Speed Passion Thread
#1292
I have a gt 2.0 running 4pole in an scte cannot finish a main esc cuts out low voltage even with it set to 2.8 per cell. Should I go custom and set to 6.4v I don't want to shut it off due to practice sessions also
#1293
You can do that, however, maybe what you need to do is look and see if your battery is up to the task.
#1294
Hey questions, I had to throw in a speed passion becuase I was having problems with my Novak.. But when I plugged in the Speed passion with the Novak Blastic it was noticeably way slower. Do you guys have a video or a set to reprogram it or something to make it for it's faster? I have the programming box.. (My Novak was stock nothing on it programmed besides no reverse)
Any help is appreciated.
#1295
so if I am understanding you right, you put in a speed passion ESC as your Novak ESC went bad.
What ESC exactly did you put in?
What program box do you have?
What software is on the ESC?
What motor exactly are you using?
There are actually some nice setups on speed passions site for the ESC and a given software. I would find one that matches what class you are running and similar speed of motor and go from there.
#1296
http://www.speedpassion.net/en/produ...?p=11036&c=ESC
I dont know what programming box.. Its just like a box, changes timing drag brake etc...
I dont know software either.
Motor is novak ballistic 17.5
#1297
Turn off lipo cutoff and give that a try. Make sure you charged your lipo fully.
#1298
Anyone have the anwser to my question on how to make it like stock or something? Say the difference in the two are like night and day and it shouldn't be that much of a difference.. If there is how can I make it better?
http://www.speedpassion.net/en/produ...?p=11036&c=ESC That is the ESC I have, i'm running it in my 2wd buggy.
#1300
I run the SP 2.0 LPF ESC in my 2wd B4. I run 17.5 stock buggy (No Timing) and have my settings adjusted accordingly according to my stock factory program box (Non digital, original Software).
When I was racing last night, I have noticed that the throttle is very intermittent at times. I have tried a new sensor cable, and even changed models on my Radio (Fut. 3PKS using 2.4 Fasst).
I have checked the radio settings and it has a Linear CRV setting for the trigger, meaning it should be an equal as I give it throttle, yet it seems like its doing something erratic. Could it BE a bad sensor port on my ESC?
MOmo
MOmo
#1301
Got my GT2.0 Pro in the mail today. Got everything wired up and installed, except for the receiver and transponder. I need to buy another SR3500.
Otherwise, looks good. I like the DRRS settings. Makes having a 7.5T lazy or balls out.
Something else I noticed. I don't have a glitch buster installed on the receiver and the car doesn't cut out. I'm guessing the BEC's are better than the Viper and Tekin I have. Hopefully that stays that way. I'm out of space.
Edit: The fan sounds like a pocket helicopter. Insanely loud.
#1302
MOmo
MOmo
#1303
#1305
I have a spare HW digi box I'm willing to sacrifice.
Momo
4Likes
