Speed Passion Thread
#2851
I just wanted to drop a kudos to Speed Passion. After running Castle, LRP, Tekin, Orion, and now Speed Passion, I have to say that my Reventon Pro/Competition V3 is the best setup I've used. Smooth, fast, and reliable.
Great job guys!
Great job guys!
#2852
I did that for a few runs with a 550 but it got way hot even with a fan, so I didnt do that anymore.
#2853
#2854
I thought that the 323 software was the best for mod. Did I miss the 428 as the newest/better option?
This might be another option for you as I thought it was supposed to be better than the 205mod.Mark
Last edited by mark in wi; 01-15-2013 at 08:03 AM. Reason: Can't spel to save my life!
#2855
cool. thanks for the heads up. Pretty much run all GT2.0 Pros other than the pro stock I got in cheap. works well in the 2wd buggy so will keep it there lol
428 from what I can tell seemed very similar to 323, with a bit better temps. Pretty much used the stock stuff for awhile in 4x4 SCT, just configured as needed.
Run all mod software now in applicable vehicles since the timing settings in stock I wasn't using are by default greyed out in the mod software.
Main benefit I found was the turbo timing at WOT. using 5 degrees of it really work my Pro4 motor up and I could gear down and still get the top end I need. Temps dropped too.
#2858
Cain after a little digging I found
It might help you in the future if you need to swap an esc from the buggy to a truck. That was back on page 48 if you want to see any more. I know....its a slow day at work so I looked for it for a while.
If you track down all my thread....if customer asked me what ESC to run for 4x4 MOD...my answer is GT2 PRO...
GT2.1 can run with mod motor...5.5T limit. However, it is pushing it. It will never performs as good as the PRO. There is a reason we made these 2 ESC because they are different.
Did you use a fan the GT2.1..? Also, what software are you running on the GT2.1? You are SO NOT going to run boost on that 4 pole motor with your Gt2.1, it will not work....not got a CONCRETE BLOCK RC CAR like the Losi SCTE.
#2859
Thanks for the info. Yeah, I was more curious than anything else. In general when 2.0 Pros come up for sale, I pick them up as the ESC is that good. Wouldn't mind the Reventon Pro but not being able to run 4 pole motors is a no-no for me.
I am hopeful that when they make the 1/8 scale version, they really consider letting the ESC be ran on 2S. This is pretty much what all the other companies are doing now, and take nothing away from the Reventon Pro in other usage than 1/10 4x4 SCT, which is really just a glorified 1/8 buggy in a lot of cases.
#2862
J.P. Richards runs with the big dogs at the CRCRC Midwest Champs!
http://teamspeedpassion.com/2013/01/...championships/
If you register with Team Speed Passion they said they will be emailing registered members early info on product releases and ESC setup sheets from team drivers.
#2864
What are the motor limits of this reventon esc?
http://www.speedpassion.net/shop/det...SP000060&c=ESC
#2865
9.5T or slower
http://www.speedpassion.net/reventon/home.asp
click compare to see the specs for all of them
4Likes
