Speed Passion Thread >
Like Tree4Likes
Old 11-07-2012 | 11:31 AM
  #2041
Carranza76's Avatar
Will the Reventon S 70A be enough to Run my 22 Buggy with a 17.5 Orion Vortex motor?
Stock only.
Carranza76 is offline
Old 11-07-2012 | 12:05 PM
  #2042
AlanHall's Avatar
Id have to think most any speed passion could run a 17.5 easily. If i was running 17.5 stock.. blinky right? Id definitely have an S.
AlanHall is offline
Old 11-07-2012 | 12:39 PM
  #2043
Carranza76's Avatar
the Reventon 70A is actualy the R not the S so I should be good to go then.
Old 11-07-2012 | 12:47 PM
  #2044
AlanHall's Avatar
Even the s or citrix would do 17.5 stock
AlanHall is offline
Old 11-07-2012 | 01:42 PM
  #2045
Stock only.
You'll be fine... The R is good for 5.5 or higher. I run a boosted 7.5 and it works great
kerby is offline
Old 11-07-2012 | 01:57 PM
  #2046
The S is good down to 9.5T
The R is good down to 5.5T
sjenkins97 is offline
Old 11-07-2012 | 02:01 PM
  #2047
Carranza76's Avatar
thanks fellas
Old 11-08-2012 | 07:30 AM
  #2048
dMITIj's Avatar
is it just me ore are there none Reventon Pro SP setups to found on SP sitet from there Team-drivers?
dMITIj is offline
Old 11-08-2012 | 08:37 AM
  #2049
2canSAM's Avatar
R/C Tech Elite Member
Probably been answered but I must be missing it. Can I remove the switch on he Reventon R and Stock Spec ESC. I know if I jumper the pins it will be always on when the battery is connected. I can just reconnect the switch if I need to mess with programming. Any harm in this?
2canSAM is offline
Old 11-08-2012 | 09:13 AM
  #2050
Stock only.
I've run the Pro, R, and S Revention in my 2WD buggies and they all work very well for 17.5 blinky
I'm sure you could, but I guess the question is why? Plus if it is new you might void any warranty or possible service help from Speed Passion.
Nexus is offline
Old 11-08-2012 | 10:28 AM
  #2051
AlanHall's Avatar
So reading about that switch.. i just got my pro yesterday.. wheres the switch? Maybr just havibg a DUH moment.. but i dont remember it
AlanHall is offline
Old 11-08-2012 | 10:53 AM
  #2052
The switch is now integrated with the ESC. No more extra wiring for a cleaner look. The programming button also doubles as the ON/OFF switch.
SP Tech is offline
Old 11-08-2012 | 10:57 AM
  #2053
AlanHall's Avatar
I was thinking that lol. I just haven't had more than maybe 2 minutes to check it out real fast.
AlanHall is offline
Old 11-08-2012 | 01:04 PM
  #2054
heavy's Avatar
When will the Reventon Pro, or R, or S be listed on the ROAR list for non timing esc ?
heavy is offline
Old 11-08-2012 | 02:35 PM
  #2055
Originally Posted by Raul Garcia
Anyone get Speed Passion USA on the phone in the past few days? Albert is unreachable...? Howard can you help?
He has tons of phone call everyday, 1 person 1 line...see you can leave a voice mail to him, he will call you back.
Solara is offline
