Speed Passion Thread
#766
Any one Running a Silver Arrow 2 and Citrix 2200, I have this in a Hot Bodies Ve8 and I have very little brakes, they do slow you down but very slowly, I have had castle systems and they will lock the wheels up. I have the radio set up right, I do get the proper lights on the speed controller when full brake is reached. I have tried with two different recievers and two transmitters, one a Eurus-10 the other a dx3s. I have set up the speed controller with 100 on the transmitter and then bumped it up to 150 with no change.
#767
#769
I'm one of the racers that assisted undercut Sunday in trying to get things working.
I've had SP esc's since Dec 08 (first was a GT1.1 lpf).
We re-bind the radio/receiver, re-programed the radio to the esc and re-set the esc to base spec's. All had the same results little to no brakes.
Last time I seen this happen was with a Novak brush esc. It had a burnt smell to it after about five minutes after it lost brakes, undercuts SP esc doesn't have a smell to it. First thing I checked.
#772
#773
#774
just curious. Does it work like this on the GT2.0 and 2.1 speedos too? If I have FOR/BRAKE setting and change reverse to 100% will the brakes increase too?
#775
#776
Never thought about undercut having the reverse turned off.
I've never raced with reverse off, have it set at 75%. I bump the TH trim up a few so the esc can't see neutral. Should be a interesting weekend getting use to MORE braking! :-)
THANKS for the info!!! :-)
#778
dan200487
Download V1.36 to get the latest and greatest. You will need the LCD programmer though.
http://www.speedpassion.net/en/produ...802PROcb&c=ESC
#780
You should be able to. Others have. You will need to flash the LCD box. If your going to use boost with a 7.5. Be careful, start at very low settings. If your new to 323 I would just run 205mod until you have a very good understanding of 323. Really...boosting a 7.5?
4Likes
