Speed Passion Thread >
Like Tree4Likes
Old 11-14-2012 | 08:42 AM
  #2161
Word is...ROAR is about to approve the entire line of REVENTON series ESC for running the soon be release STOCK0 V20 software. It is still the same as the current Stock0 software except we have to have a VERSION # listed as this is the ROAR new rule....new update software should be out along with the new EOS winning off road software MOD2.
Solara is offline
Old 11-14-2012 | 11:45 AM
  #2162
[QUOTE=Nexus;11439071]Depending on the track you go to you can try lowering the DRRS first to say 6 or 7. Then if your setup is working well and traction allows for it go up incrementally. This increases your "punch".
Hi, thanks for the advice. I need more info/help on the DMTS side with regards to the setup of timing, degrees..etc. Hope you can shed light on this.
thanks again.
berkin is offline
Old 11-14-2012 | 11:46 AM
  #2163
I have problems with older Speed Passion 2.1 ESC. My sensored motor SP13,5T is running the opposite direction. I tried everything I know, but it always work opposite.. i tried several SW like stock 428 and older, but nothing change it.. with another ESC (Speed Passion 2.0LPF) the direction was OK. Is there any chance to change the motor rotation in the ESC?
TroubleRK is offline
Old 11-14-2012 | 11:49 AM
  #2164
AlanHall's Avatar
throttle on the radio reversed?
AlanHall is offline
Old 11-14-2012 | 11:57 AM
  #2165
2canSAM's Avatar
R/C Tech Elite Member
Have a like new, Blue Reventon R that I want to trade for a Silver Reventon R. I'll add 10.00 bucks to the deal. I bought this 3 weeks ago. It has 4 runs in it as stock with an 8.5. They were out of the silver when I ordered and I am moving away from the blue. Can provide receipt as well to show age. I thought I would try here first as this will see more traffic than Sale forums.
2canSAM is offline
Old 11-14-2012 | 12:02 PM
  #2166
sure I tried, when i calibrate transmitter with esc, (esc is set to throttle with brake only) it goes opposite while turn throttle on. when i reverse my radio (kopropo ex5ur) it does not do anything with throttle, but only reverse on brake position..
The only solution is to change the motor direction. I have multi esc program card SP, but i did not find the change motor direction function..
Old 11-14-2012 | 12:15 PM
  #2167
Wildcat1971's Avatar
The sensor or sensor cable might be acting up. Try without the sensor cable. And double check the motor wiring. Reversing on the radio wont help with esc's
Wildcat1971 is offline
Old 11-14-2012 | 12:30 PM
  #2168
i really tried everything.. different motor, different sensor cable... i need to revers the esc/motor..
Old 11-14-2012 | 12:38 PM
  #2169
If you cant get it to work without the sensor cable. Your esc is probably dead. There is no firmware to reverse it
you can reverse the rotation of BL sensorless motors by switching the motor connections until it reverses.
But if every sensored motor and every sensor cable with that esc rotate wrong, then buy a new esc.
Old 11-14-2012 | 12:55 PM
  #2170
DId you make sure that your motor cables are correct? If you swap two of them the motor will run backwards. With the sensor it's not likely to work but if the timing is advanced enough like most people are doing it just might.
linkless is offline
Old 11-14-2012 | 09:21 PM
  #2171
See
Good news.
See is offline
Old 11-15-2012 | 01:32 AM
  #2172
It is the only way to work.. but It has not full power without the sensor cable
Old 11-15-2012 | 06:54 AM
  #2173
dvsstrike's Avatar
Who here is keeping their bluetooth module in the car?
dvsstrike is offline
Old 11-15-2012 | 09:31 AM
  #2174
2canSAM's Avatar
Anyone want to trade a my 3 week old blue Reventon R & $10.00 for your Reventon R silver
2canSAM is offline
Old 11-15-2012 | 11:08 AM
  #2175
Speed Passion Reventon are now ROAR approved.
http://www.roarracing.com/?page_id=737
SP Tech is offline
