lrp motor though
#3429
Got my Reventon Pro 13.5r combo kit yesterday and to be honest I wasn't that impressed by its built quality. IMHO it looks cheaper than an HW Ezrun, which as entry level goes is pretty solid. I'd expected a bit more from the Reventon-series. Hopefully it's performance won't disappoint!
#3430
#3431
#3433
In your opinion is it worth switching from a RX8? I happy with the RX8, but always looking to improve.
#3434
The plastic quality and molding looks inferior to what I am used to. Not hopeless, just not as good or clean.
I also have HW, Novak, Castle and Teking entry, mid and high level ESCs to compare with.
But...if it runs as expected, I'll ignore the base
#3435
4Likes
