Speed Passion Thread >
Like Tree4Likes
Old 10-14-2011 | 11:36 PM
  #661
Turbo, Red= Positive, Black=Negative
John C is offline
Old 10-15-2011 | 02:30 AM
  #662
Hi Guys,
I'm still learning with this SP system it's got me little confused lol doesn't take much.
Right I'm running the SP 2.1 Pro with 10.5t motor in my 2wd with 27t pinion.
How do I give it more top end on the settings from my laptop?
Which function do I need to use
SC RPM Delay is for smoother bottom end? lower number more punch-higher smoother acc
SC boost level? not really understand
SC punch? Again not really sure
The booklet doesnt really make that much sense as it tells you one thing does this & the next one seems to me will over kill the other setting?
All I want is to give the motor more top end so do I just advance the timing on the motor
Or timing on the speedo but what setting?
At present it set as stock from the software
carlin is offline
Old 10-15-2011 | 05:45 AM
  #663
Not enough info to give you much help. Which software version are you using? In general, boost and turbo will give you more top end. Boost will kick in at whatever start RPM you set, then ramp up to its max value at whatever ramp rate you set. You're just using the speedo to advance motor timing as RPMs increase. Turbo occurs after you hit WOT, and kicks in after whatever delay you have set. Also sounds to me like you may be a little over geared, but can't say for sure b/c I don't know what spur or internal ratio you have. I'm running 23/81 with a boosted 17.5 in my B4, so FDR is 8.78. When you run boost and turbo, you're going to under gear the car compared to what you would run without. Look at the Team Driver setups on the website, you should be able to find something close. Start from there, check motor and speedo temps and make changes one at a time.
cjtamu is offline
Old 10-15-2011 | 07:10 AM
  #664
Hi
Does anyone know if speedpassion do a smaller size capacitor instead of the large brick type one,or another make that would work?
Quietman is offline
Old 10-15-2011 | 01:05 PM
  #665
youwish16's Avatar
i have a losi xxx-sct with the cirtix stock esc and 17.5 motor. first, are the brakes suppose to be applied as soon as i hit them or does it take a second? i set up the control and everything and when i hit the brakes, they take a second to apply.
secondly, what gearing should i run?
youwish16 is offline
Old 10-15-2011 | 07:03 PM
  #666
tmail55's Avatar
Was looking forward to racn' the T4 with my new SP 2.0 today, same one that blew the tires off Thursday night.
Pluged the lipo (5000 7.4) in and the esc SMOKED!!! :-(
Un-retired the SP GT1.1
tmail55 is offline
Old 10-15-2011 | 07:11 PM
  #667
are the speed passion SP2.1's capable of being run with a tekin 4 pole 4600kv in a Losi TEN-T SCTE?
NitroLuver is offline
Old 10-15-2011 | 07:49 PM
  #668
apriliamille's Avatar
disregard. they contacted me
Last edited by apriliamille; 10-17-2011 at 09:20 AM. Reason: email got to the correct location
apriliamille is offline
Old 10-15-2011 | 09:03 PM
  #669
ETA for more lpf's.....the indoor electric season is here
Lowrance is offline
Old 10-16-2011 | 12:27 PM
  #670
Hey, i got the Short course master ESC. and I have the Critix ESC USB Adapter on the way. I was looking on speed passions site, but didnt see any upgrade firmware. did i miss something? thanks for any help.
Dirtay J is offline
Old 10-16-2011 | 02:39 PM
  #671
Can someone explain the differences in the 17.5R V3 MMM, 1 Cell, and standard competition motors? I am looking for a stock class motor that is smooth but has some top end with or without boost. This will be going in a xxx-sct for outdoor tracks. Thanks
n2trouble is offline
Old 10-17-2011 | 10:12 AM
  #672
All V3 and 1S SP motors are on sale on SP website...check it out. This is only for USA (N & S America) sales only...make sure you click the N & S America button at the top of the website for the correct pricing.
http://www.speedpassion.net/us/catagory.asp?c=mtr&sc=2
Solara is offline
Old 10-17-2011 | 10:17 AM
  #673
Calibrate your radio with the ESC again...make sure your radio is setup at default position.
Yes.
2-3 weeks.
1S is more for 12th scale and TC. MMM has more top end power with higher timing. For SCT...I would stick with V3 motor. But MMM is actually a good option too.
Solara is offline
Old 10-17-2011 | 10:21 AM
  #674
There are none because whatever the latest one is on the SCM itself already.
Solara is offline
Old 10-18-2011 | 07:24 AM
  #675
does the silver arrow speed control allow the super charging settings?
cm.stites is offline
