Speed Passion Thread >
Like Tree4Likes
Old 11-10-2011 | 06:35 AM
  #781
how do i flash the lcd box
dan200487 is offline
Old 11-10-2011 | 06:51 AM
  #782
Once you d/l the program. There will be a box. Up in the corner it will say device. Pick LCD program. The hook up the LCD. Then you can flash it. Press upgrade if I remember. Pretty easy.
kwiksi is offline
Old 11-10-2011 | 08:11 AM
  #783
Originally Posted by tmail55
Never thought about undercut having the reverse turned off.
I've never raced with reverse off, have it set at 75%. I bump the TH trim up a few so the esc can't see neutral. Should be a interesting weekend getting use to MORE braking! :-)
THANKS for the info!!! :-)
Please help UNDERCUT. Our ESC is very well known of the BRAKE, and when you guys tell me that our ESC has no brake, the 1st thing I know is the reverse is off.
There is a reason why our ESC is not the super compact small design. Anything has a limit...you want small ESC, you gave up something. We want performance over the size........thats why we won the WORLD CHAMPIONSHIP 2 times, and going for the 3rd.
Solara is offline
Old 11-10-2011 | 04:25 PM
  #784
t0p_sh0tta's Avatar
Hey guys, I have a 10.5 V3 motor with bad sensor board.
The motor cogs when it starts going. Unplug the sensor cable and it works fine. Plus the LED on my Tekin RS shows that only 2 sensors are being picked up.
Where can I find a replacement sensor unit ASAP? I looked into ordering from SpeedPassion, but they aren't in stock in the US. I've even tried eBay, but it'd be shipped from Hong Kong.
t0p_sh0tta is offline
Old 11-11-2011 | 09:14 AM
  #785
Already answered your question, all sensors are instock at SP USA direct sale site.
Solara is offline
Old 11-11-2011 | 09:33 AM
  #786
Default Strange issue - SP GT 2.1 EX
Hello!
My esc is mounted in a 1/10or-car. When I stop the car, release the throttle the engine will not start again, the car will not go forward. But a small (barely noticeable) boost from another car and it will start again.
Have tried this without pinong, the same. When I turn very lightly on the pin it go again.
Have tried different sensorcables, and diffrent engines. Have change capicator also.
Before i had the esc in a 1/12 pancar, then i put it in my OR, drived about 10 rounds then this problem apperead.
Broken or Software? Or something else strange?
LumberJack is offline
Old 11-11-2011 | 10:42 AM
  #787
Originally Posted by LumberJack
Hello!
Possible sensor problem on the ESC............
Solara is offline
Old 11-11-2011 | 12:37 PM
  #788
Trashcan or is it possible to fix?
Old 11-14-2011 | 01:39 PM
  #789
Where is your location..? We can try to fix it but the better chance is we can sell your a refurblish version....kinda like new but it is reflurblish with limited warranty. PM me your information.
Solara is offline
Old 11-16-2011 | 05:06 AM
  #790
Pulse_'s Avatar
Just got an used SC10 with a speed passion combo for a stealing price, but I have no programming card.
The ESC is a SpeedPassion GT Competition Brushless ESC v1.1
Does anyone know where I could find this programming card?
Pulse_ is offline
Old 11-16-2011 | 07:35 AM
  #791
If you weren't in Belgium, I'd send you the one that's in my living room. If SP doesn't have it, try HW site.
cjtamu is offline
Old 11-16-2011 | 10:29 AM
  #792
dag32's Avatar
Sorry for the shameless plug but I have a great Speed Passion v2.1 Pro-Stock ESC+SP 17.5 Motor+Program box for sale here on RCTECH. Click here to see
dag32 is offline
Old 11-16-2011 | 12:22 PM
  #793
Pulse_'s Avatar
Thanks! I managed to bind my radio to the ESC but I'm wondering if the cut off is ok. Don't wanna burn my car because I had no cut off set up
Pulse_ is offline
Old 11-17-2011 | 08:21 AM
  #794
Default setup of the GT1.1 ESC is set at 2.6V/cell.........but if the ESC was previously setup by someone, it will be different. I never use cut off on my lipo so I will setup to 0.......
Solara is offline
Old 11-17-2011 | 08:44 AM
  #795
mjk1210's Avatar
yeah but you get free batteries!
My advice, as SOON as you notice that the power of the car is fading, pull it off and stop running that battery. If the previous owner changed the cutoff to a lower number it will be the best way to keep from overdraining the battery and causing irreversible damage. It's a good rule of thumb to go by even with the cut -off.
mjk1210 is offline
