Speed Passion Thread >
Like Tree4Likes
Old 06-03-2012 | 05:01 AM
  #1351
Originally Posted by umm winning
I thought turbo was different from boost... Can i run stock buggy with turbo?
Depends on where you run. Most tracks have adopted the Roar blinky idea, but yes you can run boost with any of the higher turn stock motors.
kwiksi is offline
Old 06-03-2012 | 05:09 AM
  #1352
Originally Posted by kwiksi
So heres what happened today running two different 17.5's. I was able to stay somewhat competitive on tight track with no staights against mod cars.
Tried
SP V3 with 10 deg max phys timing geared 69/34...about 130f..decent
SP MMM with 20 deg timing green board 69/34 about 180f ...bit quicker
SP MMM with 11 deg...75/33 about 155f ...decent
Not sure where to gear the MMM...I experienced the same indoor on carpet running TC blinky. Way hotter than V3.
Good times yest at Stateline R/C in Fremont, IN. 215 entries for the Factory Tracks Midwest series! Long day with 23 heats in each round. Ended up locking up TQ after 3 rounds of qualifying in stock blinky buggy. Unfortunetly rains came heavy after the last heat. Race was called, but I left satisfied with a TQ. Track was huge 1/8 type.
I ended up running the 17.5 MMM geared at 75/33 with temps around 115f. Had maxed physical timing at 20 deg. on endbell. Dunno what I did different, but I did reshim the motor and added a milled motor plate for better cooling.
kwiksi is offline
Old 06-03-2012 | 03:51 PM
  #1353
I am looking at getting another 17.5 motor for offroad racing, mostly on a medium large (24 second laps) loose dirt track. I have two V3 motors that I have upgraded the sensor on to get 30 degrees of timing and they have worked well, high gearing with acceptable temps. Should I get another V3 or would the MMM be a better motor for this application? What timing is recommended for your selection. Thanks!
RCMaster1 is offline
Old 06-03-2012 | 05:12 PM
  #1354
What class? I believe the V3 is more torquey. I had great success in SC with one. I liked the MMM in buggy. I was running laps in the low 40 sec range. Lol. I will try the 30 deg. board next time.
kwiksi is offline
Old 06-03-2012 | 08:36 PM
  #1355
Stock Truck, Blinky. By 30 deg. board do you mean one that has an upper end of 30 deg. or an upper end of 40 deg.?
Old 06-04-2012 | 03:51 AM
  #1356
21-30 deg green board. I used the 11-20 deg red that came with the MMM. I'd prolly use either. SC I would def go V3.
kwiksi is offline
Old 06-04-2012 | 07:49 AM
  #1357
Cain's Avatar
Tech Legend
got my Speed Passion Silver Arrow V2 in.
Any tips on this when using with Tekin motors like the Buggy 2050Kv?
Cain is offline
Old 06-04-2012 | 07:58 AM
  #1358
Yea, pull the trigger....
Raul Garcia is offline
Old 06-04-2012 | 08:19 AM
  #1359
Cain's Avatar
Tech Legend
lol.
I'll keep that in mind
Cain is offline
Old 06-06-2012 | 02:04 AM
  #1360
i have 2 sp speedos and they are the carbon lpf ones and when i wire them up hey both seem to cog when using very little throttle? how do u fix this? is the neutral range? or something?
thanks in advance
av4625 is offline
Old 06-06-2012 | 07:32 AM
  #1361
Cain's Avatar
Tech Legend
new sensor wire is what I would try first.
What motor are you wiring them to?
Cain is offline
Old 06-06-2012 | 07:13 PM
  #1362
I run the Speed passion gt 2.0 in scte with a radio post tx/rx my motor is fantom racing 3.5 after about 3 min of racing i lose total power no steering no motor if i cut the receiver off wait 30 sec it works for another cpl minutes??? what is wrong
jford is offline
Old 06-06-2012 | 07:30 PM
  #1363
Have you checked any temperatures? If I'm following correctly that motor is a very poor choice for a relatively heavy RC like a SCTE. Virtually guarantee it's overheating. Better get a 550 size or at least a 4 pole motor.
Dave H is offline
Old 06-06-2012 | 08:31 PM
  #1364
Cain's Avatar
Tech Legend
+1 . Another thing, how are the batteries holding up?
Cain is offline
Old 06-06-2012 | 11:27 PM
  #1365
umm winning's Avatar
Radiopost, open up your reciever and clean it out, there is most likely dirt in there.
umm winning is offline
