Speed Passion Thread >
Like Tree4Likes
Old 10-31-2012 | 08:34 PM
  #1981
3Captain's Avatar
The Pro was $136 shipped
3Captain is offline
Old 10-31-2012 | 08:36 PM
  #1982
AlanHall's Avatar
Originally Posted by Mxer59
The R is like $66 last time it was in stock
oh ok it read like that dude paid 130 for it. maybe he got 2
AlanHall is offline
Old 10-31-2012 | 10:05 PM
  #1983
See
Originally Posted by 3Captain
Don't blame ya! Website showed in stock, yet I am now playing the wait game with a "reserved" order and $136 already charged to me
Same thing here.
See is offline
Old 10-31-2012 | 11:18 PM
  #1984
vysoto's Avatar
Default Reventon Pro
I could use some assistance i recently purchase a Reventon Pro to use in my RB6, it works very well except for 1 issue, i am losing brake under hard braking.
i have tried updating the firmware tried different firmware(mod 0, mod 1, stock 1) they all do the same thing. Here is my current setup
1.running mode= for/brake
2.volt protect = 3.2v/cell
3.heat protect = disable
4.brake force = 100%
5.drag brake = 30%
6.neut range = 6%
7.drrs3.0 = level 5
8.hb active = 40%
9.hb maximum = 110k
10.hb start rpm = 3000rpm
11.hb delay = 0s
software stock 1 v19
lcd program card software v2.4
any help would be appreciated
P.S. i also tried , changing sensor wire, changing motor, and different receiver and transmitter, none of these resolved the issue
vysoto is offline
Old 11-01-2012 | 04:00 AM
  #1985
5.drag brake = 30%
6.neut range = 6%
7.drrs3.0 = level 5
8.hb active = 40%
9.hb maximum = 110k
11.hb delay = 0s
Try a higher DRRS...it's basically your current limiter. More power for braking.
kwiksi is offline
Old 11-01-2012 | 09:33 AM
  #1986
Originally Posted by Cain
Solara or a SP Tech, can you provide me some info on my question above? didn't want it to get lost in the shuffle.
I am still very confuse about 550 motor...is that a 4 pole motor..? If so, please DO NOT use the stock1 (boost) software on that motor.
If that is NOT a 4 pole motor...use the MOD1 setup and max out the timing...mod1 setting does not have much setup on it but it is plenty fast.
Solara is offline
Old 11-01-2012 | 09:38 AM
  #1987
5.drag brake = 30%
6.neut range = 6%
7.drrs3.0 = level 5
8.hb active = 40%
9.hb maximum = 110k
11.hb delay = 0s
Yes, step up your DRRS...try 6 and I mainly use 7 on my B4.1....
Also, check your radio setting, make sure the throttle are in 100% setting and then recalibrate the RADIO/ESC again. Also, if you are setting the throttle trim to FORWARD like 10% more (rolling start) that will reduce your brake amount % because you are shifting the whole travel range of the throttle by 10% or more...
You say you are losing brake...are you missing brake at all or it just feel like less brake..? Or there are zero brake now...
Solara is offline
Old 11-01-2012 | 10:12 AM
  #1988
Cain's Avatar
Tech Legend
Its for a 2 Pole 550 motor, 4.5 setup.
This is in an SC10 4x4 that a buddy is using.
So, no more boost using on 4 pole 540s with the Reventon? was using that with the GT2.0 Pro and it worked well on a Pro4 4000Kv 540 motor, albeit, VERY little turbo needed. (like 5 degrees)
Cain is offline
Old 11-01-2012 | 12:17 PM
  #1989
vysoto's Avatar
Setting on radio where set to 100% for fwd brake was reduce to 80% to smooth out braking tried these setup on an aitronics m11x and on a futaba 3pks both 2.4 ghz
as far braking it would be fine for a couple of laps then it would fade out and then it would be ok again
I also changed sensor wire, motor, and receiver to see if any of these would cause the problem.
the only thing i haven't tried is changing the capacitor.
btw i also checked to make sure all my solder connections and reciever connections were good
vysoto is offline
Old 11-01-2012 | 04:09 PM
  #1990
3Captain's Avatar
My Pro shipped today
3Captain is offline
Old 11-01-2012 | 04:29 PM
  #1991
See
Just got my shipping confirmation on my pro also.
See is offline
Old 11-01-2012 | 09:44 PM
  #1992
STLNLST's Avatar
So.... What color did you go with?
STLNLST is offline
Old 11-01-2012 | 09:57 PM
  #1993
See
Black and silver the blue didnt match the rest of my electronics.
See is offline
Old 11-02-2012 | 03:03 PM
  #1994
AlanHall's Avatar
Could anyone explain to me the difference or advantage of the stock1 boosted settings vs the mod1 setyings on the revention stuff. Say with like a 10.5 or 13.5 motor. I guess the reason im.asking is whats to gain with a PRO in stock1 boosted vs a revention S or R in a mod1 setting
AlanHall is offline
Old 11-03-2012 | 11:05 AM
  #1995
AlanHall's Avatar
am i right that the S only has blinky and mod1? no stock1?
AlanHall is offline
