Speed Passion Thread >
Like Tree4Likes
Old 08-14-2012 | 11:38 AM
  #1531
Originally Posted by savannahmick
I have a couple questions about swithching rotors with my SP v3 17.5 and Ultra Sp. v2 11.5/3600 because I noticed the rotors look the same except different turn. Anyway I run nitro but like to mess around with 2wd SCT I would really like to use the can from my v3 17.5 it has much better air flow also I don't have to solder on new connectors and the reason I am wondering is I run at two tracks one is 17.5 SCT other is 10.5 SCT. What effect will switching rotors from a lower turn motor into a higher turn can if compatible have on the motor turn/performance? Might have been stupid question but I am curious! Thanks!
Those 2 rotors are the same (black/purple ring)...so swapping them will not make a different.
For SCT 2WD stock 17.5...our latest setup is using the super 7 SILVER RED 12.5mm rotor with tall gearing...works great.
Solara is offline
Old 08-14-2012 | 11:41 AM
  #1532
Originally Posted by caltrigger
I have bought a TD DEX410Rv3 and returning to rc after a 7 year break. There are 4 of us wanting to buy the same setup for social racing on our own track. We do not have a local club for 1/10 so we kinda setting our own standard.
We need to choose a motor and esc comination that will be simple and not too programable but that will perform well and have decent speed. Comming from brushed history I need advice on which turn and esc to use. We would like an esc that can handle down to a lower turn if we need.
I was thinking 10T 4000Kv or so, would that be too slow?
We not experience racers but want something we can grow into speed wise, we also want something standard and ensure all the guys run the same setup, kinda like stock racing i guess.
Your comments welcome...
You will need the GT2 PRO with the LCD programmer box and some 550 or 4 poles motor.....SP will have the SCT 4x4 motor called BLAZE coming soon, and should be here around end of September early October...
Solara is offline
Old 08-14-2012 | 11:46 AM
  #1533
Originally Posted by Joel Lagace
Anyone on here work for Speed Passion USA?
I have been trying to get 2 new cases for my GT2.0 LPF Brushless ESC units. Back in may contacted Albert at Speedpassion about buying them directly, we exchanged emails and all was set to send me some replacements(price address ect ect)... Weeks passed and nothing, started to email him back june/july and no more responses???
Anyway can anyone help me get a hold of 2 new cases? any color just need to fit my GT2.0 LPF Brushless ESC
Thanks.
Can you please call ALBERT and talk to him on the phone instead....thank you. Phone 1-888-928-1328
Solara is offline
Old 08-14-2012 | 11:47 AM
  #1534
Originally Posted by manuelargentina
I've recently updated my new GT2.0 Pro with the 428STOCK software, but is no working. Only have the red light blinking since!!! Steering servo moves but motor isn't. I've turn off all system and try to re-calibrate the radio wiyh no success. Can anyone give me a hand with this please?
Thank you!!!
Manuel
I bet it work now...your PM said it does...thanks.
Solara is offline
Old 08-14-2012 | 11:54 AM
  #1535
Originally Posted by Autocratic
Just looking for something smaller than the Pro for 17.5. Also, need something that's in stock too.
I can see you want something for the 410 SCT 4x4...unfortunately the ON and OFF ROAD NATIONAL are all happening right now and till the end of August and all the GT2 PRO are reserved for the drivers or already sold out to the drivers.
I hope more will be back instock after September.
If you are running blinky or MOD on 1/10th off road...the GT2 LPF or GT2.1 ProStock will work on off road 2WD or 4WD with boost or no boost (with dynamic timing) or blinky....it will be pushing it when running it on 4x4 SCT with mod 550 motor with boost...I personally think that is POSSIBLE but I just have not try it in person nor anyone did any testing for me....most ppl are all running GT2 PRO because they want the best out of it.
We do not have anything smaller then the GT2 that can do all these MOD racing with boost...usually the smaller ESC are either thermal or they let the magic smoke out after 4 minutes...
The possible smaller unit that will work beside the GT2 PRO...is our new REVENTON PRO.
Solara is offline
Old 08-14-2012 | 12:59 PM
  #1536
Autocratic's Avatar
I don't have a SC truck.
I'm currently running the GT2.0 Pro in my DEX410 buggy and love it. I ordered the ProStock that will go in my DEX210 whenever it gets shipped. I will most likely order another GT2.0 Pro to replace my Tekin RS which is giving me some issues lately.
Whats the specs on the Reventon Pro?
Autocratic is offline
Old 08-14-2012 | 04:21 PM
  #1537
trickedout's Avatar
Hey Howard, ended up getting the GT2.0 LPF and I couldnt be happier. My brother went from a Castle MMP to this and its a night and day difference! Looking forward to purchasing more Speed Passion in the future!
trickedout is offline
Old 08-14-2012 | 10:38 PM
  #1538
onekiwi's Avatar
Whens the revention pro coming out?
onekiwi is offline
Old 08-15-2012 | 05:56 AM
  #1539
And how it worked!!!! AWESOME as my other GT2.0 Pro... ! Thanks!!!
manuelargentina is offline
Old 08-15-2012 | 08:26 AM
  #1540
GT2.1 ProStock is a good choice for your 210.....alot of the local Durrango driver used the LPF version but some are using the ProStock as well. You won't be wrong anyway....
Reventon PRO spec.....ah, ALOT....140 amps for a starter. Smaller...on board switch. Intercooler channel cooling design. Wifi, bluetooth programming...I am still trying to know all of these feature right now.
Solara is offline
Old 08-15-2012 | 08:27 AM
  #1541
For the price right now...I would stock several of those and run BOOST with it...get the LCD and use the BOOST software, LPF can do boost just like the PRO except I would not boost anything faster then 6.5 motor with LPF.
Solara is offline
Old 08-15-2012 | 08:28 AM
  #1542
Late September October....actualy, they are on sale over Asia and Europe...we are trying to get that approved by ROAR...that will take some time.
Solara is offline
Old 08-15-2012 | 10:01 AM
  #1543
Cain's Avatar
Tech Legend
Revention pro being used at all in 4x4 SCT yet?
Cain is offline
Old 08-15-2012 | 12:30 PM
  #1544
onekiwi's Avatar
Where, I can't find any to buy?? What do you have to get approved? the esc like lipos? Or is it for stock settings etc?
Also if the GT Pro isn't available whats the next best thing to run mod? EX/LPF?
onekiwi is offline
Old 08-15-2012 | 02:05 PM
  #1545
LPF and GT2.1 ProStock is capable to run MOD...even with boost. But I prefer to cap it under 6.5T with full boost.
Solara is offline
