Speed Passion Thread >
Like Tree4Likes
Old 11-15-2012 | 11:17 AM
  #2176
trx450racer174's Avatar
Originally Posted by SP Tech
Speed Passion Reventon are now ROAR approved.
http://www.roarracing.com/?page_id=737
Stock 0 update coming soon???
trx450racer174 is offline
Old 11-15-2012 | 11:33 AM
  #2177
Originally Posted by TroubleRK
sure I tried, when i calibrate transmitter with esc, (esc is set to throttle with brake only) it goes opposite while turn throttle on. when i reverse my radio (kopropo ex5ur) it does not do anything with throttle, but only reverse on brake position..
The only solution is to change the motor direction. I have multi esc program card SP, but i did not find the change motor direction function..
I have a KO radio and it works great. Throttle in reverse on the radio then rebind. When you do that the radio setting forward and brake remain the same and adjust accordingly. I had a exur5 and had to do it with my Tekin ESC
kerby is offline
Old 11-15-2012 | 12:38 PM
  #2178
subaru_tech's Avatar
so reventon pro,s came today.from what i have read.
make sure the drrs isnot set low
low cell=off
neutral dont set low.
and there was something on getting the reverse to work.
can someone tell me what the latest firmware these should have?
subaru_tech is offline
Old 11-15-2012 | 02:13 PM
  #2179
could use some help with a few questions.
esc=reventon pro-modify1 v16 software
need to run blinky mode.
do i need to download a different firmware to esc for blinky.
i did put the timing to zero,but no esc lights flashing.
i have also read i must update the lcd program card
Old 11-15-2012 | 02:18 PM
  #2180
You need to down load the firmware to your PC
http://www.speedpassion.net/reventon/home.asp?t=5
Update you LCD program box and set the Stock 0 profile to your esc.
Old 11-15-2012 | 04:06 PM
  #2181
A very minor UPDATE per ROAR requested.....just the software's name has to match what ROAR approved...which is STOCK0 V20. But when it is out, make sure use it....
Solara is offline
Old 11-15-2012 | 04:11 PM
  #2182
I have problems with older Speed Passion 2.1 ESC. My sensored motor SP13,5T is running the opposite direction. I tried everything I know, but it always work opposite.. i tried several SW like stock 428 and older, but nothing change it.. with another ESC (Speed Passion 2.0LPF) the direction was OK. Is there any chance to change the motor rotation in the ESC?
I am wondering...what is your car..? And what causes the reverse rotation...?
Understand this...if you are running SENSORED...only the SOFTWARE (if equipped) will allow you to reverse the rotation. For GT2.1, there are no software to do so.....sorry.
The only way to reverse the rotation of the motor is...use sensorless. unplug the sensor wire, you CANNOT use it. Then rotate the A and C wire (I think that is the way....FYI, I never tried it...I only heard about it). And the motor rotation will be reverse. And you will never be able to use timing and boost from the ESC.
Just try to find out WHY you need to reverse the rotation of the motor..?
Solara is offline
Old 11-15-2012 | 06:15 PM
  #2183
thanx for the help.
can more than one profile(stock-0,mod-1) firmware be installed on one program box.
or must i have multiple boxes?
Old 11-15-2012 | 06:17 PM
  #2184
AlanHall's Avatar
Youll have to plug in to the PC each time. But that would be an awesome featire to eventually have. But i think thats the point with the new blue tooth stuff?
AlanHall is offline
Old 11-15-2012 | 06:37 PM
  #2185
See
Originally Posted by dvsstrike
Who here is keeping their bluetooth module in the car?
Are they available here yet?
See is offline
Old 11-15-2012 | 09:21 PM
  #2186
dvsstrike's Avatar
see,
are you going to fawl brawl tommorow, if you are i will show it to you. works awsome. clint knows who i am. i works awsome no more pc all loaded in phone.
dvsstrike is offline
Old 11-16-2012 | 05:57 AM
  #2187
See
I will be there I know who you are I will come check it out.
See is offline
Old 11-17-2012 | 06:17 PM
  #2188
tony montana's Avatar
ok I got a second hand gt 2.0 pro. I havent been able to get it to work since I have owned it. Im using a spektrum dx3r in case I have something set on the radio wrong. But I cant get the speedo to power my rx without the use of a external bec. But even with the bec connected I cant get the speedo to set to my radio. Im programming it exactly the way the directions say to do so. Have the radio on, holding down the set button and then turning on the switch. I have a red light blinking when I do this. But then I click the set button to set neutral and there is suppose to be one green light flash after I do this and I have no lights after I click the set button. Im lost here
tony montana is offline
Old 11-17-2012 | 06:26 PM
  #2189
What servo are you using? Many new servos require a capacitor connected to the receiver. This is why Spektrum makes their own capacitor that plugs into the receiver.
Here is a video that walks you through the steps. If this is still not working please let us know. You can PM me or contact Speed Passion USA directly.
Reventon Firmware Update
Many of our racers and customers asked and Speed Passion came through. In the newest update for your Reventon you can set "custom" drag brake profiles. You still have the option to select the predetermined values or set custom drag brake in 1% increments!
SP Tech is offline
Old 11-17-2012 | 06:32 PM
  #2190
I dont have a servo connected to it. Also there is no link on your post that shows a video
