Speed Passion Thread >
Like Tree4Likes
Old 05-02-2012 | 10:30 AM
  #1231
Originally Posted by Cain
any prelim info we can get on the new SP motors? Like what kind of plug setup they will use, etc.
2450 2750kv oversize motor aimed for 4x4 like the LOSI, it is hugh. And use standard solder tabs.
I actually using it on my SERPENT 960 running 6 cells...but I don't have a big enough parking lot to actually use up the motor.
Solara is offline
Old 05-02-2012 | 10:36 AM
  #1232
Cain's Avatar
Tech Legend
are these 1/8 motors? I guess I am just not used to such High Kvs on 4S nowadays. Usually in the 1800kv - 2200Kv range, max.
How are the can width dimensions in comparison to a Tekin 1/8 motor?
Cain is offline
Old 05-02-2012 | 11:18 AM
  #1233
Yes they are for 4 cells.....but I have used it from 2S to 6S. Very similar in size compare to the TEKIN 1/8th motor or the Novak size.
Solara is offline
Old 05-02-2012 | 11:40 AM
  #1234
Originally Posted by Solara
Every morning I asked myself this question....
Great.
Raul Garcia is offline
Old 05-02-2012 | 11:55 AM
  #1235
Originally Posted by Raul Garcia
It's a no go for 4wd(Dex410). Lpf has different construction than the pro.
Originally Posted by kwiksi
GT 2.0 LP is rated down to 5.5T motor. You can use it, but make sure you use the fan!
I don't recommend 5.5T for 4wd buggy or boost. I wouldn't do anything lower than 7.5T for 4wd.
So you guys go flip a coin or something and let me know? LOL
Culetto is offline
Old 05-02-2012 | 12:02 PM
  #1236
Originally Posted by Culetto
Just a quick question, is the gt2.0 LP the same board as the normal gt2.0, just minus the fan? I have a spare i was going to put into my 4wd buggy, i know the gt2.0 can handle but not sure with the LPF.
You can use it....if you are not running BOOST software, you can use the 205g and run as high as 5.5T on your 4WD. I think you should use 6.5 only...mainly ppl are running 205g with 7.5T.
If you use boost...try run it with 7.5 or 8.5T motor. It will not run anything faster then 6.5 with boost. Also, must run fan.
Both PRO and LPF comes with fans. The board looks the same but the parts inside are different...LFP are 1/2 the power of the PRO.
Solara is offline
Old 05-02-2012 | 12:06 PM
  #1237
Cain's Avatar
Tech Legend
Are there any plans to make a motor in the future with a lower KV in the 1800 - 2200 Kv range?
Cain is offline
Old 05-02-2012 | 12:10 PM
  #1238
Possible, but not now.....
1/8th off road just not hitting the market like what everyone expecting...but the market of bashing or drag racing is actually showing the need of fast motor.
Solara is offline
Old 05-02-2012 | 12:17 PM
  #1239
Cain's Avatar
Tech Legend
darn ... oh well thanks for the heads up though. would like to get my stuff all Speed Passion, but that high Kv makes me leery.
Cain is offline
Old 05-02-2012 | 12:29 PM
  #1240
Do own either one?
Old 05-02-2012 | 01:10 PM
  #1241
Do own either one?
I have a 2.1ex that was in my old touring car and a 2.0lpf that was in my f104. Since i dont race onroad anymore i was trying to figure out what else i could use them for. I like how smooth they are and easy to program with the LCD card but the documentation online can be a bit confusing with all the different software and versions.
Culetto is offline
Old 05-03-2012 | 10:11 AM
  #1242
t0p_sh0tta's Avatar
Default Gearing Help
I'm looking for gearing suggestions:
Car: AE SC10 4x4
ESC: 2.0 Pro (with the old software)
Batt: Speedzone 5300mAh 50C saddles
I started with a Tekin 5.5 geared 15/62 (32 pitch), but it was slow as a dog.
Put in a Tekin Pro4 4600kV in there, and it's running hot. I started at 13/62 and temped 160* in about 4 min.
Tried 11/62 and made 8 min in the high 170s.
ESC settings:
DRRS = 1
Timing = 1 (it's set to zero)
The motor continued to run strong, but I need to get temps down. I see there are others running higher gearing (14 & 15 tooth pinions) on similar sized tracks, but I'm starting to suspect a drivetrain issue.
Is there anything else I should do as far as the ESC is concerned?
t0p_sh0tta is offline
Old 05-03-2012 | 10:43 AM
  #1243
Cain's Avatar
Tech Legend
when you disconnect the motor from the drivetrain and free wheel it, any binding, weird clicking, etc?
have you tried temping the motor with a different temp gun to confirm that your temp gun is working accurately?
Cain is offline
Old 05-03-2012 | 11:42 AM
  #1244
t0p_sh0tta's Avatar
No binding or weird clicking when disconnected, only under power. I'm going to pull it apart tonight.
I used 2 guns and all were similar.
Old 05-03-2012 | 11:55 AM
  #1245
Cain's Avatar
Tech Legend
how would you describe your driving style? Are you smooth or on power / braking a lot?
Cain is offline
