Speed Passion Thread >
Like Tree4Likes
Old 11-01-2011 | 05:32 AM
  #751
Originally Posted by NitroLuver
I am still having an issue with this speedo..I re-programmed, and re-geared my 17.5 and it still was very slow...what do you guys think is the problem?
What motor are you using? Can you advance the physical timing?
kwiksi is offline
Old 11-01-2011 | 10:22 AM
  #752
used a murfdogg 17.5 I can advance the motor timing but it should'nt be as slow as it is
ok I would like to get the box if I could find one...you know a place that has them in stock?
NitroLuver is offline
Old 11-01-2011 | 10:55 AM
  #753
Originally Posted by Mxer59
Thanks just was curious as I can't get the gt 2.0 pro anywhere. And I've heard shortage is due to a new model being released. I want to run sp just can't find them anywhere and I've been told silver arrow 2.0 won't work on 2s either
Give us couple weeks, I was told there is shipment coming next week, some GT2 PRO and LPF.
Solara is offline
Old 11-01-2011 | 10:57 AM
  #754
mjk1210's Avatar
Pretty sure I saw one on the A-Main website just the other day.
mjk1210 is offline
Old 11-01-2011 | 11:17 AM
  #755
Mxer59's Avatar
Thanks for the info I'll defiantly be buying a pro I don't have a Esc right now as I sold them off for the gt2 pro
Mxer59 is offline
Old 11-01-2011 | 12:02 PM
  #756
Getting the box...from a-main hopefully I can get my truck running good once it gets here but until then I'll have to throw another system on
Old 11-02-2011 | 02:33 PM
  #757
sc10pc's Avatar
Hey, has any of you guys heard about the new ananta 2sc kit from speed passion?
sc10pc is offline
Old 11-03-2011 | 12:31 AM
  #758
bzb
several times on this tread
i'll get one!
bzb is offline
Old 11-03-2011 | 12:03 PM
  #759
Should be out on X'mas time....I am working out the number of PARTS that I need to order to fullfill the US dealer...we will go start a pre-order special. Stay tuned...
Solara is offline
Old 11-03-2011 | 12:30 PM
  #760
are any of yall using the speed passion chargers? if so which ones i would like something that can do atleast 10 amp charge rate.
cm.stites is offline
Old 11-03-2011 | 01:51 PM
  #761
Hi all,
i start racing a Asso 44.1.
ESC: SP GT2.0 LPF
Motor: Gens Ace mars 6.5T
Gearing 81/20 (?)
Can anyone give me a recommendation for ESC Settings
for the advanced programs (12 - 15) ?
Track will be indoor - carpet
Thanks in Advance
Kuhnibärt is offline
Old 11-03-2011 | 02:02 PM
  #762
t0p_sh0tta's Avatar
Any ETA for the 2.0 Pro or LPF to be back in stock?
t0p_sh0tta is offline
Old 11-04-2011 | 02:34 AM
  #763
mjk1210's Avatar
Originally Posted by Kuhnibärt
Hi all,
ESC: SP GT2.0 LPF
Gearing 81/20 (?)
Thanks in Advance
Check the setup sheets on the website. I would put the last one around 500 with a 6.5 though. Check temps and if for some reason it's getting hot (over 150) go to 600. I wouldn't expect you'll reach full throttle very much on a carpet track (they are usually not very big) especially with a 6.5 motor
mjk1210 is offline
Old 11-04-2011 | 03:00 AM
  #764
Many thanks for your advise.
Alternatively i can try a Reedy Sonic 9.5T.
i will try the 6.5T first.
regardz
Old 11-05-2011 | 12:23 AM
  #765
I am trying to connect my esc to the pc but the box just says connecting and the SP software has everything grayed out..what am I missing? ps my version is
V1.07_110119 lCD
and esc is V1.10_090205MOD but it won't let me update the esc? is the sofware not supported on windows 64bit?
esc is a gt 2.1EX
my LCD Box quit working...it won't show anymore text how do I go about returning it? and what is the turn around?
