Speed Passion Thread >
Like Tree4Likes
Old 11-04-2012 | 09:07 AM
  #2011
AlanHall's Avatar
http://www.speedpassion.net/reventon/reventonr.asp
check out the bottom of the page
AlanHall is offline
Old 11-04-2012 | 09:16 AM
  #2012
Trevor Williams's Avatar
R/C Tech Elite Member
thanks Alan...gonna order an R version today!
Trevor Williams is offline
Old 11-04-2012 | 11:04 AM
  #2013
Mark Erce's Avatar
Originally Posted by Trevor Williams
so that LED programmer and my pc at home are all I need to alter esc settings correct? I mainly have ran LRP sxx in the past....sorry for the silly questions.....thanks for the help.
you dont need your pc to adjust esc settings. thats what the program card is for. but to download different software, for ex. switching to blinky mode to regular mode u will need the program card and pc together. both the led and lcd box(lcd is nicer due to the big screen and no reading numbers, but both work the same basically. the RP comes with the nice one) can do this. once u download the software just take your little card with you to make any esc adjustments.
1. download software from SP website
2. hook up card to esc and pc
3. click whatever software u wanna run from the computer screen
4. then the card transfers the new software to the esc....your ready to go!
i believe there's some nice videos floating around here somewhere demonstrating how to do it also. maybe someone can repost the video.
Mark Erce is offline
Old 11-04-2012 | 11:50 AM
  #2014
AlanHall's Avatar
right. then the box is for setting boost or brakes and timing. stuff like that.
AlanHall is offline
Old 11-04-2012 | 12:07 PM
  #2015
Mark Erce's Avatar
see i'm learning! lol
Old 11-04-2012 | 12:59 PM
  #2016
The Reventon R brakes are a lot stronger than my Novak. My brothers stadium truck with boost on an 8.5 works awesome (Reventon R)
cr133r is offline
Old 11-04-2012 | 06:33 PM
  #2017
See
Ran the pro today it is a night and day difference how smooth it is compared to the tekin rs I have been running.
See is offline
Old 11-04-2012 | 06:39 PM
  #2018
AlanHall's Avatar
in what setting
AlanHall is offline
Old 11-04-2012 | 06:42 PM
  #2019
See
17.5 blinky stock 0 profile
See is offline
Old 11-05-2012 | 07:49 AM
  #2020
jspurgin's Avatar
I bought a used GT2.0 and it is setup in blinky mode.i have the small program box but which setting should I put it on to get the boost and timing? Thanks
jspurgin is offline
Old 11-05-2012 | 07:59 AM
  #2021
AlanHall's Avatar
Are you asking how to take it off blinky?
AlanHall is offline
Old 11-05-2012 | 08:06 AM
  #2022
vr6cj's Avatar
If you want to change the esc software you have to use the lcd programmer and update the esc via a software download off the cpu using the lcd programmer.
vr6cj is offline
Old 11-05-2012 | 08:35 AM
  #2023
jspurgin's Avatar
Ok. Imay have the wrong program box.I don't have a USB cord to go the box from the comp.is it like a Hotwire? I'm kinda new to the speed passion stuff lol
jspurgin is offline
Old 11-05-2012 | 08:43 AM
  #2024
AlanHall's Avatar
You should have a disc and usb cable. But you may be able to download the pc program if you dont have the disc. Im not certain.
AlanHall is offline
Old 11-05-2012 | 10:02 AM
  #2025
Cain's Avatar
Tech Legend
for the GT2.0 series you need that LCD Programmer box to do the firmware updates. Unofficially people have had success using the hobbywing box once you flash its software (the actual box) to use Speed Passion software. I use this box, however, this is not supported by Speed passion, just an FYI.
As for what software to use, what is this going in and what motor?
Cain is offline
