Speed Passion Thread >
Like Tree4Likes
Old 10-06-2012 | 06:15 AM
  #1831
Originally Posted by ilanstylz
Quick question, I only plan on running stock class 17.5 no boost etc would the 40a version be more then enough or should I just go ahead and spend more and get the 70a? Thanks
If you can. spend a bit more f the R...more efficient and leaves you room to grow if you plan on going to lower turn motor or use boost in future.
kwiksi is offline
Old 10-06-2012 | 07:51 AM
  #1832
tony montana's Avatar
as I said before, My 22 came with the gt 2.0 pro. How does this esc compare to say the tekin rs series? Also it came with a hobbywing programmer box, looks to be the same as the sp one looking at the pics. I tired connecting it to the esc but it wont go pass the screen that says connecting esc? Do I need to download software to my laptop or does the box do it all. Also running a tekin 10.5 motor, could someone post all the setting Im roughly should be at? Thanks
tony montana is offline
Old 10-06-2012 | 08:03 AM
  #1833
Some say smoother than a Tekin.
D/L the latest software (v1.38) here..
http://www.speedpassion.net/en/produ...802PROcb&c=ESC
Update the LCD first...after that leave it plugged to your laptop and hookup your speedo...should be fine. Load/adjust whatever program you want to use on the speedo.
kwiksi is offline
Old 10-06-2012 | 08:07 AM
  #1834
Cain's Avatar
Tech Legend
I believe you need to have the ESC powered via the battery as well from what I recall. You can just power it from the LCD box and the PC.
Confirm with a manual first however, but at least that is what I have to do with my HW box and the SP ESCs from what I recall.
As for performance compared to a Tekin, after owning SP, Tekin, and Castle products, I keep coming back to SP stuff as I love the interface, the performance, and the robustness of the GT2.0 Pro series of ESCs. And I am a big warranty fan which is why I also love castles 1 year warranty, but man, the SP GT2.0 Pros are killer ESCs.
Cain is offline
Old 10-06-2012 | 08:08 AM
  #1835
so download 110323? So for the newb questions, all I ever have run is a tekin rx8 lol
Old 10-06-2012 | 09:29 AM
  #1836
ok I found the v1.38 software. Downloaded it but I get a error when trying to open it. Error 2048 say not a file quicktime understands???
Old 10-07-2012 | 02:56 AM
  #1837
Originally Posted by Solara
Allow me to answer...
The reason MMM was not widely used becasue the motor turn of MMM is design for ON ROAD USE...that does not mean the MOTOR is not capable to be used on off road. MMM 17.5 along with the silver red rotor is heavily used on blinky class in off road such as SCT and buggy.
If you are running it on buggy in MOD....V3 is the better choice because the 7.5 and 8.5 motor can does not have the vent holes like the other turn. They are heavily used for MOD buggy....and with the boost software, they are more then enough power for any track.
MMM is more fit for the blinky mode with 17.5 or 13.5 depends on your country's spec.........if you are running it on 13.5 or 17.5 or 21.5..MMM is your better choice. Otherwise, V3 is still the big off road favor.
13.5t MMM ordered.
kaan is offline
Old 10-07-2012 | 07:34 PM
  #1838
07Forester's Avatar
Anyone run the reventon r in a 4wd buggy with a 9.5?
07Forester is offline
Old 10-08-2012 | 07:49 AM
  #1839
07Forester's Avatar
Also can anyone recommend gearing in a b4.1 with a 17.5 v3?
Old 10-08-2012 | 08:48 AM
  #1840
Are you talking about Reventon S(40A)? If yes, this esc don't have Stock 1 Hybrid Boost Software. Only Reventon R(70A) and Reventon Pro(140A) Support boost. And kwiksi answer is correct. thank you
SP CS is offline
Old 10-08-2012 | 08:53 AM
  #1841
For GT series: Yes, you need to connect a battery to the ESC in order to connect to computer using the LCD card.
For Reventon Series: Big no, never connect a battery to the ESC when connecting to the computer. Only need to unplug the fan during connection.
For Cirtix Series: No, Same thing unplug the fan.
SP CS
SP CS is offline
Old 10-08-2012 | 10:32 AM
  #1842
my son is running one and he loves it alot, smoother and still fast.
SP Tech1 is offline
Old 10-08-2012 | 10:33 AM
  #1843
I run mine with a 78/25 with a 9.5 with mod software
For 17.5 aroung 75/30 is a good place to start in blinky and gear accordingly after that
SP Tech1 is offline
Old 10-08-2012 | 12:13 PM
  #1844
vr6cj's Avatar
Are the Reventon Pros ever going be in stock in US wharehouse? Or should I just buy them from overseas and forget about it?
vr6cj is offline
Old 10-10-2012 | 12:28 AM
  #1845
From what my drivers told me, they were never use 205g anymore because it is slow.....they are all running 428STOCK with boost and supercharger along with the 4x4 used motor. I have seen some using it on NOVAK and some on TEKIN (but I have not seen that in person)....some of the drivers are running the prototype Speed Passion BLAZE 4x4 SCT motor and actually they are using it at the up coming Futaba Race that host at Leisure Hour Raceway this weekend.
The BLAZE should be release around end of August.....as well as the 1/8th version of the BLAZE motor.
This was said a nearly 2 months back. Any more info on release date Mr Speed Passion? My fingers are getting twitchy.
Bumpy is offline
