Speed Passion Thread >
Like Tree4Likes
Old 03-24-2013 | 06:34 PM
  #3481
-WHEELMAN-'s Avatar
Can someone please post the a link to download "stock 0" program for the Reventon Pro? I dont know why I cant find it.
-WHEELMAN- is offline
Old 03-24-2013 | 06:54 PM
  #3482
Pittster's Avatar
Go to the Speed passion website page ( i can't link it not enough posts) and download the latest Reventon PC Program with USB Driver V1.1.0.22. This contains all the firmwares available for your ESC.
Follow the intructions and flash the LCD Unit to the latest firmware (remove fan & Batt Pack) then when you conect to the ESC go to firmware upgrade in the software and you can select from all the firmwares available. Read the guides you can download it is quite easy.
I have flashed Stock1 Mod2 & yesterday Stock0 with no issues
Pittster is offline
Old 03-24-2013 | 08:09 PM
  #3483
See
Here you go.
http://www.speedpassion.net/en/download.asp
See is offline
Old 03-26-2013 | 02:14 PM
  #3484
3Captain's Avatar
I am going to purchase the SAII for my 1/8 buggy. Can I flash a different firmware to one of the "spare" Programmers that came with my Reventon Pro's to use with the Silver Arrow? I don't need both of them for my 1/10 stuff
3Captain is offline
Old 03-27-2013 | 02:05 PM
  #3485
MOmo's Avatar
Was looking over the site under the TEAM Setups.
Does anyone have a good setup for the LPF 2.0 in Mod 2wd buggy?
I found a couple, but mostly for GT 2.1, but they seem a bit outdated. For now, I'll use the LPF till I can afford 2 Rev. pros.
Can someone clarify the major significance of the LPF vs the GT 2.1?
AE B4.2
Novak 8.5
Indoor Clay Med/high traction
I looked at a couple and they all seemed to use the older software.
I updated to the current 428, but looking for some more help for a baseline.
MOmo
MOmo is offline
Old 03-28-2013 | 11:31 AM
  #3486
Orion_2kTC's Avatar
Has anyone tested Speed Passions alone with Team Orion and noticed a substantial difference between either?
I'm still debating between SP or Orion for various reasons but I've heard that SP is as smooth as Orion.
Orion_2kTC is offline
Old 03-28-2013 | 11:44 AM
  #3487
-WHEELMAN-'s Avatar
They are VERY similar!!!
Old 03-28-2013 | 01:12 PM
  #3488
UN4RACING's Avatar
Any one tried the 1/8th blaze motor yet? 2450/2750 I think are the Kv's..
UN4RACING is offline
Old 03-28-2013 | 01:51 PM
  #3489
Wildcat1971's Avatar
but the program box is 1/3 the cost of the orion one. if you dont need the 160amp orion version, then pick up the speed passion.
Wildcat1971 is offline
Old 03-28-2013 | 05:09 PM
  #3490
Resqnu's Avatar
Just purchased and set up my sp revention pro. All works and going to test tomorrow
Question, tried to download the new software and update. USB driver will not install but program does. Help! FYI I am using windows 7 home edition on a Mac
Resqnu is offline
Old 03-29-2013 | 05:21 PM
  #3491
Cult Racing's Avatar
When is the Blaze 4600kv 4x4 motor going to be instock?
Cult Racing is offline
Old 03-29-2013 | 06:34 PM
  #3492
Cain's Avatar
Tech Legend
curious as well, Kvs are up there in comparison to what is considered "normal" for 1/8 4S these days but maybe they feel different?
+1 . Have heard of guys getting them overseas i guess and using them, though, the higher Kv versions.
Has anyone here used or still use the Cirtix R8 or whatever it was called ESC?
Cain is offline
Old 03-30-2013 | 08:25 AM
  #3493
makaluch's Avatar
Page 16 of the Reventon Pro Manual
Install USB driver: For Windows 7 / Vista
*After you extract the downloaded files you'll find the setup exe and the USB Driver folder.
1. Open SpUsbDriver folder.
2. Double click SpUsbInstaller.exe to install usb driver.
3. Press “Install” button to start.
4. USB driver will install automatically.
5. If security warning pops up, click on “Install this driver software anyway.”
6. Click ok to finish driver installation
* Wait a minute then connect your Programming Box. If you're using Fusion, connect to W7; works for me. Not sure if it works if you're running on a Boot Camp partition.
makaluch is offline
Old 03-30-2013 | 08:44 PM
  #3494
Waflet's Avatar
Originally Posted by Scooterboy34
Nope no different, perhaps there is a compatibility issue with iOS 6.1.2 on the iPhone, no problems at all with the iPad but I don't really want to have to take the pad to the track
Hideeho
You might be right. I had not gone to iOS 6.1.2. Now I have & can't get the reventon app to talk to the ESC. In settings I get the check mark indicating a wifi connection & the led is solid on the wifi adapter, but the app will not connect to the ESC. I have not tried an iPad.
Did you ever get your phone to connect scooter?
Has anyone else run into or heard of this problem?
Waflet is offline
Old 03-30-2013 | 08:52 PM
  #3495
Default Castle cm36 4600 ok to use??
Hey guys I have a speed passion reventon pro set to stock blinky mode and I was running a speed schuur 17.5 and I changed over to a castle cm36 4600kv sensor less motor to get more speed out of my car when I'm just messing around at the track and not raceing.. Should this set up be ok?? Just wondering if the ESC can handle that motor? I just dont wanna burn it up so I thought I'd ask.. Thanks
twitchvoodoo is offline
