Speed Passion Thread
#3667
EXT98802-C01 It says its for the GT series.
http://www.speedpassion.net/us/produ...8802-C01&c=OPT
Or this:
EXA93301-C01 Which is for the Citrix Stock, but looks like the Rev. Pro version.
http://www.speedpassion.net/us/produ...3301-C01&c=OPT
MOmo
#3668
Hello,
I'm having a small issue with a Rev pro I just purchased. I'm not getting any motor movement. Motor is brand new and the radio and tx are perfect. I'm able to calibrate to esc with no problem. Both the orange and red lights are on. I've tried different sensor wires, another motor and different batteries.
esc = Rev Pro (firmware updated)
motor = Reedy Sonic 2 8.5
radio = KO Propo Eurus FH
Any suggestions?
Any suggestions?
#3670
Hello,
Any suggestions?
Any suggestions?
Can you hear the motor making ANY noises? Have you used this motor in other cars and has it worked before? Can you move the motor by hand w/o power on?
Momo
#3671
Hello,
Any suggestions?
Any suggestions?
#3672
Bingo!
Thanks guys. I guess it's not just Futaba radios that have to reverse the throttle.
Now that I understand how to read SP manuals, any other surprises I should be aware of?
#3674
I have a revention pro I having issues getting the speedo in to program mode if I follow the direction? If I press the setup up button after step 2 right when I turn it on it will enter into program mode? Ne1 else have this problem?
#3675
http://www.speedpassion.net/us/video.asp
4Likes
