Speed Passion Thread >
Like Tree4Likes
Old 01-13-2013 | 05:39 PM
  #2821
Cain's Avatar
Tech Legend
stock is usually 17.5T motors at a minimum, 2S battery limit. mod is open motor, but may be limited to ROAR rules in general.
Cain is offline
Old 01-13-2013 | 06:55 PM
  #2822
Originally Posted by ALIEN3T
any word on when the lcd boxes will be in.
also trying to load the new reventon software on a 64bit win 7 computer. just like the video shows, last update worked fine, new update, all it lets me do is update to firmware 1.4, but doesnt read the esc when plugged in.
Your program card is LED or LCD? The latest version of LED is V1.4, LCD is V2.7. What ESC firmware do you using?
WMGary is offline
Old 01-13-2013 | 07:09 PM
  #2823
Anyone else having trouble connecting to the wifi module? I tried using IP 192.168.11.111 and 192.168.11.223. I'm able to connect to it but when I use the reventon app, it says wifi disconnected. I tried restoring the factory setting, no difference. I bought this item new from my LHS.
shagino is offline
Old 01-13-2013 | 07:35 PM
  #2824
I have LED, i installed th enew hardware they announced, (tried to put in the v1.4) but keeps saying stall ESC, or only gives me na option to update firmware. I installed the older version the night before sea,ed all right. Getting an LCD box just because, I plan to get more Reventons, and they all come with LED, so might as well upgrade.
ALIEN3T is offline
Old 01-13-2013 | 09:39 PM
  #2825
See
Reventons come with Lcd boxes.
See is offline
Old 01-13-2013 | 09:44 PM
  #2826
Thanks for helping. Not stock. Thanks
xxx123 is offline
Old 01-14-2013 | 09:05 AM
  #2827
My Reventon s came with the LED box. I see the pro comes with the LCD.
ALIEN3T is offline
Old 01-14-2013 | 03:15 PM
  #2828
@SP Tech Can I get some help here?
shagino is offline
Old 01-14-2013 | 03:53 PM
  #2829
Default v3 motor connectors
Anyone know any alternative bullet connectors to the speed passion ones used on v3 motors or what size they are? I just bought a used motor and have no way to hook it up to my esc.
Icero is offline
Old 01-14-2013 | 04:28 PM
  #2830
07Forester's Avatar
A few of us are working on it....
07Forester is offline
Old 01-14-2013 | 04:30 PM
  #2831
07Forester's Avatar
Speed passion has the connectors on their website. Or, you can solder directly to the tabs which is what I do.
Old 01-14-2013 | 04:39 PM
  #2832
Is it necessary to remove the endbell to change the mechanical timing on the motor? I heard from a member of my local track that you only need to loosen the cap rather than to remove the whole endbell. When I tried, it showed a bit of resistance and I did not proceed further for fear of breaking the connector. Would anyone like to share their experience in adjusting the mechanical timing on their motor?
Thanks!
capricorn415 is offline
Old 01-14-2013 | 04:40 PM
  #2833
07Forester's Avatar
Thanks!
I've always done it by removing. When I get home I will test your way, and verify what works.
Old 01-14-2013 | 04:53 PM
  #2834
Cain's Avatar
Tech Legend
I do it by loosening the screw enough that it can turn. But there is some resistance.
Cain is offline
  #2835
Thanks for checking.
He did mention that the sensor unit rests on top of a rubber ring which may make it hard to slide if not loosened well. I chickened out at this point as I didn't know how far to go before the endbell came off. From his experience, he told me that reassembly was nothing to look forward to as the magnetic rotor was finicky to align and frustrating as heck to get through the bearing.
Thanks again for helping out. I look forward to your findings.
