Speed Passion Thread >
Like Tree4Likes
Old 01-18-2012 | 03:48 PM
  #931
Suspended
Originally Posted by banditcustoms
I have a speed passion 1/8 scale esc motor combo, the motor is a cirtix 2200 and the problem im having is the front screws came out. so what we had to do is re-tap the holes and go to a bigger size. but the motor has so much power it ripped the can at the screws. i was wondering if i could get a new can and top of motor?? where the bearing goes. and also i was wondering how hot should this motor run?? after a 10 min main. im at about 230 degrees everyone is saying thats way to hot.. but it still runing great. i just have to check the screws after every run... and also is there a new motor coming out for the 1/8 scale stuff. that will work with the silver arrow. i like running speed passion stuff to be different.. cause everyone here runs tekin
please any help would be great..
The screws coming loose are a common problem. Your motor is gonna run hot mostly due to it being a smaller than normal 1/8 size motor. They were made back when 1/8 buggy/truggy was in it's infancy. Now the motors are way bigger and make more power and have a greater efficiency. 230 is way too hot. A common 1/8 buggy/truggy motor should be at 180 or less.
And yes they are fixing to release a new 1/8 motor. I believe Solara mentioned it a few pages back.
MattP is offline
Old 01-19-2012 | 06:02 AM
  #932
banditcustoms's Avatar
thanks matt, how can i get the heat down,,
banditcustoms is offline
Old 01-19-2012 | 09:51 AM
  #933
Default Citrix club stock ESC and 17.5
I'm looking for help.... I bought a citrix club stock esc and 17.5 about a month ago for my t4.1 truck. I have raced it 3 times (no other practice time b/c of bad weather). This past Tuesday, I showed up to race and the brakes either don't work at all or have about a 2-3 sec delay before working. I recalibrated a few times and replaced the sensor wire. Sometimes the brakes work immediately but usually with the delay. No changes were made to the electronics and all was fine when I drove it at the previous race.
I just talked to Albert at the support phone # and he suggested that I change the capacitor and see if anything changes.
Any other ideas? I do not have the programming card so my options might be limited.
riverdog is offline
Old 01-19-2012 | 11:24 PM
  #934
AlanHall's Avatar
Any have luck with the v3 13.5 in a SC truck? Or should I put some cash together for the MMM
AlanHall is offline
Old 01-20-2012 | 04:53 AM
  #935
I have had good luck with 13.5 v3 and 323 software in sc
clintscreations is offline
Old 01-20-2012 | 11:12 AM
  #936
AlanHall's Avatar
ok cool. i have the gt2.1 and 17.5 but need to go 13.5 for SC. there was a v3 13.5 in the forsale section
this one
http://www.amainhobbies.com/product_...ess-Motor-135R
AlanHall is offline
Old 01-20-2012 | 12:28 PM
  #937
Suspended
Really no secret cure. Add vents to the body, gear down a tooth on Pinion, or just pick up a better newer style motor.
MattP is offline
Old 01-20-2012 | 01:11 PM
  #938
this one
thats the one.......i keep switching between that and v3 8.5 with 205mod software......
Old 01-20-2012 | 02:24 PM
  #939
AlanHall's Avatar
Cool I have the 323 software. Sucks with such a sweet esc to have to run blinky. But ill try the motor.. how would you compare it to the ballistic?
AlanHall is offline
Old 01-20-2012 | 03:14 PM
  #940
umm winning's Avatar
Just got myself a gt 2.1 prostock... and Holy **** this is one nice esc... didnt know its came with a program card and all the extras!!!! A+ SP
umm winning is offline
Old 01-20-2012 | 06:15 PM
  #941
You can use 323 with 8.5. I have....just use very low settings to start with. Phys. timing middle on can.
kwiksi is offline
Old 01-20-2012 | 06:41 PM
  #942
I like 205 for my "mod" stuff
Old 01-22-2012 | 08:15 PM
  #943
ambryatim's Avatar
Default Running Weird
Hello everyone. I am having an issue and I think it might be ESC related.
Ok what I have is a Hyper 10TT with the SP GT PRO 2.0 a Tekin 4.5 SC4X and a savox 1258 servo. Batteries are 40c 5.4mAh
Now I have tired a new sensor wire and it still does the same thing. I have linked a video so you can see what it is doing. The turbo/boost does not always kick in like it supposed too. As you can see in the video it is almost as if I let off the throttle for a second then reapply and the boost kicks in. Rest assured I am still holding it at full throttle when this happens.
Setup Sheet I am using http://www.speedpassion.net/uploadfi...20Walt%20G.jpg
+ YouTube Video
Any info would be greatly appreciated.
ambryatim is offline
Old 01-22-2012 | 08:23 PM
  #944
russp's Avatar
S.P. for life! Haha knew you'd like them
russp is offline
Old 01-22-2012 | 11:08 PM
  #945
+ YouTube Video
When you stab the trigger to full multiple times, check the green light on the speedo, see if it flashes. If its flashing, yoy have either a bad sensor wire, sensor on the motor, or the circuit on the speedo is damaged. I would try another known good sensor lead first.
Raul Garcia is offline
