Speed Passion Thread
#1384
I finally dug through the site and found the information but thank you. Its just funny to me that people I race with complain about spending X amount of dollars on an esc/motor combo and refuse to even look at SP. $60 for an ESC designed for blinky racing, but can handle a little more, is pretty awesome.
#1386
I just wish there were more stock racers around here so I could try it. I keep thinking I am going to buy the V3 Comp 17.5 and hook it up but first I need for JP, Luke, or Dustin to show up at the same track I do and hopefully get them to download the software for blinky and ask them what settings to try.
#1387
#1388
I run Mod now. I moved to the V3 Comp 9.5 and I am very happy with that motor. Very strong and pulls the entire straightaway and temps after 8 minute mains are 160-170 esc and 135 motor. JP moves around quite a bit and if it is a big race I am not going to bother him no matter what his obligations are supposed to be. I am hoping he runs at The RC Factory again soon so I can talk to him. Nobody else runs SP stuff except for them and me so my options of people to talk to are small.
#1389
i have a grandturismo 2.1 ex that is acting funny. I acting like it has two speeds. I tried updating the software and it still doing it. sometimes is work fine for a heat, then the next heat you will only have half the power or no power. any ideas?
#1390
Sensor problem....when you are slow, you are running sensorless. Check your motor sensor board, then sensor cable....if nothing work, the sensor port of the ESC is bad.
#1391
#1392
#1395
You aren't going to take that purty thing out in the dirt are ya?
Somebody needs to make a 90 degree end servo wire though....didn't care for the first pictures I saw of just the unit, looks even scarier with the plug connected. Not that it'll stop me from giving it a go, but still.
4Likes
