Speed Passion Thread >
Like Tree4Likes
Old 03-17-2013 | 11:17 PM
  #3451
Yeah, I will try Mod2. Worst that can happen is a fire, right.
AlderBoy is offline
Old 03-18-2013 | 05:22 AM
  #3452
Originally Posted by AlderBoy
I tried running the Rev Pro in my Tekno SCT410 and no worky. I was running stock 0 software with a HW 4000kv 4-pole. The motor never got above 130 but the ESC would hit overheat protection in less than 3 minutes of normal driving. I turned off overheat protection, drove like a granny and the ESC would completely shutoff after 5-8 minutes.
SP guys, any idea why the Rev Pro cannot handle a 4-pole in an SC running stock 0 software? The GT 2.0 which is 120a seems to have no problems, but the Rev Pro which is 140a cannot hack it.
You have to turn the temp control off i never use it on my k1 and i wont use it on the Tekno.
maizer is offline
Old 03-18-2013 | 05:34 AM
  #3453
Tried that, no worky. See the last sentence of my first paragraph.
AlderBoy is offline
Old 03-18-2013 | 08:47 AM
  #3454
I see. Lower your lipo cut off or just shut it off. I have been told the ESC works better with them off. Does it turn off on the Rev Pro?
maizer is offline
Old 03-18-2013 | 08:57 AM
  #3455
I looked at PastaBoyNY posts and any of the software options that don't have boost should work. I have been running stock 0 which has no boost or timing and it still doesn't work. So something is wrong.
I have a feeling that your motor has the over heat protection on the sensor...can you disable one of the cable on the sensor wire and give that a try....? See below link for the wire that you need to cut...
http://www.speedpassion.net/files/So...eventonPro.pdf
Solara is offline
Old 03-18-2013 | 10:06 AM
  #3456
I've just got the wifi module and am having problems connecting it to my iPhone 4S ( but no problems connecting it to my I pad) it will connect to it but not receive a wifi signal. Any ideas chaps?
Scooterboy34 is offline
Old 03-18-2013 | 10:46 AM
  #3457
Go to settings and manually choose the wifi network.
kerby is offline
Old 03-18-2013 | 11:04 AM
  #3458
I can choose the network and connect to it but do not receive a wifi signal, no problems with the I pad just the phone
Old 03-18-2013 | 11:23 AM
  #3459
Waflet's Avatar
Hideeho
One of the videos had a guy entering the static ip as 192.168.11.111 instead of the 192.168.11.123 listed in the manual. I was having the same problem & tried that & it worked.
Waflet is offline
Old 03-18-2013 | 12:21 PM
  #3460
I will try that. Yes it does.
AlderBoy is offline
Old 03-18-2013 | 12:22 PM
  #3461
I will try that too.
AlderBoy is offline
Old 03-18-2013 | 02:06 PM
  #3462
Nope no different, perhaps there is a compatibility issue with iOS 6.1.2 on the iPhone, no problems at all with the iPad but I don't really want to have to take the pad to the track
Old 03-18-2013 | 08:31 PM
  #3463
dvsstrike's Avatar
Solara You got mail
dvsstrike is offline
Old 03-19-2013 | 02:55 AM
  #3464
MOmo's Avatar
So I picked up a Rev. S (Blue Case) and i planned to use it in my Drift car. I thought I would update the software and change it over to the Drift profile.
I see others have posted about not detecting it and I too had the same issue. I tried multiple downloads and uninstalled and re-installed etc. Still not working.
Using an IBM Thinkpad running XP SP3.
Here is what I did-
-Downloaded the latest software from the SP site.
-Once downloaded, ran the USB software- (Windows msg about finding new hardware, tried both cancel and trying to install from the software downloaded)
-Followed the manual instructions
-When I initially connected it, I would see the ESC light up, but later, no lights. I would get 2 dash lines on the LED box.
I did try checking the settings using the box alone, and was able to make changes to the basic settings, but I really need the Software to make other changes. Not sure where to do from here.
I have uninstalled and re-installed a couple times. No Difference.
MOmo
MOmo is offline
Old 03-19-2013 | 03:53 PM
  #3465
Cain's Avatar
Tech Legend
browsing the classifieds and noticed the cirtix R8 up on one.
Curious, what every happened to this ESC? Looked pretty good. No mention on SP's site anymore on it but there is historic info on it.
http://www.speedpassion.net/us/produ...3301C8X&c=DIS#
Cain is offline
